Remove these ads by
Signing Up
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
You and I know how to do this, but can you explain how in a bit more detail?
L
You are completely right, it is a subject that needs a good explanation. I also have taken apart a lot of old or disfunctional electronincs for parts (and have burn some fingers while doing it) and as you say it isn't as straightforward as it seems.
And I must say that I now prefer to buy part instead of reusing them (with the exception of motors and solar cells and some other bigger and more expensive parts). Some of the standard values are so cheap that isn't worth to heat my solderingiron for it. And new parts have long leads so they are easier to use when soldering.
But that ofcourse is only my humble opinion.
And by means I mean something like this:
http://img408.imageshack.us/img408/1200/solderpot.jpg
I can humbly strip a few hundred dollars of parts an hour with it. But you're right, trying to salvage parts with a soldering iron is a waste of time and often destroys parts in the process as well. I still have to buy some parts myself. I can't always find everything.
Though I have done projects with just salvaged components too. And if I strip expensive commercial electronics it is a good bet the overall component quality is better than most are willing to pay for, or in many cases even have access to.
You can see some of my parts storage here:
http://www.instructables.com/id/Pauls-Electronics-Pit/
No part is worth me getting burnt trying to get! That just doesn't happen.
L
L
With it I can pull any through lead part off a board that is less then 3 3/8 inches long (88mm) in about the time it takes me to put the board onto it and pull. If there's a better way of stripping boards I've never heard of it, or I'd have it!
if its 4-5 pins i usually lay the irons tip flat against all the pins at once and romove then, or break away the board if im going to trash it
If there is anything more than that going on I can't see it.
I will tell you this though it takes my pot about 40 minutes to get molten so be patient. It isn't like popping something in the microwave.
