3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wii Remote IR Camera Hack with Arduino Interface
We'll physically extract the IR camera from the Wii remote and interface it with an arduino controlling a servo.
The Wii IR camera is a beautiful thing. It has an integrated processor which outputs the X and Y positions and size of the 4 brightest IR points that is sees. This can be very useful for tracking in robotics or human interfaces. Enjoy!
Step 1Extract the Wii IR camera
You'll need a Wii remote or "Wiimote" to start with. Normally they are about $40, in the end that is not too bad for a pretty awesome sensor. Otherwise you can check out ebay or elsewhere for used or broken Wii remotes.
You'll need to rip apart the case. It has some crazy three pronged screws. I didn't want to completely trash the case so I made a small tool to take it apart.
Now you need to desolder the 8 pins and the 2 struts holding the camera on the board. I used some desoldering braid. It wicks the solder away and makes it easy to get the camera out. Be careful, don't break the camera!
How to use desoldering braid: http://www.youtube.com/watch?v=AcbezX8TrOU
You might want to keep the rest of the parts. You might be able to scrap other parts. Also, If you decide later to use the Wiimote again, you could always put the camera back in.
61 comments
1-40 of 61next »
May 21, 2012. 8:16 AMbharrison7 says:
You can now buy the camera's pre soldered onto a clock circuit from this place:
http://rocketbrandstudios.com/store/pcb-s-and-boards
He's even got some video and code examples for using it in a followme setup on a bot.
I'm not sure if you would still need to run it through a converter circuit to use it with a 5v board like the arduino but it looks to be running fine interfacing to an arduino nano in the video
Either way it makes for a much neater little package than unsoldering and proto boarding your own :-)
May 2, 2012. 10:43 AMdrujensen says:
(removed by author or community request)
Jan 31, 2012. 1:21 PMmmalluck says:
I'm wondering if a 3.3v to 5v logic converter is necessary. Some folks have had luck with disabling the internal pull-up resistors used in wire library and installing their own pull-up resistors to 3.3v source.
http://www.varesano.net/blog/fabio/how-disable-internal-arduino-atmega-pullups-sda-and-scl-i2c-bus
No converter necessary.
Dec 26, 2011. 11:33 AMevolvingtech says:
I imagine that the IR camera is a custom made component made only for Nintendo. Does anybody know if there is an equivalent product that can be purchased from an third party company be it Pixart or anyone else?
Dec 11, 2011. 1:24 PMEvilChip says:
Hi. You know which is the range of IR that the WiiMote detect?
May 20, 2010. 4:02 PMGonazar says:
OK, so i'm new to the use of inverting logic gates and i don't understand the schematic. After reading wikipedia i see that the logic gate has 6 inverters in it. Does it matter which you two you use? And as far as i can tell from the photos, your using using the VDD (pin1) and NC (pin16) but what are they connected to?
Also, would you be able to make a list of recommended digikey parts for the standard parts? I'm not quite familiar with the logic gates and don't know which to pick. I'm also not sure about the crystal either.
Oct 5, 2011. 10:22 AMquestionman says:
Hi there. Is 74LS04 ok with this circuit? Thanks buddy. :)
Oct 4, 2011. 8:24 AMquestionman says:
Hi there. That is a very interesting project you have. I am wondering if instead of using that voltage converter shield, can we use this instead:
http://www.sparkfun.com/products/8745
It has the same purpose though, which is to convert voltages.
Forgive my knowledge about this, since I am just a beginner as a hobbyist.
Thanks a lot buddy! :)
Oct 5, 2011. 4:04 AMquestionman says:
Hi. Sorry for this newbie question but, is the theory behind the circuit of
same as this?
http://i52.tinypic.com/2niprtz.png
I am trying to work your on your project and I followed all the circuits,
except for the voltage converter shield. It seems that the i2c scanner:
http://todbot.com/blog/2009/11/29/i2cscanner-pde-arduino-as-i2c-bus-scanner/
cannot detect the i2c device, which is the pixart camera.
I would really appreciate if you can help me on this. Thanks again. :)
Aug 26, 2011. 6:07 PMbskaloud says:
Hi, I am having problems getting this circuit to work. I've tried replacing all the components, different wii IR cameras, and still I get a continuous output of all blobs with a size of 0. I lowered the pull-up resistance on the SDA-in and SCL-in to 1.5k ohms, and this worked for a bit, but then after a few days it stopped working again. I've also tried soldering all the components instead of using a breadboard, but this had no effect. Do you know what the problem might be? This is driving me nuts. My next step is to vary the pull-up resistor values and see if something works. Thanks for your time.
Aug 29, 2011. 4:09 PMbskaloud says:
Thanks for the reply. Turns out it was a grounding issue. I was only connecting pin 2 of the camera to ground, and when I connected pin 3 also, it worked. I don't quite understand it because the pins are connected internally... Also, one of the cameras I was trying to use was burnt out, so that just added to the frustration.
