3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Carve a Staff / Walking Stick
In this Instructable, you will learn how to whittle a staff / walking stick out of a cut off branch. Just so you know, whittle means to carve, specifically wood carving. There is more than just stripping off the bark in this Instructable! This is the same method that Rick Wiebe, with 50 years of experience, taught me, so you can't say I did a bad job! Remember to rate if you liked this 'ible!
Step 1Tools Needed
Tools Needed
The only tools needed are:
  • Axe or Machete Knife (used to cut down branch)
  • Knife (specifically a locking one)
  • Dry Wall Spackle or Old Ice Skate (Optional)
112 comments
1-40 of 112next »
Apr 22, 2008. 4:55 AMHOMEPIE64 says:
I HAVE A PROBLEM!!!! i whitlleted my staff : yes I curved the bottom: yes pyrography :no staining: no HERE IS MY PROBLEM: on the first day of cutting down my small tree it was fine, i got rid of most of the green bark. Day 2 i got rid of the rest of the green bark and rounded the edge. It was dry and ready for use. TODAY, DAY 3 IT HAS MASSIVE CRACKS IN IT!!! WHY???? WAS IT BAD WOOD? DID I WHITTLE WRONG? WHAT WHENT WRONG?
Feb 16, 2009. 2:33 PMthepelton says:
Some woods are easy to cure, such as elm or Paulonia. Others, such as cherry need to be carefully run through the curing process, and even then much of the wood wil crack and crumble. I am assuming that you used some variety of wood that doesn't dry out easily. Taunton press put out a book on curing your own wood.
Mar 23, 2009. 9:15 AMzzoe says:
I will add that, for example, having made a lot of staves, when i had less experience, i attempted to make a staff out of hornbeam (Carpinus Caroliniana), a wonderful wood - i seasoned it, bark on for four months, then went to work, roughed it out and de-barked it. The next day, it had so many cracks, it looked a bit like rope. Unbelievable, i've never seen anything like it. Later, i made one from a piece that had seasoned for two years. I still have it - it is so durable, that when i accidentally shut it in a car's door, the door sustained a good deal more damage than did the staff. The type and age of the wood make a BIG difference. I usually look for 'dead standing' saplings in overgrown forest - they' already partially seasoned, they often are straight and grew slowly (they were struggling to reach the light), and i can tap them to see if they're solid. After cutting, and indeed after finishing, a good staff should have a ringing tone, if you hold it at the right place,and tap it. Also, i would recommend learning to use a drawknife and a spokeshave.
Mar 24, 2009. 10:37 AMthepelton says:
I live in Colorado Springs, which is over 6000 feet in altitude with winters that get below zero, and less than twenty inches of rainfall on the average. Recently, we have had a decade of drought, so the rainfall average may have to be recalculated down. The most common standing deadwood saplings here are either lodgepole pine or aspen. I have made a staff from aspen. I wish I could get some other varieties, like hornbeam or persimmon. I wonder if it would be possible to trade?
Sep 12, 2011. 1:14 PMroldroyd says:
Hi this is an errand of mercy - I have begun collecting wood from the local forest and want to whittle my own staves. The wood is a mixture of Pine and I have let the limbs stand for a number of weeks. My question is when can I begin carving and one I particularly love is really heavy (too heavy for me to comfortably use.) Will I be able to whittle this down and what would be the best technique. Thank you
Dec 4, 2011. 3:30 PMmaddog52 says:
depends how good with tools you are,a rasp or file works well,knives need to be really sharp and sharpened often.moisture escapes from the end grain so use wood glue to seal it.you can whittle it down fairly soon after you collected it,but as you work on the wood you set up stresses in the structure so leave it outside so it doesnt dry too quick,or if you arent rushing seal the cuts with glue as well.and the advantage with working green timber is its a lot easier to cut than seasoned wood.or just do what i do and have loads of blanks to work on.
