Step 5Assembling your whip and bowl.
Your bottle needs to be cleaned to remove any glass particulate.
The copper tubing needs to be cleaned to remove any grease and/or copper dust.
The brass pipe fitting needs to be cleaned to remove any gunk on it.
Don't clean your heating core, doing so will probably destroy it.
you screen doesn't need to be cleaned because it should have been clean enough when you bought it.
Flange one side of your 1/4 copper tubing.
Do this by sticking a small enough pair of needle nose pliers in the end of the tube and twisting.
Take your brass fitting (mine's from lowes and its labeled 3/8' flare x 3/8' FIP), and slide it over the copper tubing from the not flanged end, down the copper tube, and to the other end of the copper tubing. Make sure the larger side faces outward. The flange should be big enough to not allow the brass fitting to slide completely past the flanged end of the tubing. Put your screen in the open end of the brass fitting. your plant material will go against the screen inside the large side of the brass fitting.
Pro tip: Is should be flanged as far out as will fit in your bowl. Since this is the vessel through which the air will pass, if it's too narrow your plant material will not vaporize evenly. It is not flanged enough in the picture.
4
comments
Add Comment
Add Comment
