3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wide-Angle and Fish-Eye Camera Lens Adaptor
How to build a lens adaptor for your camera for about $5-10. This adaptor allows you to get wide angle shots up to 200 degrees field of view and take funny fish-eye effect photos. Uses only commonly available materials. The entire process and example photos are shown in the video.
Step 1Parts List
Parts List
A picture is worth a thousand words and a video is worth even more. All of the instructions are demonstrated in the Instructional video.
You will need:
1. A peep hole - the kind you use on your front door to see who is on the other side. Get one at the hardware store. They come with 160 degree or 200 degree field of view. The 160 is probably fine for most wide-angle work. The 200 is as wide as most people will ever need. You can actually see slightly behind the lens with this one. And, it works better for fish-eye effect. However, is may show more barrel distortion. If you can't decide, get both.
2. PVC Pipe. The smallest diameter you can find that will fit around your camera's lens barrel.
3. Craft foam. These EVA foam sheets are available at craft stores and any place that sells scrap booking supplies.
44 comments
1-40 of 44next »
Oct 28, 2011. 8:45 AMnvranjea says:
Very nice project indeed. I made this today, but I used a 120 degree peep hole and it had a too big circle around it, I even sawed it off quite a lot, but it was still a bit big. Anyway I am pleased with the result, but I gotta get myself the 200 degree one. Here is a photo. Camera used is Coolpix L22.
Dec 31, 2009. 11:10 PMsjoobbani says:
I have trouble with 2 things:
focus
Lighting.
Focus: i tried on landscape, i tried autofocus, and I tried macro. what to do? still blurry, i understand the edge's could be blurry, but the whole thing?
Lighting: everything seems a darker, and flash ruins things even more. tried different exposures, brightness... only thing to do, is use the Nightvision mode on the camera, from my 'ible : and that makes everything green, so...
please help.
Jul 1, 2010. 2:32 PMarchmadtramp says:
I occasionally have troubles with focus, but it's usually because my hand wasn't perfectly still. I'm not sure of this, but with the fisheye lens, the camera's focus seems more temperamental...
Sep 26, 2010. 12:10 PMsjoobbani says:
Yea, you could do that, or you could just manually adjust the focus.
depends on how much you use it..
May 30, 2010. 11:47 PMPretty Idiot Productions says:
Fantastic project that resulted in some fantastic pics.
Recycled an old plastic 35mm film canister instead of using the PVC pipe (cut out the entire bottom of the canister and mounted the peephole in the grey lid). Got the 200 degree field of view peep hole and wrapped it in the craft foam... fits like a glove on my Casio Exilim!
Thanks!
Sep 3, 2009. 7:15 PMrada194 says:
How Would i make it for this camera
Jan 23, 2010. 12:55 PMruktion says:
Oct 18, 2009. 6:35 PMJ@50n says:
i would guess that it might work. but probably not. you may need lots of duct tape.
Jan 9, 2010. 6:38 PMgoeon says:
 works great ! thanks for the ible
(sorta took the picture in a rush hence the blurryness
Jan 30, 2008. 4:08 PMry25920 says:
nice idea. I gotta try this. It would be great for security.
Dec 31, 2009. 11:04 PMsjoobbani says:
the corner security camera's and also, Dashcams
sometimes just for fun, or for "spying" on teen drivers...
Jul 12, 2008. 8:17 PMasianpuff16 says:
do you think i could make one of these to fit on this camera?,has anyone tryed it on this camera?:
http://www.walmart.com/catalog/product.do?product_id=5924870
Dec 31, 2009. 11:01 PMsjoobbani says:
This is an excellent one, I've done it on a similar camera ( Flip Ultra HD )
Jul 25, 2009. 6:42 AMQuelso says:
This is awesome. I don't have to spend several dollars on this. This is very cheap and useful! This is my cat at the fish eye, and me in the fish eye! Jeje Thanks
Dec 31, 2009. 11:00 PMsjoobbani says:
haha cat looking at a fisheye.. get it?
Nov 10, 2009. 5:22 PMkitfoxtrot says:
thanks for the info! always wanted to experiment with one but didn't have the $- this is great :D
Aug 9, 2009. 8:51 AMQuelso says:
Without feelings about make my video known, I made a video of parkour using the fish-eye lens.
I invite you to see it!
http://www.youtube.com/watch?v=quOpnBTDSIs
Greetings! And thanks again for the lens!
Jul 29, 2009. 1:21 AMgeemarc12 says:
hi i live in england and i cant seem to find them any where any ieas where i could get one from because im not willing to pay like £400 for one im a skater so i need one for mine and my friends skate videos
Jul 16, 2009. 6:54 PMbaken411 says:
i am definatly making this asap great 'ible
Feb 21, 2009. 1:04 PMClayton H. says:
This would be cool to put on one of those old TRL cammeras but you would need to make two, one for the lense and one for the "veiwfinder?".
Nov 22, 2008. 7:14 PMKryptonite says:
Wow, a fish eye or wide angle lens is quite expensive where I come from, looking forward to making this! :D
Oct 15, 2008. 8:48 PMxskatinforsatanx says:
I made my lens today and its sickkkk dude. I really needed it to make some skate vids. Heres a couple things i did with it so far.
Aug 9, 2008. 2:53 PMrediculosis says:
Is there a way to substitute a cardboard toilet paper thingy for the PVC piping? I mean, I'm like 16, and I could buy some PVC piping, I just don't know what that cutter thing is. Haha.
Jul 21, 2008. 9:47 PMgordo says:
(L)
Jul 12, 2008. 10:54 PMalvincredible says:
thats a super clean and well done design! i really like it good job
Jul 3, 2008. 9:20 PMvanpaun says:
how close to the camera lens should it go?
Jul 11, 2008. 11:28 AMvanpaun says:
Ok, I assembled it today! My only thought is that Spray adhesive isnt good, and can be replaced by scotch tape. You can also use scotch to build up a "Micro layer" if a whole one is not needed, Spray adhesive bubbled and stuck my fingers together. P.S. I adapted it for my video camera
Jul 11, 2008. 11:37 AMvanpaun says:
Also, I used a sawed in half coupler witch has a really handy lip, so that it can only slide to a certain point.
Apr 24, 2008. 11:46 AMzappBrannigan says:
This seems to be a common way to add wideangle to your compact camera or webcam. The only thing is that its very unpractical. I took my saw out and chopped one of those peepholes up. It consisted of 4 lenses, throw the first one away, and you can attach the other ones directly to your camera, theyre small, light and a much better solution than this. It adds max 5 grams and 1cm to your cam. Just make sure to orient them in the same way they were in the housing, you can even use just one or two of the lenses with a narrower angle as a result.
Mar 16, 2008. 7:40 PMtheresanovak says:
Really interesting and cool idea. Thanks! :-)
Feb 21, 2008. 10:49 PMclarissa2k6 says:
what a great idea... and cheap too...i'm doing this later... thanks
Feb 4, 2008. 3:05 PMmanonfire285 says:
Can you give me the exact dimensions you used please? I have that exact same camera. Thanks.
Jan 30, 2008. 12:19 AMcloner says:
where are your sample photos? i wanna make this one :) tnx
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
75
Author:shoemaker
