Wi-Fi Jammer Using ESP8266-01?
2,018
35
4
Posted
Introduction: Wi-Fi Jammer Using ESP8266-01?
Wi-Fi Jammer using ESP8266-01? Is that possible? Well... YES, It is. If you can't afford a NodeMCU ESP8266 or you simply don't want to buy one, just follow this tutorial!
Note: THIS IS NOT A TOY! IT IS CONSIDERED ILLEGAL. Do not use it to hack wifis. This is for educational purposes ONLY!
Step 1: Connect Your FTDI With Your ESP8266
Connect your FTDI with your ESP8266-01 using this diagram:
ESP8266-01 -> FTDI
RX -> TX
TX -> RX
VCC -> VCC
CP_PD -> VCC
GND -> GND
Also DONT FORGET to connect GPIO0 to GND ONLY WHILE PROGRAMING!!!
ESP8266 use a logic level of 3.3 Volts for communicating. If your FTDI Chips can switch to 5v-3.3v select the 3.3v.
Step 2: Flashing the ESP8266
Go to https://github.com/spacehuhn/esp8266_deauther/rel... and download esp8266_deauther_4mb.bin or any other version you want (must be .bin). Then you have to flash it to the ESP8266 board using a flash program (I used ESP8266_Flasher. Link to it here).
How to Flash the ESP8266?
- Open the esp8266_flasher.exe
- Click on bin
- Find the .bin file that you download in the previous step.
- Select the port where the FTDI Chip is connected at
- Click on "Download"
NOTE: GPIO0 MUST BE CONNECTED AT GND WHILE DOING THIS STEP! DONT FORGET IT!!
At 99% or 100%, you will get an error. Ignore it. Your bin file was successfully uploaded to the ESP8266.
Step 3: How to Use It?
After you upload the bin file, your device is ready to be used!
For more info and how to use it go to this link:
https://github.com/spacehuhn/esp8266_deauther#how-...
You can also do the same using the Arduino IDE. I can help you if you want to see how to upload the program using an Arduino board (any type) and Arduino IDE.
Hope this tutorial helps you. Have fun!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
Flashed no problem. Logged into the network no problem Then nothing happens when I try to browse to 198.164.4.1
3 Comments
Hi, if we want to upload it through arduino, what steps whould we follow?
You can find additional information here:
https://github.com/spacehuhn/esp8266_deauther#compiling-the-source-with-arduino
I tried the considerably long IDE method - it was a nightmare for an arduino noob. This way with the bin file was a breeze. It's not working but it was very easy to upload to the ESP8266
