3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Whip Convection Vaporizer
This is my homemade DIY Vaporizer. I mostly vaporize herbal mixtures, but it would work as well for tobacco. It uses convection (only hot air touches the plant material) which makes a cleaner vapor than induction (where the heat source touches the plant material). Some scientific evidence suggests that vaporization puts fewer carcinogens in a vaporizers (the person doing the vaporizing). Some evidence suggests that it doesn't make any difference. I think it tastes cleaner, and probably isn't any worse than smoking. Convection vaporization is a feeling which is subjectively distinct from smoking or the other sort of vaporization, and better in my humble opinion.
WARNINGS:
While commercial vaporizers use it, I don't believe that PVC is safe enough for this purpose. Don't use it. As you can see I I've read about leeching in medical products (while they were using specific chemicals), and also read that the PVC should not be heated over 180F which is not enough. Silicone tubing can be bought online. I use thin copper tubing.
Where I live smoking tobacco is restricted to people 18 and over. If your under 18 don't make this, don't smoke, or vaporize, or whatever. While vaporization may reduce the health hazards associated with inhaling plant material, I'm certain that it does not completely eliminate them. Don't smoke. It's addictive and bad for your health. Depending on what region or country you live in, it may be illegal to consume specific herbs. Make sure that the herbal blend you choose is legal in your region. This guide is not intended to assist in the illegal (And highly immoral) consumption of banned plant materials.
This vaporizer is a fire hazard. It's cheap and easy to make, but there's a trade off. This one cost me about $25. A similar commercial vaporizer would cost 150-250$.
You might consider buying one of those wall timers so that if you leave your vaporizer plugged in by accident it will only run as long as you set the timer for. This is a must if you plan on vaporizing any herbs which may induce forgetfulness. Don't start a fire!
Further I've been warned that copper fumes are vary dangerous. I don't think copper will fume at the temperatures I'm subjecting it to.
That said the consensus among many smokers is that the most sure healthiest thing to smoke out of is glass. If you find a good way to do this with glass, more power to you! For now my brass on glass design might be the best DIYers can hope for.
One more warning: Don't use a soldering iron that has come anywhere near solder. Solder is super poisonous nasty stuff. Just buy a new one. They are really not that expensive.
Step 1Materials.
Materials.
"A wall socket timer"
This is for the socket where you plug your vaporizer into. With the timer you set the timer for as long as you plan on using your vaporizer so that it shuts off automatically. If your at all forgetful this is a must. Some herbs have even been suggested to bring about forgetfulness. If you plan on vaporizing any such herbs the timer is must!
A (few) bottle(s).
I used a large 1.75 liter Gvori vodka bottle.Gvori is my favorite vodka, and their bottle is awesome. Other bottles should work, but you'll want to vary the end of the fitting that goes against the bottle (more on that later). This should be free. If you don't have a good bottle laying around someone near your probably does. Since breaking a bottle is a chaotic thing you will want to have back-up in the case your first doesn't work (it probably won't).
A soldering iron (at least 40 watts).
I used a generic radio shack one. It cost about 7$. A radio shack one is probably best since their design is so simple. Anything more complicated will only get in your way.
Thin copper tubing.
I used 1/4 inch. It's flexible, but don't bend it into too sharp of an angle or you will get a kink (they're almost impossible to get out).
A brass or copper fitting.
I used a copper fitting I picked out which allowed the copper tubing to barely slide through it on the narrow threaded end, that was big enough on the other end to make a good bowl and fit against the neck of the bottle. The one I bought from lowes is labled 3/8" flare X 3/8" FIP. I would suggest looking ahead in the instructions before you purchase any type of fitting for this project.
Two pairs of pliers, at least one of which is needle nose
A serrated knife or dremel for cutting through the plastic handle of the soldering iron.
A coat hanger.
A hammer.
A screen
The type bought at smoke-shops to go in the bottom of a pipe.
119 comments
1-40 of 119next »
May 23, 2010. 12:07 AMadamic_99 says:
 FYI, there's no need for the electrical tape. Glass is easily sanded to a smooth surface. This will make your "device" much less ghetto.
Feb 2, 2012. 8:17 AMfly_boy_bc says:
"Glass is easily sanded"......On what planet is the second hardest substance "easy to sand?"
Feb 6, 2012. 11:47 PMadamic_99 says:
On Earth. Try it.
Feb 17, 2012. 12:37 PMfly_boy_bc says:
Simply not true. I am a glassblower AND a laboratory optician. I grind glass all day long and it takes DIAMOND grit to do it and it has to be under hundreds of pounds of pressure. No way you can call it "easy to sand". Easy to SCRATCH sure but to actually remove a noticeable amount of material? That is beyond most peoples abilities/tools. You can GRIND glass on a grinder fairly easily because of the speed. Sanding implies a hand process. Very difficult.
