3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Building a (mostly) self-contained condensate recycler.
Here in Tucson, AZ, air conditioning is so vital that if you're renting, your landlord has to provide it by law. The relief is almost worth the high electric bills that come in the summer months, but one thing has always bugged me.
If you have a cooler, whether it's a compressor/condenser style or an evaporative, or swamp cooler, there is always going to be some waste water involved. During the 100+ season, this is especially true, and it can create problems like unwanted weed growth around your machine and possibly damage to your foundation. In addition, the tap water here is piped in from remote locations and it's finite. Waste is dumb when you can prevent it easily, so I looked around for materials to create a solution.
Step 1Gathering the parts
Gathering the parts
I took a peek around the garage, and noticed I had what I needed. Your mileage may vary, of course. Scouring secondhand shops, yard sales, and classifieds should yield the parts without too much trouble.
I didn't take photos of the assembly process, because to be honest I was winging it and wasn't sure it would work. Here instead is a shot with the parts explained.
You'll need:
1. An aquarium or reptile tank. Mine's about 10 gallons. I picked one with a screen top to prevent mosquito breeding. You could probably adapt the design to a hooded tank, though.
2. A low volume fountain pump. This one still has the fountain attached, but you could hook tubing to a bare one and install it in any kind of fixure you could think of. If you are just using an aquarium, you might be able to use the existing filter system and hack it to add an output.
3. Heavy duty duct tape.
4. Access to a file or rotary tool.
5. An outdoor source of electricity.
64 comments
1-40 of 64next »
Nov 29, 2011. 4:17 PMRustyRoller says:
All these comments were very interesting to me. Two years ago, I decided to add a piece of PVC pipe to the end of my AC condensate drain pipe, so that the water would travel further from foundation. Then, to shade AC from Florida sun, decided to plant what gets called Mexican sunflower around here ... had collected the seeds from dried flowers the prior fall.
Figured the condensate water would keep it well irrigated without me needing to think about it at all (I run my AC almost year-round, as I'm heat and humidity sensitive). I've had to cut the shrub back several times, as it grows and flowers up a storm ... last time, it got higher than roof before I fully realized it, and then a bad wind and thunder storm half-uprooted the plant.
So, I cut it all back to a few feet high, added some soil around the base, and ignored it. Several months later, the thing is thriving, in bloom yet again, and will need trimming by spring. The only direct water is from the AC condensate line (and occasional rain).
But would I even think of using this water for anything else? Not a chance!
Apr 12, 2011. 1:13 PMphillipt says:
I've seen some comments here and on other posts about Legionnaires' disease and thought I could contribute some information from a little, basic research.
Foremost, I don't pretend to be otherwise knowledgable about this topic except for the few hours I have spent reading Wikipedia articles, the CDC page about Legionella bacteria, and some other general internet searching. But, I think the info I have found can be helpful.
Wikipedia: Legionellosis
Wikipedia: Legionella pneumophila
CDC: Patient Facts, Legionella
Simple Facts
1) Legionella bacteria are (a) aquatic and (b) aerobic. So, they mostly form in water and can grow anywhere there is oxygen: water and air, for example.
2) Following that, infection occurs from breathing in the bacteria from a vapor or mist. Evaporated water from contaminated sources is the concern here, hence the issue about condensate from an HVAC system.
3) Most people exposed to Legionella are not infected. But if you do come down with an infection, it is serious and can be fatal. The symptoms are very much like that of pneumonia.
4) The bacteria are not spread from one person to another.
5) Legionella can also be found in amoebae in soil, compost, and potting mixes.
__________________________
I think it's common sense that we are talking about two possible ways of Legionella being a problem in your garden. On one hand, we worry about it getting into the produce. On the other, as the above facts point out, we should also worry about the water, and the air around the water, that we are using from the HVAC system.
To address the first case, take a look at the range of temperatures affecting Legionella; this is available in the Wikipedia article. Compare these to common cooking temperatures.
If you are pairing veggies with meat, you will likely kill any bacteria including Legionella pneumophila. If you are steaming veggies, you almost certainly kill them considering it takes 212-F or 100-C to boil water; I'd assume the residual steam is similarly hot, though I don't actually know. Along the same line, if you are making soup or otherwise boiling the veggies for even just a few minutes, you will definitely kill the bacteria. I can't recall a soup recipe that doesn't call for bringing it to a boil and then simmering for at least 30 minutes. Anything above 151-F or 66-C will kill the bacteria within minutes. And 70-C or 158-F would lead to absolute disinfection.
