3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wicking Worm Beds
Wicking Worm Beds
  • last photo ←
How to construct garden Wicking Worm Beds
Water once a week in summer and less during the rest of the year!
"The wicking worm bed is a highly productive growing system which not only produces more food from limited water, but also recycles waste organic material to provide plant nutrient and capture carbon. The essence is to form an underground reservoir of water or pond contained by a waterproof container or liner below the surface of the soil. Plants are productive because they have a continuous supply of water and nutrients." Colin Austin
Water doesn't evaporate in the bottom of the wicking bed it 'wicks' up to the roots, and, the top soil will stay soft, under the mulch. Now, we'll only need to water once a week in summer, and less during the rest of the year.
DIY eBooklet now available (USD$4.50): http://www.maireid.com/wickingbeds.html
Purchase my fully illustrated instructional eBooklet.
"Water for Food: The wicking worm bed revolution"
This booklet provides detailed information, including exact measurements and lists of materials needed for constructing timber-framed Wicking Worm Beds, plus everything you need to know about adding compost worms to the wicking beds.
Step 1The box
The box
Step 1.
We removed the soil from our existing 5x3 meter garden bed and then leveled and terraced the ground for the two new beds, which must be completely level for even water distribution. We put a layer of soft-sifted soil on the bottom for cushioning, and created a waterproof bed for the plastic sheeting (make sure no sharp objects can cut into the plastic sheeting).
60 comments
1-40 of 60next »
May 10, 2012. 10:51 AMpdbrecher says:
I suggest drilling a hole in a ping-pong ball and gluing a wooden dowel in there,
if a ping-pong ball fits into your pvc pipe you can then have a visual indicator of the internal water level by how much of the dowel sticks out
Feb 8, 2012. 8:21 PMtalonsblade says:
was just wondering how something like this would work for strawberries. my wife wants to plant strawberries but i dont know how shallow strawberries grow. what thickness should i make the dirt
Jun 7, 2011. 6:53 PMgwenzpad says:
Maybe next time it might be easier to sift using the screen material thats used for windows.
Jul 28, 2009. 6:59 PMpfred2 says:
You're not serious with that sifter are you? Tomorrow, in the light, I'll go out and take a picture of mine and post it to the thread. Nice planter boxes though. Where'd you get the wood for them, and what kind is it?
Oct 27, 2010. 9:37 PMde Oliveira says:
Hi mate! To clean your water, you may use bamboo charcoal. It's easy to do.
Use steel drums as oven, the bamboo inside of coarse. Close the steel and put under fire letting out a little steam. Watch until the bamboo turns to charcoal.
When bamboo turns charcoal put in bags (or not) and inside water. Works something like activated charcoal. Replace the bags from time to time. Other charcoal type makes the same job. Bamboo charcoal is better.
The old charcoal can be used as powder to make compost.
If you've there a plant named Eichhornia crassipes, put it in your tank. Well, it needs sun, but makes a net on water, covering all area. Its roots take all hard chemicals and clean water too.
See it: long roots=clean water, short roots =dirty water.
Eichhornia crassipes here:
http://www.ecy.wa.gov/programs/wq/plants/weeds/aqua010.html
http://en.wikipedia.org/wiki/Water_hyacinth
This plant may be used to feed cattle, sheep, as hay.
Jul 30, 2009. 5:42 PMpfred2 says:
I don't have wicking beds. Some raised beds but none that wick. Really I have to raise my plants to keep them out of water. Sadly no Eucalyptus trees around here either. It rained here yesterday so I couldn't get a picture of my sifter, but I managed to get outside today to take one. And another reversed wetter view, from earlier this year. We set a monthly record for rainfall right before it was taken. For scale the frame of my sifter is made out of 2"x4" lumber, so it is about 2x3 feet. I can sift a level wheelbarrow in less than 5 minutes with it.
Aug 6, 2009. 9:03 AMdjsc says:
I have got to make one of these. I assume the frame has something lilke chicken wire in it? I have been using a small plastic garden sieve like Maireid's. Do you return the coarse stuff to the compost heap? I am thinking of wicking beds as a robust, low tech hydroponic system, the coarse portion of my compost is very woody- an ideal medium to go in the bootom of the beds with the finer stuff on top.
