loading
Its a basic blue led light in miniature WiiMote!
Materials Needed
Soldering iron
Solder
Micro switch (5$ at radio shack)
Blue Led (5$ for 2 at radio shack)
2xAAA battery holder (5$ at radio shack)
WiiMote candy dispenser (1$ at dolorama)
total 15$ (5$ at real electronic store)
Step 1: Making a hole for battery holder
Picture of Making a hole for battery holder
Make a small hole (enough for the wires to pass) using a pocket knife or a heated screwdriver.
Step 2: Cutting down useless plastic
Picture of Cutting down useless plastic
Cut and sand down so that the switch and the led can be glued in placed later.
Step 3: Gluing and soldering
Picture of Gluing and soldering
Glue down the battery holder.
Solder the red wire to the shorter end of the switch
then solder the long pin of the led to the other pin on the switch (cut the leg to size)
the shorter leg will be soldered to the black wire.
glue everything into place.
Step 4: The End!
Picture of The End!
The end result! its a pretty bright light!
whats the extra thingy for
knex_mepalm4 years ago
Lol, I cant believe I am holding the dispenser while loking at this.
ikssk6 years ago
COOL. Can I have the guts from the wiimote you took apart???
Thornburg ikssk6 years ago
Its a candy Wii mote, its not real therefore there are not any guts.
So he ate the guts.
Plasmana ChrysN6 years ago
LOL!
VadimS Plasmana5 years ago
It looks like a Wii themed Pez dispenser, lol.
ikssk Thornburg6 years ago
I was referring to the candy, i was going to eat it my self.
My bad, I thought you were talking about the electronic parts inside the remote. Sorry
andy707075 years ago
umm, wouldnt it make more sense to put the switch on the end, so you dont have to take it apart every tie you want to turn it on?
I'm trying to think of a way to take the faux A button off, and rig a pushbutton switch under it, so you could replace the top part of the wiimote back on...or a way to fix a switch to the trigger underneath. ( I got one of these from the local Walgreens, near the checkout)
anyonenot (author)  Kanein Encanto6 years ago
The B button has a pin that make it bounce back so maybe you can use that to rig a push button switch.
