Wii Nunchuck Adapter
Step 9Testing The adapter
Testing The adapter
If you dont have the Arduino program installed yet then go to www.arduino.cc/en/Guide/HomePage and follow the arduino getting started tutorial.
Part I
1) DOWNLOAD these 2 files
www.megaupload.com/
www.megaupload.com/
2) Create a new folder called "WiiChuckDemo" without the quotes.
3) Place those 2 files in the folder
4) Open up arduino IDE and goto file> open> and open "WiichuckDemo.pde"
5) Upload that sketch to your arduino
6) we are done with part 1
Part II
+various jumper wires
+4 leds
+the nunchuck adapter
+bread board or protoshield
+and a wii nunchuck
1) Plug in the adapter into analog pins 5,4,3, and 2 like image 1 shows.
2) Now were are going to put in all our ground jumpers, in a "daisy chain" style. (image 2)
3) Now put in all the wire going from the LED's positive legs to there coresponding pins on the arduino. (image 3)
UP led= digital pin 4
DOWN led= digital pin 5
LEFT led= digital pin 2
RIGHT led= digital pin 3
4) Now its time to place our leds into the bread board making sure that the short leg or the flat side on the led is in the ground, and the long leg is in the positive (or the wire going to the arduino digital pins) (image 4)
5) plug in you wii nunchuck
6) power up your arduino
7) and hopfully it will work if now leave a comment and i will try my best to help you.
8) heres a demo video
11 comments
Dec 31, 2011. 7:29 PMredsunmtm says:
hi,
excuse me but i am really a newbee in arduino...
i am trying to make this instructable, but when i want to load the sketch i have this error:
In file included from WiiChuckDemo.cpp:2:
/nunchuck_funcs.h:13:22: error: WProgram.h: No such file or directory
/nunchuck_funcs.h: In function 'void nunchuck_setpowerpins()':
nunchuck_funcs.h:24: error: 'delay' was not declared in this scope
/nunchuck_funcs.h: In function 'void nunchuck_init()':
nunchuck_funcs.h:33: error: 'class TwoWire' has no member named 'send'
As of Arduino 1.0, the Wire.send() function was renamed to Wire.write() for consistency with other libraries.
nunchuck_funcs.h:34: error: 'class TwoWire' has no member named 'send'
/nunchuck_funcs.h: In function 'void nunchuck_send_request()':
nunchuck_funcs.h:43: error: 'class TwoWire' has no member named 'send'
/nunchuck_funcs.h: In function 'int nunchuck_get_data()':
nunchuck_funcs.h:63: error: 'class TwoWire' has no member named 'receive'
As of Arduino 1.0, the Wire.receive() function was renamed to Wire.read() for consistency with other libraries.
/nunchuck_funcs.h: In function 'void nunchuck_print_data()':
nunchuck_funcs.h:114: error: 'Serial' was not declared in this scope
i also tested various sketches from other instructables and i always have errors !
with the included libraries i have no problem !!!
what is it happening ?
please help me !
PS:
i have the Arduino Mega Atmega1280 and use Arduino V1.0
Jan 2, 2012. 12:36 PMredsunmtm says:
hello and happy new year
thanks for answering that quick !
so it is due to the V1 ?!?
i was searching the Arduino 22, but i cant find it ! could you please send me that version by mail please?
tha would be very friendly...
regards
Jan 2, 2012. 4:35 PMredsunmtm says:
it is ok i found at arduino's, i was searching in google arduino 22 and couldn't find nothing, but went to site and voila, thank you, i am going to get 0022 and 0023 to see, thanks again.