On that note, though, I'm not real sure that plants would even sustain the bacteria. There was no mention of such instances in anything I read, which was much more than the above cited pages to be clear. Being aquatic, the bacteria "live" in water; being aerobic, they grow where there is oxygen. Aside from being "infected," the plant could not otherwise play the part of a reservoir or host for the bacteria.
Furthermore, I don't believe that the plants become "infected" as one of the most common hosts for Legionella pneumophila is an amoeba found in soil: Acanthamoeba castellanii. That's right, soil! In fact, it's possible that the bacteria are in soil, compost, and even potting mixes and can be kicked up into the air with dust, where you can breathe in the bacteria. We all garden with much of this, so I figure (1) the CDC must be correct when they say most people that are exposed are not infected and (2) it sure doesn't seem to be affecting plants.
The only concern that I can see remaining is with regards to the vapors from this possibly contaminated water as it evaporates from your garden, as opposed to being taken up by the plants.
FACT: this water, before being used for irrigation, is already being evaporated into the air around you -- the HVAC condensate outlet is already disposing of the water. Some seeps into soil (is it affecting your grass?) and some will no doubt evaporate (is that affecting you?)
Legionella have been shown to have an effect in communities and up to several miles away. If you don't already have an outbreak in your area, and I'm sure you would know about it, then it's probably just as safe to let that water evaporate from your garden as it is to let it evaporate from the ground around the condensate outlet.
Recap
It's not likely in your produce, but if you think it is, common sense guidelines for preparing food should take care of that.
It's not likely a problem evaporating from the water source because if it were, you wouldn't be reading this; you'd already be in the hospital with Legionellosis.
If an outbreak of Legionellosis should occur in your area, then go to back to plain old manual watering until all seems well again. Otherwise, I'm sure it's fine. I feel compelled here to reiterate that I'm no expert.
Aug 25, 2008. 12:56 PMbiochemtronics says:
Interesting Instructable! I have a question. Could the water be recycled by using it to help cool the smaller and hotter of the two freon lines that run between the condenser and evaporator? A container similar to a small gutter could be put around a short length of the pipe and the condensate water could drain into that container. The pipe is very hot and would surely completely evaporate the water in the container quite easily. My house has a crawl space where these pipes run so a container up to around 8 or 10 feet would be no problem at all to install. Even a piece of split PVC pipe could be used. The condenser water could help cool the pipe and the freon it is carrying thereby increasing the effeciency of the AC unit. Even a little cooling could help save some money.
Aug 30, 2008. 10:14 AMgodfish says:
I've been an UA, Local 250 Union HVAC&R Service technician for 20 years, and you are right that it would make scene to cool the hotter line coming from the condenser outside, however Air conditioning systems work on the Pressure Temperature relationship, Cooling the hotter line is called sub-cooling and does make a systems effeciency go up, WAY WAY up. and if you whir to over cool the line too much your indoor coil would make only ICE, blocking the air flow and costing you lots of money in loss of effeciency. SO if we throw the T&P out of whack by over cooling the line, OR like I've seen many times on residential calls people hook up water hoses to spray water on the condenser outside, all that happens is you cost your self more money on your electric bill. The best thing to do is have your A/C unit serviced by an honest company, change your filter when you should and keep the whole system clean, that will save you the most money. Or better yet just turn it off, A/C is a luxury and not a necessity. And YES I work in PALM SPRINGS So Cal, where it gets 121 in the summer, if I can work out in the heat, you can sit in your home without A/C. ;P
Jul 21, 2010. 8:33 AMBlofish says:
godfish thanks for the info! I was just getting ready to mist my condenser with rain barrel water....
Aug 30, 2008. 10:58 AMbiochemtronics says:
godfish: Thanks for the information. I suppose it would be nearly impossible to determine if the 5 to 10 gallons of condensate water would cool the hot tubing too much so I guess this idea could help but is not very practical since the effect could over do it and actually cause problems. However, I am surprised by the fact that cooling the outdoor unit with a water hose can cause the indoor unit to freeze up, but I guess it does make sense now that you mention it. One more thing - I have to disagree with you on AC not being necessary. I know there was a time not to long ago when nobody had AC but as for me - I could not live here in South Texas without it. LOL No, seriously - considering how many seniors die every year from the extreme heat, I would think it safe to say that AC can even prolong some people's lives. I plan to make it well beyond 100 with the help of AC. I want to thank you again you for your professional opinion. That is the nice thing about this site. We backyard do-it-ourselfers can get advice and help from experienced professional like yourself. Thank you for taking the time to help us out. It is greatly appreciated.
