3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
White Water Pouches
White Water Pouches
This duct tape water proof pouch is sealed by doubled zip-lock bags under a quick release snap. Webbing on the back side allows for attachment to your life vest. Window cleaner helps make it possible.
You’ll need:
Duct tape
Window cleaner
Scissors
Razor blade
Quick release snap
Reflective tape
Strait edge
Step 1Set up
Set up
Find two zip lock bags in the size you want to use. I used 1 quart bags. Cut the bottom off of one of the bags. Place the intact bag into the bottomless bag. Adjust the bags so the zip locks are one above the other. The zip lock of the intact bag should be on bottom. See the pictures.
Spray your flat surface with window cleaner. Place the doubled bags on the wet surface and spray that as well. The window cleaner will give you some freedom in placing the tape. Don’t worry it will dry without effecting the performance of the tape.
24 comments
Feb 20, 2012. 5:40 PMblack hole says:
I bow to thee, master of ductigami. =D
Aug 16, 2011. 9:54 AMzacharydl97 says:
I made one and it is awesome! Love taking it kayaking to hold my phone and other items. Instead of the clip I used Velcro as that is what I had avalible and it worked nicely! Thank you for the great idea!
Jul 9, 2011. 12:36 AMsunshiine says:
Still waiting to see if you won!
Jul 19, 2011. 4:39 PMsunshiine says:
You won! Congrats!
Jun 30, 2011. 10:41 PMnamrac says:
Great project! I'll definitely be making one or lots of these for canoe trips. Thanks for the detailed walk through.
Jun 19, 2011. 4:54 AMROOKIE49 says:
wow where did you get 8x11 duct tape?
Jun 21, 2011. 2:50 PMROOKIE49 says:
wHEN YOU ARE TAPING THE BACK SIDE ARE YOU MAKING THAT LONGER SO THAT IT FOLDS OVER THE FRONT? I can not tell from the pics and you do not mention that
Jun 4, 2011. 9:06 AMtaria says:
what if someone steals your vest? then your national treasure map will be gone then your lost...hahahaha
I do like this btw, might work for something else, can't think of what else at the moment.
Jun 15, 2011. 2:14 PMsiafulinux says:
I'm thinking of using this to make an inexpensive "webbing" tactical vest / leg bag of sorts. For my needs, I would add in some reflective strips too.
Jun 4, 2011. 4:47 AMmslaynie says:
Ok, how the heck did you learn that trick with the window cleaner? That is GENIUS!
Jun 15, 2011. 2:13 PMsiafulinux says:
...and window tinting.
Jun 6, 2011. 7:52 AMmslaynie says:
Ahhh, ok, that makes sense!! I've often wondered about those auto decals! It's always seemed like they would be super-easy to mess up, especially if you're as clumsy as I aml
Jun 15, 2011. 2:12 PMsiafulinux says:
NICELY done!!!
Jun 6, 2011. 9:37 AMehudwill says:
This is one of the best looking duct tape projects I have seen.
Jun 4, 2011. 1:50 PMRedneckEngineer says:
Now this is a cool idea! Makes me want to make this for some other type of application which if I ever find my camera I will make some things for camping. My youngest daughter and I are giong camping in a few weeks, might be just the thing to do on the downtime before bed. Can't believe I forgot about the windex trick. Once again thanks for the insperation Mrballeng!
Jun 4, 2011. 9:15 PMechodawg says:
Why not just fold the inner bag and tape it instead of cutting a perfectly good inner layer?
Jun 4, 2011. 10:00 AMlyonpridej says:
I love this! My 2 boys are Boy Scouts & this pouch would work GREAT for their canoe trips! Also, several of the boys in the troop love to make things with duct tape, so they'll love this too!
And thank you for reminding me about the window cleaner trick. I'd forgotten until I asked you about it, but now I remember that when they 1st came out with the tinted window film you could put on your car yourself (ages ago), we had to spray the window with window cleaner before applying the film, so we could place it right before it stuck permanantly. I'd totally forgotten about it & am so glad you reminded me, because I hadn't thought about using it with duct tape & a couple of months ago I bought a case of 8x11 sheets of duct tape for my boys to make things with - this tip will sure help!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
965
Author:Mrballeng(Visit my shop)
I've opened up shop =). Click "Vist my shop" to check it out. Or write me at info@mrballeng.com