Jan 3, 2012. 3:44 AMredsunmtm says:
hy,
yes i found them, but nothing works, i mean, the sketches seem to install correctly, but nothing happens, only sometimes the led 13 keeping alive and my up and left led staying lighting with no change from nunchuck.
the leds are new, the nunchuk too and even better i cutted the cable to connect directly on the board, so no false contact... but nothing...
have tryed to send only the pde, then i try to send pde and h files and nothing... disapointed ! :(
i think i'll wait you V1 version !
thanks
Dec 31, 2011. 7:45 PMredsunmtm says:
hy again,
now i placed the folder in C:\Documents and Settings\mich\My documents\Arduino\
i open the .ino i converted before, start loading and now:
In file included from WiiChuckDemo.cpp:105:
/nunchuck_funcs.h: At global scope:
nunchuck_funcs.h:14: error: redefinition of 'uint8_t nunchuck_buf [6]'
nunchuck_funcs.h:14: error: 'uint8_t nunchuck_buf [6]' previously declared here
nunchuck_funcs.h:17: error: redefinition of 'void nunchuck_setpowerpins()'
nunchuck_funcs.h:17: error: 'void nunchuck_setpowerpins()' previously defined here
nunchuck_funcs.h:29: error: redefinition of 'void nunchuck_init()'
nunchuck_funcs.h:29: error: 'void nunchuck_init()' previously defined here
nunchuck_funcs.h:40: error: redefinition of 'void nunchuck_send_request()'
nunchuck_funcs.h:40: error: 'void nunchuck_send_request()' previously defined here
/nunchuck_funcs.h: In function 'char nunchuk_decode_byte(char)':
nunchuck_funcs.h:49: error: redefinition of 'char nunchuk_decode_byte(char)'
nunchuck_funcs.h:49: error: 'char nunchuk_decode_byte(char)' previously defined here
nunchuck_funcs.h:57: error: redefinition of 'int nunchuck_get_data()'
nunchuck_funcs.h:57: error: 'int nunchuck_get_data()' previously defined here
nunchuck_funcs.h:79: error: redefinition of 'void nunchuck_print_data()'
nunchuck_funcs.h:79: error: 'void nunchuck_print_data()' previously defined here
/nunchuck_funcs.h: In function 'int nunchuck_zbutton()':
nunchuck_funcs.h:141: error: redefinition of 'int nunchuck_zbutton()'
nunchuck_funcs.h:141: error: 'int nunchuck_zbutton()' previously defined here
/nunchuck_funcs.h: In function 'int nunchuck_cbutton()':
nunchuck_funcs.h:147: error: redefinition of 'int nunchuck_cbutton()'
nunchuck_funcs.h:147: error: 'int nunchuck_cbutton()' previously defined here
/nunchuck_funcs.h: In function 'int nunchuck_joyx()':
nunchuck_funcs.h:153: error: redefinition of 'int nunchuck_joyx()'
nunchuck_funcs.h:153: error: 'int nunchuck_joyx()' previously defined here
/nunchuck_funcs.h: In function 'int nunchuck_joyy()':
nunchuck_funcs.h:159: error: redefinition of 'int nunchuck_joyy()'
nunchuck_funcs.h:159: error: 'int nunchuck_joyy()' previously defined here
/nunchuck_funcs.h: In function 'int nunchuck_accelx()':
nunchuck_funcs.h:165: error: redefinition of 'int nunchuck_accelx()'
nunchuck_funcs.h:165: error: 'int nunchuck_accelx()' previously defined here
/nunchuck_funcs.h: In function 'int nunchuck_accely()':
nunchuck_funcs.h:171: error: redefinition of 'int nunchuck_accely()'
nunchuck_funcs.h:171: error: 'int nunchuck_accely()' previously defined here
/nunchuck_funcs.h: In function 'int nunchuck_accelz()':
nunchuck_funcs.h:177: error: redefinition of 'int nunchuck_accelz()'
nunchuck_funcs.h:177: error: 'int nunchuck_accelz()' previously defined here
WiiChuckDemo.cpp: At global scope:
WiichuckDemo:3: error: redefinition of 'int loop_cnt'
WiichuckDemo.pde:-1: error: 'int loop_cnt' previously defined here
WiichuckDemo:5: error: redefinition of 'byte accx'