Aug 28, 2008. 1:15 AMthermoelectric says:
I'm not that good with HVAC vut i used to work with a guy that installs them, If you have a look at the outdoor unit, if the connections are condensing water, it would just be a waste but if your refrigerator has the wire on the back, you could have the water move through pipes over them because fridges get colder, use more power and put off more heat. Hope that helps, if u need to know anything else just ask
Aug 28, 2008. 7:56 AMbiochemtronics says:
If both of the connections on the outdoor unit are condensing water then the unit is probably low on freon and needs to be recharged. On a properly working unit the one of the pipes is cold and the other is very hot. I am suggesting using the water from the indoor unit to cool the one hot pipe running to the outdoor unit. Also, trying to water cool a refrigerator with coils on the back or underneath would require major modifications including elaborate drip pans, splash shields, and in most situations, a pump to get the water to it. This doesn't take into account the extra humidity such a setup would put into the room. I really do not think that would be very practical or efficient. And as for a refrigerator using more power than an central AC unit - there is no way. Refrigerators run on a 120 volt, 15 or 20 amp circuits. Central air conditioners run on 240 volt 30 amp circuits. Also an average size AC unit gives off around 4,000 to 6,000 BTUs of heat whereas a refrigerator only gives off a couple hundred BTUs at most.
Jul 11, 2010. 8:42 PMTogetherinParis says:
You can cut the bottom off a 2 liter coke bottle and screw it to an old hose to funnel condensate pipe drippings through the hose under your lawn's grass to your fruit trees. Dirt just loves bacteria that gets into the water along the way. The trees (or plants) keep their fruit sterile on the inside--that's why you should cut and eat fresh fruit if you change climates to avoid Montezuma's revenge. Rain is condensation, too. Of course, if you sprinkle the condensate water on the fruit itself (instead of just irrigating the roots as I do) you might be asking for trouble. The beauty of air conditioner condensation irrigation is that your garden gets more irrigation when the weather gets warmer. I just left the cut hose end in a depression under my tangerine tree and covered it over with some compost to keep it from evaporating away. Wow, I've never seen such a crop of fruit like we're going to have this winter! No pumps, just gravity flow, and it does the job spectacularly.
Jun 10, 2009. 8:58 AMMadrias357 says:
Well, the water's good for washing a car. First: It's free water. Second: your car won't care what it's washed in. Third: It's FREE water. Thereby, logic states it's good for washing cars, clearing a sidewalk of dirt and debris by means of pressure washer, watering small decorative plants and trees, and generally contributing back to the environment by returning the water you pulled from the air. It's also good for hurling 1/2 a gallon at the neighbor's house window when they're sitting there with the boom box and blasting horrible music way too loud. You're not really wasting it.
Jul 7, 2010. 3:34 PMspa31rky says:
I am not sure washing a CAR with such water is a very good idea. That water will contain contaminants that will "fog" the clear coat of the paint. Being a former Auto Detail-er myself I was very careful as to what water was used on any vehicle to prevent damage to the clear coat, or what used to be called PolyGlycoat. I used Teflon as a finishing product that would repel water and any contaminants and keep the clear coat like new.
Jul 7, 2010. 7:20 PMMadrias357 says:
Considering the car I drive has peeling clearcoat, I figured I'd pass on my mention of what one can use free water for. I drive an old 88 Ford Taurus. I don't mind the clearcoat peeling.
Jul 7, 2010. 7:53 PMspa31rky says:
Gotcha!
Sep 12, 2009. 12:42 PMtreesneedtobehugged says:
On the discovery show The Colony and you can see the video online from the website that they made a ozone machine that cleaned there water which came from the Los Angles river!
Jul 31, 2009. 11:24 AMjwaterfallguy says:
Really cool, creative way to harvest water. I had no idea that Tuscon actually required ac by law! That's intense! Check out our rainwater harvesting community: water harvest online. We would love to have you!
Jun 3, 2009. 1:33 PMdripwater says:
Check out the website:www.airigator.com. This might be of interest and assistance.
Apr 19, 2009. 7:55 AMThe Dark Ninja says:
Ever thought about taking some of your water to a treatment plant of some sort to have them test it for drinkability? And you could also build a solar purifier to filter out the nasty stuff if you're really worried about it. Chances are you could even build it out of your existing setup with almost no major changes.
