3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
WiFi range expander on wireless repeater Linksys WRE54G
Problem definition
Sometimes the existent operation range isnt enough, or if there are obstacles on the route between the device and the router the distance of operation can be dramatically decreased. In this case You need to increase the sensitivity of the repeater respectively increase the radiation power.
Increasing of the radiation power on the device side isnt legal and might be a subject only for the qualified electrical engineers. So the normal practice is to redistribute power in the volume. Thus many WiFi devices have an option to exchange their antennas. Than you can replace the original omni-directional antenna by a directional antenna. The power and sensitivity can be increased in a desired direction. The antenna of Linksys 802.11G RANGE EXTENDER - WRE54G can not be replaced for now.
Step 1Solution idea
Solution idea
This paper suggests a noninvasive method to extend the operation range in order to connect to a remote access point or client. The method is an approach to form the omni-directional radiated signal into a beam signal. This causes a reduced range/power in other directions.
27 comments
Nov 9, 2011. 8:31 PMardson says:
Hey kot, I'm not to sure that you will be able to find these models anymore as I think Linksys stopped making them? I have been looking but a lot of them are refurbished or just straight up used. If you are lucky you can find something that hasn't been out of the box, but lots of the time seems hard to find. I'm wondering maybe its just better to get a new repeater altogether because a lot of them are able to send a signal further now. Was looking at a few reviews around the WRE54G and not too many people decided to boost it this way? Some people were just using cans! I checked out a few other reviews on wireless repeater review and it seems like if you wanna boost the signal with any repeater you will usually want to get DD-WRT or Tomato. Some sort of firmware which will allow you to customize the repeater or router to your specifications. Finally, I'm wondering if you have any recommendations for 2011?
Sep 10, 2010. 12:20 PMchrishangsout says:
I use a Linksys WRE54G repeater mounted on an old Dish Network satilite dish. (Modified with a 15 dbi antenna) I cut off the Dish Network electronics and simply taped the repeater onto the steel arm. This is very directional and once setup it must be locked down. I then connected a Linksys WRT54G access piont with an omni-directional antenna to the repeater via network cable. The access point re-transmitts the repeaters signal on a new SSID on a different channel. I am currently connected to an unsecure network that is over 4 miles across a lake and forest preserve. I have a full 54Mbs connection. Internet upload speed is 1.38 Mbs and download speed is 5.12 Mbs. I have my access point setup with my own SSID and WEP security. Totally free internet. I've been doing this for over 5 years without any problems. The network is mapped like this... Targeted unprotected wireless access point >>>> Linksys repeater mounted onto the satilite dish pointed at the unprotected network >>>> Repeater connected to the Linksys access point via network cable> >>> Signal is re-broadcasted througt the Linksys access point using my own security settings.
Oct 11, 2010. 6:26 PMThe Ideanator says:
Make an instructable on how to do that, I'm very interested.
Sep 10, 2010. 8:46 PMchrishangsout says:
To give a better idea on the connection. Rather simple. The only difficulty you may have is programming your routers.
Oct 4, 2009. 6:29 PMestefan2020 says:
why not go to e-bay and search for a RP-SMA 2.4GHz 12dbi- 18dBi Wireless WLAN Antenna Aerial and just replace it with a 15inch antenna.
Jan 17, 2009. 11:19 AMdecades says:
The FCC power limitation (broadcast power) is the output times the antenna gain so changing the antenna gain actually changes it's transmitted power. However as a certified WIFI engineer I can tell you that your broadcast power limit is 400mw in the U.S. and some manufacturers like Cisco ship their higher end transmitters at 100 mw not counting the type of antenna gain. Home stuff is 35 mw usually. So the statement of changing power is dead wrong, but of course there are rules as stated.
