Wii Nunchuck Adapter
Step 8Soldering on the header pins
SOLDERING ON THE HEADER PINS:
+header pins
+soldering iron
+electronic solder (with flux perferd)
this is kinda a pain cause we dont have the privalage of through hole soldering, so we have to solder on both sides of the PCB.
1) place your header pin in the board
2) Solder in each pin on the side that says "TOP"
3) let cool
4) turn the board over and romove the black plastic it should just slide right off.
5) here comes the sort of hard part. solder the bottom of the pin and try to keep it relativly straight, or else it woulnt fit in the arduino. You must to this because we have a double sided pcb.
6) try inserting it into the arduino and if it doesnt fit heat up the solder and adjust the pins as needed.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:dany32412