Aug 7, 2009. 3:13 AMpfred2 says:
OK the mesh I use is 1/4 inch called hardware cloth. It is welded wire.
The wood frame is half lapped 2x4s.
The way I have my sifter rigged it easily dumps off to the side. When the pile gets too large I shovel it out of the way I guess in the general direction of another rotting pile.
How my sifter is rigged:
A piece of light gauge coated steel cable (got mine from around a defunct pool cover) thrown over round top support bar run to hooks into each end corner. Hooks threaded into sides of sifter frame, pointing down. Set sifter up on 2x4 blocking on wheelbarrow over where you park it then I use a simple knot in the wire to the corner hooks.
Knot looks like this:
http://www.finehomebuilding.com/CMS/uploadedimages/Images/Homebuilding/Departments/021200bs104-01_xlg.jpg
Aug 7, 2009. 7:33 AMdjsc says:
thanks.
Jul 31, 2009. 1:52 PMpfred2 says:
You sound impressed with my sifter. It only took me about a half an hour to hang up. I don't think I live in a rain forest, possibly a subtropical one. Though where I'm at it is a bit too low lying. I live in Delaware USA.
Aug 26, 2010. 4:35 PMellismelanie says:
Hello, I have followed the instructions (nice and easy to understand thanks), however now that it is winter I have realised that I forgot to put in drainage holes. You mention putting them in at the end but don't go into any specifics. I was wondering what size, how you stop soil draining out of the hole and how many holes. Hoping you can help as I will soon have raised pools instead of gardens!
Aug 31, 2010. 9:11 PMellismelanie says:
Hi mareid, thanks for the information and the quick response, we'll try that this weekend! Cheers
Feb 1, 2010. 11:07 AMdocwiltbank says:
I have been looking for ideas on how to build this type of grow box for quite some time.  I have made a number of smaller ones similar to the earthbox or earthtainers.  But, I wanted to build build larger ones like yours.  My problem was figuring out how to support the soil on the water.  I like your solution of using rocks for that support, it looks like it works.
My question is how do you get the water to wick up from the water resevoir to your soil?
The smaller boxes I have made use a pond basket filled with soil, and rest in the water resevoir.  I suppose a few of those would work in your type boxes.  But, wondered what your solution was.  Or, does it wick up naturally from evaproation?
Feb 9, 2010. 3:13 PMdocwiltbank says:
I spent this morning, with my son, building the box.  It is a 4'x8' and 20" tall.  I made it out of composite decking planks.  So, the box shouldn't ever have any problems with rotting.  Next, I'll put the plastic liner in.  I have to go to the sand and gravel yard to get some gravel still.
Aug 10, 2009. 10:10 AMswcd says:
Hello Maireid, I feel your approach has many strong chariteristics that are positive to a trouble free system. So far my system is "bullet proof". Once in a while I will find gophers that have borough into the beds making a mess. You are right to be concerned about debris in the water. We do not want any solids to collect, even fine sediment. My fear is that the finer the particles the faster the beds will clog reducing the wicking action and life of the beds. To reduce the issue of solids entering the beds, I failed to mention that my storage tank is tilted slightly to allow solids to settle away from the inlet and outlet. Some day I will need to scrape out the solids but that is a long ways away. I operate a re-wholesale nursery that depends on rain and surface water. It is a remote area without electric service,; these beds work perfectly. I also have a 4,000 gallon tank buried to collect surface water. I use a 12 volt pump with a solar panel to drip irrigate my potted trees. Unlike your arid conditions, I live in Ohio, United States where on average we witness two or three months of mild drought conditions. Other times its more rain than you need. Oh! for moderation!
Feb 27, 2010. 9:33 AMPaladin says:
 putting galvanized chicken wire underneath beds is a good gopher shield.
