The purpose of this instructable is to show how you can remove solder from a board when you're in a pinch.
Let me know what you think of doing it this way or if you have another method...
Remove these ads by
Signing UpStep 1First things first
1) Something you want to desolder
2) a piece of wire or two
3) tinning flux would be nice
4) a soldering iron
5) wire strippers
6) pliers
I'm using a strand from a piece of cat 6 cable I had laying around. All I had was solid, but I'm guessing the stranded type might work even better (like copper braid).
Strip the wire back a couple of inches and get out those pliers.
im guessing that u mean the weller butane irons. The portasol is said to be pretty good and i am considering getting it.... not only is it good for soldering (using a soldering tip) but the hot air tip and blow torch tip can be used for smt work and also possibly desoldering... Adjustable flame control also allows for precision temperatures as to not burn out certain components such as semiconductors, which are very heat sensitive
Clearly, i have done my homework on this topic, so to say
these are the irons i am talking about