Mar 18, 2012. 2:52 PMx3n0c1dal says:
ROFL, what kind of glassblower/laboratory optician has a name fly_boy_bc?
Mar 22, 2012. 12:00 PMfly_boy_bc says:
One who is a pilot.
May 7, 2012. 1:38 PMx3n0c1dal says:
Good point, but a juvenile pilot born before recorded time?
Feb 17, 2012. 1:15 PMadamic_99 says:
Ok jeez. I'm basing this on personal experience. I bought an 18" x 18" x 0.5" piece of glass that I had cut. The edges were super sharp. So I took regular sandpaper and sanded the edges and low and behold, it smoothed them out pretty easily.
Dec 19, 2011. 8:14 PMvov35 says:
Let me begin by complementing your build quality. superb, simple, effective.
That said, I'd like to figure out a way to get the bowl to stay in place on it's own, and perhaps mount the bottle vertically so convection will happen passively (rather than letting the heating coil burn out)
Ideas on making the bowl stay? I guess you could modify the cap, but it seems like a pain...
Aug 12, 2011. 12:10 AMhopslams and herbslams says:
nothing against your choice in adult beverages, but would a beer bottle work well too? specifacally a certain british brewer with an unreal oatmeal stout or maybe a french canadian brew that uses a 750 ml bottle. Or do you use clear bottles that you may see whats going on inside the machine part. or for that matter, any wine bottle
Oct 9, 2007. 8:21 AMbarni says:
I've been told this trick to cut bottles: 1) tightly tie a thick cord previously dipped in alcohol around the bottle 2) put the cord on fire 3) when the fire is over, plunge the bottle in a bucket of cold water. This results in a clean safe cut, with no chaos theory involved. ;)
Mar 15, 2011. 6:02 PMhoughchrst says:
I will have to try this and see if I am any good at it.
Sep 7, 2008. 1:00 PMmondaymonkey says:
hmmmmmm that sounds smart. I'm going to experiment with that. I sometimes wash my herbal water pipe (Y'all know what im talkin bout) with alcohol to clean it... sometimes I light the alcohol to see fireshows... but now that I think of it rapid cooling could break it)
Jun 13, 2009. 10:24 PMdaltondude says:
thats not a vape, a vape just heats up the thc crystals from the buds snd lets off vapor, thats what happends when you smoke, but u burn the plant, nit just the crystals
Mar 1, 2011. 12:13 AMLiquidLightning says:
No, a vape just heats up the entirety of any herb you use. Be it cannabis, tobbacco, or any other herb. Besides, the crystals (Resin glands) are not the only part of weed that has THC. Most of it is actually contained in the plant matter.
Feb 2, 2011. 7:17 AMFontella says:
Worked off of a bit of different build, Teh Vaporizer's, and made a few changes, namely, using a 1/2 inch copper pipe cap seated on the heating element into which the other (3/8 inch cap) could be placed and changed out easily. http://tehvaporizer.blogspot.com/
http://picasaweb.google.com/101644146320194799735/SnowmageddonVAPe?feat=directlink
Feb 24, 2010. 8:20 AMnevssons says:
 Cheap and easy vaporizer:
Jan 31, 2011. 4:55 PMshmack92 says:
Easy yes, cheap no. You'll be paying for it tenfold through your diminished health. Light bulb glass was never meant to be used to vaporize a consumable, and the toxic substances lining the bulb weren't either.
Aug 25, 2010. 12:49 PMnickd2582 says:
You should really check out this link it shows and easy and precise way to cut a glass bottle in half. http://www.youtube.com/watch?v=yViiVLlaQag&feature=related
Apr 1, 2009. 4:06 AMAcerRock says:
In keeping with the convection method, is it safe and effective to use a hair dryer instead of a soldering iron?
Jun 5, 2010. 11:30 AMstudent.mckinney says:
As far as effective, no, the hair dryer does not reach the temperatures necessary to vaporize most chemical that are in herbs (or in herb). However, if you were to open up the blowdryer and locate the cutoff sensor, (it is a bimetallic strip that turns off the heating element at approximately 140 degrees) then it would reach much higher temperatures. THC and similar cannaboids vaporize at around 200-220 degress Farenheit. The upside of a blowdryer is that you could lower the motor speed and have it fill a bag like the Volcano vaporizers. As far as safety, it would pose no great threat to your health, the element is made of nichrome which does not oxidize at high temperatures and doesn't produce harmful toxins to my knowledge. Good luck, I think I'll try this.