Nov 24, 2010. 9:01 PMameenyousuf says:
nice work. I was wondering whether similar circuitry could be used to detect finger movements? I am working on an optical projection keyboard project and was planning to use the Wiimote IR sensor for the purpose of detecting finger movements when a user hits a key. I think what you have made could be applied to some extent to my project also?Is that possible? Thanks
May 18, 2011. 1:23 PMpspittle says:
You may find it a lot easier if you were to do something like what is in this video for your project. Doesn't require such lengthy amounts of work, and you can keep the wiimote in one piece
Apr 16, 2011. 9:28 AMBeenay25 says:
Brilliant instructable.
Do you know how to change the pins that the camera uses on the arduino? I think it defaults to 6 and 5, but I'd like to change these and can't figure out where they are set...
Apr 2, 2011. 6:54 PMmarcwolf says:
Very interesting project and also thanks - I have been curious about the 'speed' of processing.
I do animatronics as a hobby and one of the 'holy grails' is real time Lip Syncing where the mask will move it's lips in time with yours.
If one thinks of the lips as a flexible circle with points every 90 degree's then it's easy to put reflective points on the lips at that location/ Then it's easy to work out how open, cloded, or wide the mouth is and du0plicate it on the puppet.
Using an industrual face mask (for dusting) you can make a fully self contain system complete with camera and IR 'spotlight' that will protect the eyes and provice a dark environment.
Take Care
Marcwolf
Oct 24, 2010. 9:03 AMrazstec says:
Anyone can help with building a smaller controler so i can attach it laptop screen side and use a pen as a mouse?
the wiimote its just too big, any sugestion?
A way to power it by usb would came in handy too.
thanks
Sep 22, 2010. 9:35 AMjamwaffles says:
Does anyone know where you can buy the camera on it's own?
Also, thanks for the cool instructible - that servo is incredibly responsive!
Nov 19, 2009. 10:03 AMshining_wizard says:
Very interesting project... for disassembling anything Nintendo related, you can find "trigram" or "triwing" screwdrivers pretty cheap on the web which will unscrew these, NDS cases, and many McDonalds toys too LOL.
Jul 13, 2010. 3:35 PMcdousley says:
i just use a very small flat bit theres an ible for it around here somewhere...
Apr 17, 2010. 1:56 AMLance Mt. says:
 Could you mount to the servo and cut movement back to a 1:1 movement ratio?
Jun 6, 2010. 5:18 AMLance Mt. says:
Miniature Mech Fighting toys, here we come.
Nov 24, 2009. 4:22 AMthalass says:
This is great. I wonder if you could use it to track the sun? There are cheaper and simpler ways to do that, I suppose, but the wiimote ir camera mounted in the middle of a group of solar panels, or a reflector dish for solar thermal, with the arduino programmed to return the array to a pre-determined position when an ambient light sensor determines it's dark outside (or the solar panel output goes below a threshold, or an internal clock determines it is close to sunset, or a combination). You could even alter the morning position based on the date, so the panels are in the right spot in the morning.
Very flexible, I like.
Nov 24, 2009. 7:48 PMthalass says:
I don't think the moon has much of an IR signal. Not enough for the wiimote camera, probably. It'd be easy to test, though. With cwiid or another wiimote program for pc. Point it at the sky and see what the output looks like.
For orientation, that method would work great, except at around midday. Especially if your vehicle is on a tilt. That can be compensated for, though. But then again you can get hall effect compass systems for fairly cheap nowdays, which also have no accumulative errors or anything.
Now if your vehicle was on a body without any magnetic field, like the moon or something, then that would work very well. Especially if you could use the earth as a second reference point for when the sun is directly overhead.
Dec 4, 2009. 12:59 AMthalass says:
I just tried this out, with wmgui on my laptop. The sun is much too bright for the wiimote to register it! Even with two polerised sunglasses lenses at various angles (crossed at 90 degrees you can't see through them, though the sun still shines through) I got no output - though reflections of the sun on various things produced a myriad of points the wiimote will track.
I also tried the moon the other night, being a full moon, and I think that it wasn't bright enough either. Though I didn't try putting my sunglasses in front of the lense to test that out.
Apr 16, 2010. 8:45 PMwkuace says:
maybe you could try a welding mask? If you have a spare set of oxy acetylene goggles those might work, arc welding mask are actually darker and might block to much light. They might completely block the IR light though
also does anybody know if the IR cameras from the Nyko or other brand wii remotes will work?
Nov 24, 2009. 7:54 PMthalass says:
Actually if your system was sensitive enough you could work out longitude and lattitude, too!
Apr 10, 2010. 9:48 PMGonazar says:
Very interesting instructable and well written.
I'm looking into taking this a bit further and was wondering if you set up an area where you have 1 camera on one side and another facing perpendicular from another side like so...
_____________
|_____________|
Where ^ is a camera direction and * is the light source in this square environment
Would you be able to track 3 dimensions? (1 camera doing xy, the other doing yz). Would arduino be able to handle the two cameras? I also assume that each camera would need it's own interface circuit as well?
Apr 2, 2010. 8:56 AMnadav says:
 Is there anywhere we could get the IR camera separately?
1-40 of 61next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:BigRedRocket
