loading
Picture of Whipped Cream Peanut Butter Pie
With fathers day coming up I decided to make a pie that is simple for children ,and others, to bake for their Dads Grandfathers etc.
Step 1: Ingredients and Equipment
Picture of Ingredients and Equipment
Ingredients:
Sugar-A few teaspoons for the cream
M&M's- A handful, optional but recommended
Whipping Cream- One tub, no canned whipping cream here
Peanut Butter- I used chunky but smooth would work too
Shortcrust Pastry or a Pie Crust- I have a block of premade shortcrust, homemade is optional
Butter- A small amount to grease the tin
Equipment:
A Knife- Any shape or size will do
A Palette Knife- Or anything to spread the peanut butter
A Whisk
A Mixing Bowl
A Pie Tin
A Spoon
A Rolling Pin
A Circular Object Bigger Than Your Pie Tin- To cut a circle to do the sides and base
A Piping Bag- Optional
Greaseproof Paper- Essential
Step 2: Making The Pie Base
Picture of Making The Pie Base
Preheat your oven to 180 Degrees Celsius.
Roll your pastry moderately thin and cut it into a circle using your circular object.
As you can see from the second picture of this step I greased the tin. Do not do this! Line it with greaseproof paper so it can be pulled out easier later.
Drape the circle of pastry over the tin then slowly press down on it all around to get all the air out from below it.
Trim the edges of the pastry off and bake until golden brown, as in picture 3.
If you would like a way to use the left over pastry go to the next step, if not skip it and go to the one after that.
Sounds delicious! I'm a huge fan of whipped cream!
loafers3 years ago
The existence of this recipe is dangerous to my sanity.. I WILL BE MAKING THIS! Sounds and looks amazing. might add a small layer or nutella on top of the peanut butter layer, but it's got a lot of flavour diversity already.. Whatever I do, I can't wait, thanks mate
The Science Guy (author)  loafers3 years ago
Thanks but I'll give you a tip. KEEP IT IN A SAFE. You will eat yourself to sickness otherwise. I learned that the hard yet extremely tasty way.