Jun 5, 2010. 11:42 AMstudent.mckinney says:
Scratch that part about removing the sensor, you would need to bypass it. A heat gun woul suffice, and require no modification, those are available at hardware stores at reasonable prices.
Jun 2, 2010. 11:20 AMgreymatter21 says:
smokin weed itsnt addictive its jest fun to do;D
Mar 29, 2010. 10:03 PMJ_M_Ped says:
One thing to keep in mind about the fittings is anything brass or copper it would be a great advantage to you to soak them in two parts vinegar and one part hydrogen peroxide to remove excess lead.
Mar 24, 2010. 7:27 PMJ_M_Ped says:
I was wondering, did you stick a different piece of wire inside the heater core, because it looks like you did.
Dec 25, 2009. 9:00 PMweaponscollector94 says:
back when i smoked the chronic i found for bongs or pipes that the best bowl can be made from an old co2 cartridge neck, i do not recommend smoking but you just take an empty co2 (make sure it is empty, then stick it in a vice cut it with a hacksaw so it is like a metal cone. btw i do not do any illegal stuff like that anymore. i just recommend that you stay clean everybody
Dec 6, 2009. 6:52 PMthefonz101 says:
Herbal mixtures FTW!
Oct 18, 2009. 6:39 PMdustwren says:
Cool...  my only concern is your use of copper.  Copper off gases some very nasty chemicals when heated.
Oct 18, 2009. 12:05 AMrebeljedi says:
since there's only so much air one can pull in through the tube, it would be best to also make sure that the fresh air passing through the element isn't excessive and just allow just enough air in at a time, takes the need to inhale slowly since there's only so much you want to stress your lungs on anyways.  Also, one could easily attach a temperature sensor to the midpoint between element and herb receptacle and just have a dimmer switch regulate the power to it.... then again the price jumps up about $50 if you don't have any of these already lying around. It's still a good hands on project, screw the pre-fabs!
May 3, 2007. 10:10 AMScurge says:
I was gonna build one this way, but I learned some things about vaporizors before i got the chance to get started.
Whatever chemical your trying to get to release from the plant material has a specific temprature at which it most efficently breaks free. Too high and you incenerate some of the chemicals and cause it to combust (really char) anyway making it no more efficent than just smoking it regulary, too low and it just smells good and no chemical has been released, so adjustable heat is optimal. you can just play with the settings, or look at the Wikipedia article on Vaporizers. they say it's around 365 degrees F. when you look at the Wiki entry, notice the picture on the top left of the entry, that one used heated air and the plant matter never touches any "hot plate" so there's no toxic byproduct by the heating element. i've used one of those heated air types before, theyre hands down the best and most efficent vaporizers, not to mention much more interesting to build than a hotplate type.. Drop me an email Vapoking, and i'll fill you in on the specifics of the construction methods i've concidered.
Jun 24, 2009. 6:08 PMpopmedic says:
Hey Scurge, great points, what about creating a heated air one with something like this: http://www.engadget.com/2006/03/07/how-to-make-a-surface-mount-soldering-iron/
Although vaps point on the diaphragm made me laugh.
May 3, 2007. 10:11 AMScurge says:
oops my bad, the pic of the air type vapo is on the top right..
Jun 24, 2009. 5:48 PMpopmedic says:
I found this little contraption to be a great way to adjust the heat. It is way cheap to build and easy to put a timer into! (always be safe)
http://www.afrotechmods.com/cheap/iron/iron.htm
May 1, 2007. 4:16 PMT3h_Muffinator says:
Illegal Drugs + Instructables..... I don't like so much..... Perhaps post this on a druggie forum, not on a website with an audience that consists of people of all ages...
Jun 24, 2009. 5:42 PMpopmedic says:
last I checked tobacco is legal while over the age of 18 in all the US, even younger in some countries, and I don't know what you read, but this thing is for smokin tobacco, and the author even cautions the read about the effects of smoking tobacco, jeez someone is a little too pc...
May 1, 2007. 8:07 PMtrebuchet03 says:
Illegal is a regional and usage thing ;) As s/he said... some herbs are illegal in some areas, and others aren't :p Tobacco, for instance, is legal almost everywhere (with restrictions).
May 2, 2007. 6:58 PMT3h_Muffinator says:
Regardless... no matter what one uses this to smoke, it's still a bad for one's body. Instructables shouldn't give kids cheap ways to kill themselves (via drugs or tobacco)
Jan 6, 2010. 10:14 PMmarkymaster1 says:
Marijuana has shown to have no adverse effects or side affects. no damage to lungs, brain or any other organs.
May 22, 2009. 12:02 PMridejb99 says:
A couple year late. Yet still maybe we should attack the beer brewing instructables too. Fire water bad.
1-40 of 119next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:vapoking
