Wifi Antenna
Published
Introduction: Wifi Antenna
Step 1: Gather Supply's
You will need a Wifi antenna via USB Tri pod Tin can USB expander wire. Tools Drill Hot glue or gorilla glue
Step 2: The Drill
You will take your drill and drill a hole the size of the antenna the put the antenna through the hole and reconnect it to the antenna
Step 3: Reconnect
Now reconnect the wifi antenna then you are almost done.
Step 4: The Antenna
Now take your extender wire and wrap it around the tripod then connect it.
Step 5: Plug It in and Bazinga
This gadget will boost your wifi reserver by 75%. This only took me 20 minutest and was fun. Hope you all enjoy.
    • Casting Contest
      Casting Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    3 Comments
    Could be a good instructable, but I found the repetitive pictures frustrating, and if you explained each step, it would be more effective.
    Points for actually MAKING STUFF.
    Maybe it works great, maybe not. Maybe you could do it better. Do some research and make something yourself. Keep at it until you get something that works. DO SOMETHING. Have fun. Learn. Get creative. Tell the rest of us. Go!
    you're not even on the focus point, this is a useless antenna, some aluminum paper foil as back face reflector will have the same effect, badly, but the same.
