3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wi-Fi hack /mod
Wi-Fi hack /mod
another way to "MAKE or Break" your new wireless adapters
Step 1Reverse - Engineering ur adapter
Depending on the adapter u are going to use this process may vary some
25 comments
Jul 18, 2008. 5:43 AMDerin says:
what,that,minipigtail?Man those are ultra small!
Oct 12, 2011. 12:02 PMszulli-randall says:
That's what SHE Said!
Oct 12, 2011. 11:57 AMszulli-randall says:
Is there a way that I can use a directional device to hack into stuff rather than using a computer?
Apr 5, 2007. 9:26 PMi make shooting things says:
What if your laptop already has a card built in any way to exstend range?
Apr 6, 2007. 1:26 PMLasVegas says:
Actually, you can improve your range by adding an external antenna. First, you need to open your computer and locate the WiFi card. Figure out a route for your pigtail to exit the computer and, if need be, drill a hole for it to pass through. You can purchase pigtail cables with appropriate connectors at each end so you can mount the port for your external antenna on the notebook.
Apr 6, 2007. 8:17 PMi make shooting things says:
Any other ways? cause id break somthing if i took apart my laptop any body know any other ways (thxs LasVegas).
Apr 6, 2007. 8:20 PMLasVegas says:
There is a USB powered extender that attaches outside of the notebook and boosts any local signal without actually touching the WiFi card. It's called the Quicky!
Sep 2, 2008. 5:39 AMR4Man18 says:
IF you dont want to open your laptop or pay that much cash for the quicky do the actual instructable and run off that card instead of your other one or just get a 30$ wireless g adapter and mod the wittly bitty antenna.
What im talking about.What im talking about.
Jul 22, 2008. 8:04 PMYerboogieman says:
that's for a mac.
Jul 23, 2008. 6:34 AMLasVegas says:
Since there's no software involved, Quicky would work on any notebook.
Apr 7, 2007. 5:14 PMi make shooting things says:
thnxs
Mar 19, 2008. 6:33 PMBody4Change.com says:
I've been reading a LOT of this WiFi stuff here on our extraordinary Instructables.com and was wondering if anyone has tested the strainer method against the coffee can or pringles method and also against using an old directv satellite and such. Which one would give me the best reception? I'm guessing the satellite dish but I am new to this. TIA!
Jun 26, 2007. 7:45 PMles_SD_3386 says:
I wouldnt consider this to be a WEP or WPA hack or a hacking device but its still a neat mod either way thanks for the instructable.
May 5, 2007. 10:28 PMaceman 569 says:
I"m not even a qualified newbie, I just joined to make comments...well, maybe not, but all my "projects" have failed so far '_'
Apr 6, 2007. 8:03 AMmdmoose29 says:
i've never done this before.. and it was still easy for me to follow.. idk.. maybe im special. the real comment is about how nice it is to meet someone else who disables all that shnazz in windows xp to make it be classic. cheapest upgrade you can make. joy.
Apr 5, 2007. 3:16 PMLasVegas says:
Surprisingly, I was able to follow your steps having performed antenna extensions myself in the past. I would have had problems otherwise.
As the poster, you are allowed to make corrections and adjustments at any time, just click the EDIT button in the upper right.
Your instructable should be written as if you're trying to explain the process to someone that's never seen a computer. Don't assume anyone knows anything.
After you've explaned it as clearly as you possibly can, go back to every step and read it out loud to yourself. If anything sounds wrong, fix it. Once that's done, run a spell check. Everyone make spelling errors. Smart people use spell checkers.
Apr 5, 2007. 1:49 PMHamO says:
I'm afraid I wouldn't post something if these are the best pix I could produce! I can't make out what you're trying to do. Better luck next time!
Apr 5, 2007. 1:35 PMtrebuchet03 says:
This needs some cleaning up (proof read and it ought to be more clear) ;) How did your performance change (good/bad/etc.)?
Apr 5, 2007. 12:05 PMhooloovoo33 says:
Ummmmm maybe you should mention what exactly this mod does....
Apr 5, 2007. 12:14 PMmrmath says:
How to do the mod would be nice. This instructable doesn't really tell you how to do it. As hooloovoo33 said, it also doesn't tell you what you're doing.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:wherewillwhy
i live in a igloo like everyone in canada . i have a dog sled and dog team . i also drive a skidoo to the supermarket . i wear fur coats and i have a beard lol PROPER USER NAME WICKED .
