Whistle rockets as the name describes are rockets which emit a very loud whistling sound as it shoots into the air. It contains a pressed pyrotechnic composition called whistle rocket mix. In comparison, the whistle rocket tube is usually about half the length of a similar diameter black powder rocket. No nozzle material is used in the construction of this rocket and it has a very short core making this device an end burner. When the rocket is lit, the composition around the core burns extremely fast, propelling the rocket into the air very quickly. The rocket then changes characteristics, and the material oscillates and the remaining half of the tube acts as a resonating cavity, essentially amplifying the whistle sound. During this process the burning composition still generates enough thrust to continue propelling the whistling rocket through the sky. (Pyroguide.com)
Here is an example of a whistle rocket with a 2" can shell attached to the top. tt stars on top with gold glitter on bottom
http://s90.photobucket.com/albums/k243/nateputt21/?action=view¤t=638b25ac.pbr
Remove these ads by
Signing UpStep 1Materials
-a 3/8 inch bolt (for this size it must be over 2 inches in length)
-loctite epoxy (im using 5 minute quick set)
-dremel tool
I think the lower end gets partially capped off with some sort of epoxy as well (with a hole to let the gases escape, of course).
This Instructable reminds me of part of the 5-cent sugar rocket manual.
the tube of course is longer then the bold so there is no hole left at the top
this gadget saves time - no need to drill a hole down centre if making bottle rockets and is used for larger rockets that are core proplelled not end burn
http://www.youtube.com/watch?v=rwNNyYSyrqY