Sep 12, 2011. 4:09 PMl8nite says:
Im not sure how or why I got this in email (I look forward to hearing more comments or guidance about making my walking staff. I have collected the wood from a local forest and left it to stand for a few weeks. I guess I have to bite the bullet and just have a go but I am not sure I want the sadness of find that this beautiful is cracking. I there no way I can protect the wood ? ) I only do occasional carving so Im not all that knowledgeable, I do know you need to let the wood season for more than a couple weeks, a year would be better, some pieces crack no matter what you do, as long as it isn't to bad, I try to incorporate it into the carving. One of the best materials for almost instant staves/walking sticks/staffs would be replacement handles for shovels and rakes, they are usually made of ash or other hardwood and are a good height, they can be difficult to carve by hand but a dremel or other rotary tool minimizes that problem
Sep 14, 2011. 7:09 AMroldroyd says:
I do apologize, I am over enthusiastic, being new to this and having read some of your previous comments about making ones stave. I am afraid I thought go to the source and have bombarded people asking for help. My thoughts were really is there no way to keep moisture in the wood after I have removed the bark. I guess not and I need to see what will happen having already found out it hurts when the chisel slips. Thank you for responding
Dec 5, 2011. 9:09 AMthepelton says:
A good rule of thumb for green wood is to cut it and set it aside for one year for every inch of thickness.
Sep 14, 2011. 9:58 AMl8nite says:
Stripping the bark before the piece is dry is a common mistake but it IS a lot easier then. I hadn't thought about it before but perhaps if you set up a type of kiln to dry the wood faster like lumber yards do... it wouldn't be overly difficult, a piece of large diameter plastic pipe with a hairdryer at one end might even work. Im sure a commercial dryer gets a LOT hotter but for 1 or 2 pieces... might be a good experiment...
Feb 12, 2010. 9:54 AMwhiteoakart says:
email me directly from my Instructables home page.  I often trade wood blanks with others.  I have hornbeam, black cherry (lots of that), many varieties of oak, maples, hickory, sassafras, elm,  some juniper (eastern red cedar, much stronger than true cedar), prickly ash, sumac, and I can maybe get some Osage orange, but that is difficult to find in lengths suitable for a staff around here.
Apr 20, 2009. 10:08 AMkrististanton says:
I cut off a piece of maple from the north carolina mountains. Can it be used for carving? It had a vine growing in it and made a nice spiral shape. We also have lots of persimmon trees but the wood is fresh?
Dec 17, 2009. 2:54 PMphilslizzy says:
the maple sounds cool. We call it a twistie - very desirable and rare. If it's not too late I suggest drying it out carefully and slowly for months in the shed/barn/outhouse for the first couple then i a fairly cool dry area indoors later- with the bark on!  Taking the bark off when it's fresh will cause it to split. good luck
Apr 20, 2009. 1:29 PMzzoe says:
Carving would most likely be fine, but if you mean for a walking stick, that depends upon what the diameter of the wood is - minus the bark. As for the persimmon, i've never worked it before, though i've seen things done in it, often beautifully. Given it's hardness and close relation to ebony, i suspect one WOULDN"T want to work it green (that is 'fresh'), but if you have lots to spare, there'd be no harm in a little experimentation. Good luck!
May 19, 2009. 5:40 PMgilleseg says:
you sound like you have made your fair share of staves. You wouldn't bt any chance sell them would you. I am in the beginning stages of making my first staff/hiking stick and am a little worried I will mess it up and not have a proper stick in time for a hike I am taking. If you were willing to sell one let me know. Also a quick question can you make a staff out of Iron wood?