WiichuckDemo.pde:-1: error: 'byte accx' previously declared here
WiichuckDemo:5: error: redefinition of 'byte accy'
WiichuckDemo.pde:-1: error: 'byte accy' previously declared here
WiichuckDemo:5: error: redefinition of 'byte accz'
WiichuckDemo.pde:-1: error: 'byte accz' previously declared here
WiichuckDemo:5: error: redefinition of 'byte joyx'
WiichuckDemo.pde:-1: error: 'byte joyx' previously declared here
WiichuckDemo:5: error: redefinition of 'byte joyy'
WiichuckDemo.pde:-1: error: 'byte joyy' previously declared here
WiichuckDemo:5: error: redefinition of 'byte zbut'
WiichuckDemo.pde:-1: error: 'byte zbut' previously declared here
WiichuckDemo:5: error: redefinition of 'byte cbut'
WiichuckDemo.pde:-1: error: 'byte cbut' previously declared here
WiichuckDemo:6: error: redefinition of 'int ledPin'
WiichuckDemo.pde:-1: error: 'int ledPin' previously defined here
WiichuckDemo:7: error: redefinition of 'int Lledpin'
WiichuckDemo.pde:-1: error: 'int Lledpin' previously defined here
WiichuckDemo:8: error: redefinition of 'int Rledpin'
WiichuckDemo.pde:-1: error: 'int Rledpin' previously defined here
WiichuckDemo:9: error: redefinition of 'int Uledpin'
WiichuckDemo.pde:-1: error: 'int Uledpin' previously defined here
WiichuckDemo:10: error: redefinition of 'int Dledpin'
WiichuckDemo.pde:-1: error: 'int Dledpin' previously defined here
WiiChuckDemo.cpp: In function 'void setup()':
WiichuckDemo:13: error: redefinition of 'void setup()'
WiichuckDemo.pde:-1: error: 'void setup()' previously defined here
WiiChuckDemo.cpp: In function 'void loop()':
WiichuckDemo:22: error: redefinition of 'void loop()'
WiichuckDemo.pde:-1: error: 'void loop()' previously defined here
another type of error... i don't understand...
Dec 31, 2011. 7:37 PMredsunmtm says:
hello again,
i placed the .pde and the .h files to: libraries\Servo\examples\WiiChuckDemo
then i renamed .pde to .ino
i restart loading and now here is the error:
sketch_jan01a.cpp:3:28: error: nunchuck_funcs.h: No such file or directory
sketch_jan01a.cpp: In function 'void setup()':
WiichuckDemo:16: error: 'nunchuck_setpowerpins' was not declared in this scope
WiichuckDemo:17: error: 'nunchuck_init' was not declared in this scope
sketch_jan01a.cpp: In function 'void loop()':
WiichuckDemo:27: error: 'nunchuck_get_data' was not declared in this scope
WiichuckDemo:29: error: 'nunchuck_accelx' was not declared in this scope
WiichuckDemo:30: error: 'nunchuck_accely' was not declared in this scope
WiichuckDemo:31: error: 'nunchuck_accelz' was not declared in this scope
WiichuckDemo:32: error: 'nunchuck_joyx' was not declared in this scope
WiichuckDemo:33: error: 'nunchuck_joyy' was not declared in this scope
WiichuckDemo:34: error: 'nunchuck_zbutton' was not declared in this scope
WiichuckDemo:35: error: 'nunchuck_cbutton' was not declared in this scope
it looks like no finding the.h file ...
what i am doing wrong ?
please help !
thank you in advance.
Apr 20, 2011. 3:55 PMCinder Dragon says:
Excuse me for being ignorant, but what exactly is the point of this?
Jul 20, 2011. 5:25 PMookid says:
It is so that one can use a Wii nunchuck with one's arduino without having to cut/ damage/ modify the original cable, which make the nunchuck useless for its intended purpose.
Aug 23, 2011. 5:47 PMCinder Dragon says:
Ah, thank u :)
Apr 29, 2010. 1:36 PMkeler says:
Thank you!
(your sense of humor highly appreciated :)
Nov 13, 2009. 11:35 PMwindrago says:
 super!
and I loved the comments on the pixes :-))
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:dany32412
