3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wiimote B button rumble mod
Here I will show you how you can make your B button on your wiimote light up on/either Rumble or all the time.
Supply's-
LED 3mm , color of you choice
Solder and 15watt soldering iron
Resistor (if you want)
Tir-wing screw driver
About an inch of wire
Wiimote (duh)
And thats about it
Heres what the final product will look like :)
Also you can get everything else form Radio Shack.
Here is my youtube video of it in action http://uk.youtube.com/watch?v=9M6cHJIr65k
Step 1Lets get that wiimote apart and the B button ready for the LED
First take apart your wiimote, then take out the B button. Bend your LED somewhat like this (see picture one) I put more of a curve on my led to get it to fit better, just play around with it until you get the feel right.
Then solder wire to the LED ends, make the wire about 1 1/2 inches long. Insert your LED into the B button. You can either remove the far bottom clip like i did or just put it by the clip.(what i did was once i removed the clip i took my solder iron and poked a hole threw the tube) picture #2 is where you remove the clip. NOTE: the positive (+) leg of the LED is the smaller piece of metal if you look into the clear part of the LED and the negative (-) is the other one.
Picture #3 is where you melt (optional) a hole threw the tube on the button. If you did this step, all you do is melt a hole about in the middle of the tube until you can fully insert your LED. Make sure not to melt the top of the tube because if you do it will be really hard to put the button back together and have it feel smooth.
22 comments
Oct 13, 2010. 9:25 AMEagleGrip says:
so do you solder the rumble motor and the LED to the same terminals?
Mar 14, 2009. 5:22 PMBert99 says:
How did you learn to do all of this?
Jun 16, 2008. 8:11 AMZephron says:
The B button is awesome, but wouldn't the same "light on rumble" work with the A button mod?
May 1, 2008. 1:59 AMcraig3 says:
im guessing that the +is on the left and the - on the right?
Apr 30, 2008. 7:14 PMnintendude49 says:
any idea what the voltage would be there?
Jan 8, 2008. 9:10 PMianlikescake says:
If you can make it so the b-button has the rumble mod. Could you solder it so the a button lights up when it rumbles?
Apr 27, 2008. 9:09 AMcraig3 says:
Do you mean by that that all you need to do is solder some longer wires from the rumble points so the LED can reach the A button?
Jan 10, 2008. 7:21 PMianlikescake says:
Ya that would be good i cant find a tutorial anywhere else on how to do it.
Jan 12, 2008. 12:18 PMweretater says:
yes that would be AMAZING! P.S. how do i get the faceplate off? its like, attached near the IR part, and like all of the buttons fell out and i cant get em back because I'm afraid the plate thingy will snap!
Apr 27, 2008. 9:08 AMcraig3 says:
sorry if it is dumb, but the only picture in step 2, is that the solder points to make it light up when it rumbles?
Jan 2, 2008. 8:02 PMcraig3 says:
Would it work still if i used the + and - shown in here for both the B and power button LEDS?
Jan 2, 2008. 3:52 AMcraig3 says:
good man, I'm a fan of your work All i need is a quick trip to dick smith and i have myself a fancy new Wii mote Actualy, does it matter if the Wiimote is rechargeable battery? i dout it but i just wanna make sure
Jan 1, 2008. 3:20 PMGorillazMiko says:
Awesome job, looks great, I will have to show this to my friends maybe. Nice work!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:Wiimote Master