May 20, 2009. 4:36 AMzzoe says:
Fear not, it's not a pipe organ you're making. Trust yourself, and if you screw it up, make another. As far as having it ready for a hike, well, most places i've hiked, there's a fair chance of finding a decent stick trailside (don't cut down anything living if you can avoid it) - you don't need anything fancy, just sound wood, appropriate weight, and a knife to trim off twigs and shape the ends. That being so easy, don't rush the one you're making to get it ready in time. I do occasionally sell staves, but its like a good hat - do you really want to by one you haven't tried on? Also, shipping could be an issue. Where, in the world are you (area, not address)? The question of location also affects your question about ironwood. There are several (many?) species worldwide that are locally called 'ironwood', so that depends upon where you are. Where i am ( Catskill mountains, U.S.A.), 'ironwood' can refer to two different species: American Hornbeam - carpinus caroliniana, & Hop hornbeam - ostrya virginiana. They take a while - a LONG while to season, but i have a couple of staves made from these, both unsurprisingly very hard woods, given the name. I bit heavy, but sturdy - i once shut one accidentally in a car door, and the door was dented, the staff was, as far as i can tell, unscratched. For more information on these matters, read thoroughly this list of posts, others and mine, for there's a lot of good information here, from several people who, to borrow your phrase, have made their fair share of staves. Thanks for asking, and let me know which ironwood we're talking about, and perhaps i'll have a useful tip (or then again, perhaps not) Cheers, and good luck.
May 21, 2009. 3:11 PMthepelton says:
"Ironwood" is a generic term applied to any very hard wood from Persimmon to Hornbeam to Manzanita to Lignum Vitae.
Mar 24, 2009. 6:39 PMzzoe says:
I grew up in Colorado (Boulder, Denver, Evergreen, &c.) . You' re right about the aspen, not bad wood, a bit soft and it rots easily. Could work if you cut one live and season it. Nice thing about aspen - your not killing the whole organism when you do. You might try spruce. Avoid cottonwood. In sheltered valleys you might get lucky and find chokecherry, maple ( and remember box-elder is a maple - though not a really hard one - and can produce the occasional pretty good staff ), birch, and feral crabapple and plum - from which i have made some of my favorite staves. I am also open to trade. Viva barter!
Dec 5, 2011. 9:12 AMthepelton says:
I recently made a woodturning out of a piece of box-elder with red in it. It smelled a bit musty while I turned it, but it finished beautifully.
Dec 6, 2011. 6:14 PMzzoe says:
Cool! Haven't tried it yet, but being a maple, it can't be all bad, though some think it weedy. Recently found out that box-elder can be tapped for sap (to make syrup) and apparently the taste is good... but i wonder where one would ever find box-elder big enough (or old enough) to tap.
Have you done any staves with turned handles or knobs? I've been toying with the idea.
Keep up the good work,
-Z.
Dec 7, 2011. 11:30 AMthepelton says:
I have not yet turned a stave, but I have made some out of standing deadwood aspen. I plan to turn a stave very soon, and would like to put a knob on the end. Recently, I was turning a series of magic wands for www.merlinsrealm.com.
Mar 25, 2009. 10:35 AMthepelton says:
I have seen plum and feral crabapple around the area. The problem with them is that they, like cherry, are difficult to cure properly from what the Taunton book says. I may just have to read up on them, and try anyway, preparing several at a time just to make sure that I can get at least one workable one out of the deal. As for trade, I love the idea!
Jun 18, 2008. 11:11 AMSurvivorman says:
(removed by author or community request)
Mar 24, 2009. 6:40 PMzzoe says:
I would add that it is best to season wood for staves (&c.) FAR longer than you think initially is necessary. (4weeks = > 4months).
Feb 16, 2009. 2:36 PMthepelton says:
In the Taunton book on harvesting your own woods, they suggest setting wood aside to dry for a year per inch of thickness. I suggest you look that book up.
Mar 24, 2009. 6:42 PMzzoe says:
Ditto.
Oct 12, 2008. 7:01 PMThelonelysandwitch says:
My little bro. goes to scout camp all the time, so I do it my way= First I break a branch off of the tree, next I cut off the leaves sticking out, then i debark the handle, sharpen the bottom and go. If i have a chance I cook it over a fire for 5 min.
