WiFi Jammer ( No Biasing This Time!)
Published
Introduction: WiFi Jammer ( No Biasing This Time!)
About: A diy learner and I love computers..
The 802.11 standards are vulnerable to deauth attacks i.e. they basically requires no encryption for ACK of the packet and accepts from any AP.Hence gets deauthenticated from the AP. Basically a DOS attack.
Aireplay-ng , Esp826 , Scapy(python) can all perform this attack. Here`s a little insight on all of these and deauth attack itself before getting started.
All Deauth Attack
Explanation
Step 1: About
The Wifi-Jammer has been quite a talk of the town for past few days as it has been shown to us by aireplay-ng before and now esp8266. The project was first published by Space Hunter on instructables using Node Mcu.
The attack features a nice CSS-HTML-JS enabled attack GUI which is pretty awesome and acts as access point, after authenticating to which , you can send deauth packet or run the rouge access point aka 'evil' access point attack program. If you have not checked it already , definitely give it a look and for all those who wanna diy it : Wifi Jammer.
The project can be further extended as mentioned by space-hunter himself to launch de-auth attack every detected access point and stations on it within the range.Hence here`s my little experiment on the darker side.
Let`s go....
Step 2: Parts
Only node mcu or esp826 . Go for breakout board as it contains otg adapter for powering the Node Mcu.
If you have not worked with Node muc ..no problem ! check out the space hunter`s page on the link given above for a detailed installation and description .
And you`re good to go ....
Step 3: Final
Just upload the DeAuth program to the node mcu and probably every device within on your floor within the range gets deuthenticated.
Notes:
1. The programs uses functionality of freedom_packets mentioned in SDK1+ versions and removed in SDK3 libraries for the node mcu.(the hack works well enough)
2. The project originally was developed by Rand Druid . The program works well enough to send unbiased deauth
frames ,but needs a little bit of tweeking to get it right(sometimes a lot) :-).
3. Put your devices address on the whitelist to escape them upon checking for SSIDs.
4.If it doesn`t work still, open the program and change the values at the deauth-packet frame description ..
(mentioned as comment in the program : idk how it worked!).
5. Add home -made antennae to it for de -authenticating the whole apartment stations connected to AP.
(mine was 3-storeys ... It worked most of the times while sometimes on laptop ,they get connected back quickly!)
Check out the original project page itself to download the patch also...
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
