White-Noise RF Source (DC-200 MHz)
1,086
14
Posted
Introduction: White-Noise RF Source (DC-200 MHz)
In this tutorial we present an easy to build RF noise generator. Schematic, construction details as well as the measurement results are discussed here. Additional results from a Spice simulation are available on : http://kavea.free.fr
Step 1: Materials
  • 2 x BFR93A
  • 1 x 9V Zener diode (Panasonic DZ2409100L is used here)
  • 1 x 7812 voltage regulator
  • Prototype board
  • Couple of resistors and capacitors (see schematic)
  • Optional : 1 x SMA connector and 1 x Aluminium case
Step 2: Construction
Build the circuit using the electric schematic. For better RF performances and stability of the amplifier we recommend to use a full ground plane on the bottom side of the circuit board. In our case a copper tape is used for this purpose.
Step 3: Measurement
The amplifier was designed to have a 50 Ohm output impedance. In order to validate the noise source we can than connect it to a spectrum analyzer (SA). On the first picture, the noise floor of the SA is shown. The noise spectral density in this case is -135 dBm/Hz. When we turn on the noise source (second picture) the spectral density increased up to -105 dBm/Hz which represent an ENR (Excess Noise Ratio) of 69 dB.
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    Although this is significantly weaker it (Must be heard with an earpiece) it is a type of white noise generator from Elenco EP 130 in 1. FM range with amp Ops dual.