Jun 18, 2008. 1:54 PMHOMEPIE64 says:
that could be it but the other one i made came out perfect, but it was a fresh cut tree trunk
Jan 18, 2009. 12:38 PMfoxtrot4697 says:
i used a tree trunk exept i forgot what kind
Jun 18, 2008. 8:30 PMRishnai says:
So one was fine, and the other cracked massively? Welcome to the world of wood, my friend. Wood cracks as it shrinks, and it shrinks as it dries. If you don't let it dry too fast, you will reduce the chances of it cracking. So don't try and speed up the process by leaving it someplace hot, and if it is consistently low humidity where you live, age it inside. Or outside if it's usually dryer in your house than outside. You can never eliminate the chance of it cracking, though, and you can't pick by eye which ones will crack and which won't. You just have to let them age, then use the uncracked ones (or cut around cracks and work them into your design--I've done that a few times).
Mar 24, 2009. 6:56 PMzzoe says:
You can improve your odds, however... Pick dead-standing saplings, if you can, in a dry spell in early spring, after Winter's dried out the wood. If not, try to harvest in the Winter, when the sap is down. After cutting, paint the ends of the lengths you've cut with wax, tree paint, or some other not-too-penetrating sealant. (this allows the wood to lose it's moisture gradually through the bark, which will help prevent checking (splitting that runs from the ends). LET IT DRY A LONG WHILE... a year or more, if you can. Be patient. Finally, remember (unrelatedly, sort-of) hardwoods are not always hard & softwoods are not always soft. Learn the traditional uses of your local woods - a staff should be hard, but also have a certain 'spring' to it, so look for woods that indicate those traits, along with the density ( 'weight-feel') you want.
Mar 28, 2009. 3:46 PMRishnai says:
Good advice. I've made several walking sticks out of dead-standing aspens from my yard, and have had no trouble with any of them. It's the ones I make from trimmed maple that sometimes crack like mad. As for painting the ends, I never thought of that. 'Tis the season to cut wood, though, so I suppose I'll get the chance.
Dec 17, 2009. 2:57 PMphilslizzy says:
The only problem with dead wood found outside is the chance of woodworm. They could be killed with treatment but the holes will make the wood very brittle. I have discovered to my discomfort!
Dec 5, 2011. 9:16 AMthepelton says:
There are a host of creepy crawlies that can infest dieing and dead wood, such as termites, longhorn beetles, and a tiny pine beetle that has devastated a lot of the lodgepoles recently in Colorado and Wyoming. If the piece will fit, you can microwave it.
May 21, 2009. 3:19 PMthepelton says:
If you know that the wood was elm or paulownia, that can work in your favor. Elm has football shaped leaves with sawtooth edges, about 2 inches (5cm) long. Paulownia has immense leaves, and showy flowers like foxglove. Google it for a good picture if you live near the Potomac, where it was accidentally introduced.
Mar 24, 2009. 10:43 AMthepelton says:
Woodcraft.com has some nice fillers in decorative colors if you want to try and use a staff with a cracked surface.
May 4, 2008. 4:36 PMhenrywfstone says:
the only reason i can think of this happening is if you left it near a radiator or something pretty hot like a fire. this would dry out the outside side of the shaft too quickly making it contract and crack like soil in really hot countries but the inside wouldn't dry out as quickly. the answer to this is don't leave it so near a radiator. theres no way to fix this once its cracked. just start over with another branch unfortunately. hope this answers your question
May 5, 2008. 1:01 PMHOMEPIE64 says:
idk what happened
May 4, 2008. 4:40 PMhenrywfstone says:
1-40 of 112next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
76
Author:Arbitror(Check out my blog!)
One of my favorite hobbies is dismantling electronics, then either combining them together to create something new, or adding components to make them better. I also like gadgets, whether it's taking t...
more »