Aug 6, 2009. 5:13 AMswcd says:
Glad to see the determination to make it work! I have used the same concept for 10 years, starting seedlings for my wholesale tree nursery. The only twist that I like over your design is: I keep a water storage tank outside of the beds. The discharge line from the storage tank has a inexpensive toilet float valve. When the beds demand water the float does the work automatically. It will drive you nuts adjusting and testing. Once you have the system to your liking, it requires no supervision other than a occasional look to make sure its working to your satisfaction. The key is to adjust the float to the water level of the beds. Your storage tank needs a little elevation to apply the static pressure for the float to function. Great Project!
Aug 8, 2009. 7:01 AMswcd says:
Good Morning Maireid; Good question, Yes I use a 1500 gallon poly tank that are completely sealed. I bored a 2 " hole at the top of the tank to determine water level when the tank is full. Using PVC plumbing connections I created a trap for excess water to discharge when tank is full. The trap keeps bugs and debris out of the water supply. I prefer the tank to be out of direct sunlight to avoid warm or hot water to irrigate, so my tank is on the North side of the building with shade cloth draped over it. I have about 500 sq ft of bed area. In our area we average 38 inches of rain annually. During July, August, September I probably use around 800 gallon from the tank. One more suggestion; I have two screens staged to act like filters to trap debris from the rain gutters. This is a must from problem free irrigation.
Jul 30, 2009. 4:10 AMlarsrc says:
While I've never seen them in the US, containers with the same principle are marketed in Denmark and has been for at least 20 years. Styrofoam containers for the water, where the lids have three tubes down to near the bottom. You place a sack of compost on top, make holes to match the tubes, press some of the compost down, and plant (typically) one plant on top of each tube. I've grown tomatoes and peppers that way with as much success as can be expected for the climate. See for instance here and here
This instructable has the advantage of scale and more reusability, but I see no way to clean the water part, which could become a problem over time. In smaller scale boxes, they can be made to be taken apart for cleaning, but not on this scale.
Jul 30, 2009. 6:44 AMthe rural independent says:
This is a fantastic, well written article. I really appreciate the level of detail that you provide. I have been using a home made "eco-box" this year and have had great luck with six tomatoes per 21 gallon container.
Next year there WILL be a Wicking Box in the yard for sure.
On the water level / floatie thing, I think that nillo's suggestion is great and will be incorporated into my design.
Thanks for sharing!
http://www.theruralindependent.com
Jul 24, 2009. 1:05 AMSkip says:
Awesome idea. You could easily set an aquaponics setup to this.
Jul 24, 2009. 7:28 PMcapheind says:
Aquaponics uses fish to add, um, "Organic Matter" to the water before it is used in a Hydroponic system, in lieu of, or in addition to, the normal nutrient mix. You could merge an aquaponic system into a Wicking bed by adding an inlet and outlet to the bottom of the bed so the water can be cycled through a pond. Or you could build a pond deeper into the ground coming right up to the level of the rocks, and then create a pass through between the bed and raised pond.
Jul 30, 2009. 6:48 AMthe rural independent says:
We have a small pond with fish in it and I take pond water out in a pitcher to water the tomatoes and also some flower boxes. The fertile water is much loved by the plants - great design idea capehind!
Jul 24, 2009. 9:08 PMcapheind says:
I'd love to try it myself but I don't have the space. I'm an apartment dweller. If your a piscivore I'd recommend tilapia, their very easy to keep, relatively easy to clean, and can even eat some of the veggie scraps from the garden.
Jan 7, 2012. 12:30 PMcapheind says:
Well I have a small bed here at the complex, and piles of potted plants already filling my patio.. but when I have room I'm always up for a new experiment..
Jul 27, 2009. 9:54 PMnillo says:
You could make a float to tell you what the water level is. Just get a big cork and drill a hole in the middle. Stick a piece of balsa wood through the hole. Place the float in the PVC standpipe. Try to use a big cork that is almost the same diameter as the stand pipe, and make sure the balsa wood stem is long enough to stick up over the top. Just paint the balsa wood stem for visibility and you will know how much water is in the reservoir from 10 feet away.
1-40 of 60next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:maireid
