Step 4Learn to Whittle
iImage Information
In this step you will have to learn how to whittle.
First, make sure your knife is sharp. If it isn't, sharpen it. Slide your knife along the bark, giving it some pressure. The bark should peel off in a strip, like in the picture. Try not to cut unevenly like in the second, third, and fourth picture. It causes you more work and stress. Cut evenly and cleanly, like in the fifth, sixth, and seventh picture. Don't work on making it perfect, all you have to do is remove the outer and green bark. Don't worry about the inner bark because it is removed in a different process. When you get to a knot, cut the bark on the left side from the left, and the bark on the right side by the right, so that it appears smooth.