Sep 25, 2009. 5:32 AMBlackice504 says:
Hi i have linksys ( cisco home brand ) AP at home it has Strange connectors on the Wifi Antennea they look like a hybrid of a TNC connector but instead of been normal its male pin is on the female outer casing and female connector on the male outer casing anyway i was hoping if someone known how do i get a convertor to normal SMA or something usable i have nice wifi Antennea that is very big that i would like to use on one of the Linksys WAP54G PS anyone intrested in the Linksys or Cisco Range i would have to say they are the best for networking in Wifi anything else is just cheap imertation of real network hardware. my Linksys has a good range on it now but as all computer people i want perfect Range for Wifi.
Sep 29, 2009. 5:23 AMdecades says:
Sorry that I can't envision the connector you describe, but if you are comfortable with a soldering Iron you could solder in a standard connection and drill out the case. Be very careful when soldering the pins a "cold" solder joint is really bad in the RF world.
Sep 29, 2009. 5:46 AMdecades says:
It occurred to me that if you are interested you should look into how antenna prorogation works. it does not just dump energy. there are several styles of antennas and they act like the reflector behind the bulb on a flashlight focusing prorogation. That is the part you didn't get and the transmittor and receiver will benefit from the proper antenna. If you put a Yagi antenna on your receiver it will be harder to aim, but will receive at a much higher level. If you put it on the transmitter it will go a long distance, but only cover a small area.
Aug 19, 2009. 6:33 PMthefallen says:
can someone send me a list of stuff i need for cantenna.i just got internet and have sucky wifi out in the boondocks.blaster_4_2008@yahoo.com.thx.btw this is awesome site
Oct 31, 2008. 4:46 AMSpajky [-Spikey] says:
just genious idea combining one way top "cantenna" & slotted reflector also for the other/client side signal receiving :-) ...
Mar 19, 2008. 6:33 PMBody4Change.com says:
I've been reading a LOT of this WiFi stuff here on our extraordinary Instructables.com and was wondering if anyone has tested the strainer method against the coffee can or pringles method and also against using an old directv satellite and such. Which one would give me the best reception? I'm guessing the satellite dish but I am new to this. TIA!
Jun 3, 2008. 10:14 PMkenneyd says:
i tried the coke can against the strainer method, and the coke can got the strainer beat. Used the strainer about 6 months, now i use the can.
May 31, 2008. 11:10 PMjonathan95123 says:
i like the idea, but i found that a can fits perfectly over the antenna. im using one of those fairly large size cans of baked beans.
Feb 13, 2008. 8:00 AMkillumbia says:
I have seen a lot of different ways to do this, had a buddy that went ahead and just hooked a longer wire to his wifi adapter which of course means opening it but hey why buy it if you cant personalize it. He also hooked the longer wire to a fan, which in some way was the kicker to connecting at longer, (maybe 10 feet or so) distance. Personally i had a one of the expanders just like the one in the pic above and it worked great.
Jun 10, 2007. 10:17 AMbaronvonbadguy says:
Try google-ing a coffee can antenna. It turns any columbia tin coffee can into a one direction antenna. (Forgot the word for it :P)
Nov 14, 2007. 6:42 PMTracy says:
Cantenna. Which, BTW, is a word which was stolen from ham radio. Since the 1950s a cantenna has been the name of a 50 ohm dummy load built into a paint can full of transformer oil.
Dec 29, 2006. 1:04 PMColumbusGEEK says:
I put a metal noodle strainer on my head to suck in all the WiFi when I use my laptop.
Dec 28, 2006. 11:00 AMdcshoeco33 says:
i dont think that i would want all of that foil. i would maybe do that if i could hide itsomewhere
Dec 28, 2006. 4:21 PMLasVegas says:
I'd have to say that was the first instructable I've seen that used absolutely none of the Instructable sites tools for arranging the text and pictures into a usable and readable format. Instead everything's just thrown into the Intro page and the heck with it.
Dec 28, 2006. 10:58 PMtrebuchet03 says:
This paper suggests a noninvasive...
http://static2.instructables.com/pub/FSE/UI1Z/FSEUI1Z4MEEVYDXYXX.medium.jpg
I'm going out a limb here.... but that would be quite invasive and therefore would not last long here :P
Dec 28, 2006. 12:24 PMPetervG says:
You've made it into an armored tank, itl take out the aliens!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kot_as_kot