Apr 13, 2009. 10:03 PMsplatman says:
I'm not sure how water sitting in a clear container in the sun be able to harbor bacteria. Non-bio contaminants, maybe. Google SODIS. As for the condensate pipe, finding a way to keep it completely full of water, so no air gets inside, may be able to keep it from getting funky. Try that by putting a U-bend at the end of the pipe that ends upward, followed by upside-down U-bend (or just a spout) to carry the water to the terminus w/o wetting the outside of the pipe. Sort of like a siphon. Use clear tubing for the U-bends. One possible way of sanitizing the con-pipe, is to run H2O2 thru it. Give it a Splat!
Sep 30, 2008. 3:24 PMbladework says:
have you thought about a solar panel(small one from craft proj.) to run your pump? why pay for the elect.
Sep 12, 2008. 6:41 PMvger13 says:
think i am beating a dead horse but...other than Legionnaires disease the water is just plain nasty,i wouldnt use it for anything i have been in hvac for going on 30 years and if you could see what comes out of a line when blown out you wouldnt even want it draining in your yard BEWARE of condensate
Sep 27, 2008. 5:41 AMnetbuddy says:
Theirs all sorts of nasty bugs in condensate water. This has come from hot moist air that is ideal for transmitting disease and when that moist warm air is cooled... it concentrates what was air borne into a liquid. Very grim, anyone who works with fridges, freezer units in places like supermarkets... then they will tell you of the true horror of the fridge. These devices keep stuff cool but they also are a major bio hazard.
Sep 7, 2008. 1:57 PMhandydave937 says:
Good Idea man, Here is another water saving tip, when I change my dogs water I use the stale water in the bowl to water all my house plants so no water goes down the drain.
Sep 4, 2008. 3:29 PMbrettddglas says:
If the condensate is coming from an A/C unit, this water is coming from the air just like when you sit a cold can or bottle out on a hot day the condensate drips off it. It is as pure as the air it came from so... but we use it all the time to water plants etc... with no problems. If it is a swamp cooler, there should be no concensate. water drips on a pad and when the water is low it adds more water with a float valve. There is no condensate line.
Aug 31, 2008. 9:07 PMuknative says:
The water coming out of the condensate line from your ac unit has a very low PH, this is not safe to drink. It could also have some affect on your plants over a period of time. If you do use this water on your plants, you may want to test the soil every few weeks and use a balancing agent.
Aug 28, 2008. 7:31 AMchuckr44 says:
I use my AC water to water my garden. I collect it in a 5g bucket. If my AC runs for 8 hours in a row I'll collect about 3 gallons of water, and that's for a small 800 sq ft house.
Aug 24, 2008. 10:10 AMusername says:
Just an FYI You should be able to purchase a condensate pump for under $100. I just bought one to use during a renovation (had to move condensate line). Purchased from Baker Distributing along with 100' 3/8" tubing for ~$50 2 wks ago. Up to 17' of vertical lift. Try your local A/C parts distributors or commercial supply houses.
Aug 23, 2008. 11:00 PMRishnai says:
I also don't trust that pipe. You could boil and distill your water eaily enough and make it potable. Seeing as you're in Arizona, a solar still sounds particularly easy and promising. Boil first to ensure that any bacterial nasties are dead.
Aug 26, 2008. 5:33 AMiceni says:
You may want to look into the link between Legionnaires disease and air conditioning.
Aug 27, 2008. 2:24 PMthoxbui says:
Would a solar powered UV light (with, you know, the UV LEDs) kill the little nasties? You can pickup a 51 LEDs flashlight from ebay for about 10 bucks.
Aug 27, 2008. 1:03 PMdirtdoc says:
Yes the water is technically distilled but the surface on which the water condenses is a nice bacteria farm and contains heavy metal contaminants such as lead, copper, aluminium, cadmium etc. The contact time of the water is such that the contaminants can be dissolved into or adsorbed onto the water molecules. Water analysis for metals and bacteria would cost about $300 dollars per sample from a commercial lab. Your county or state water well laboratory can probably do it cheaper. I would stick to watering only noncontact vegetation. Also a float switch (apprx. $20 at Lowes) can be plugged into any fountain pump with a standard wall plug. I put a bucket under my unit [hee, hee, I got to say Unit;)]with a fountain pump and float switch to provide water to several new planted trees in my yard 2 years ago.
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:skincage
i'm a noisician, information addict, and all around weirdo, and i'm gradually becoming proud of it.
