3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wiimote Modification for Persons with Disabilities
This instructable will show you how to rewire the button of the Wiimote to bigger buttons so that persons with disabilities will be able to efficiently use the Wiimote by not having to press the small buttons on the Wiimote. The buttons that will be rewired will be the A button, B button, the directional pad (up, down, left, right), and the Home button.
Update:
An updated wireless version of the adapted Wii-mote using an Arduino board and Xbee wireless circuits can be found here.
Step 1Soldering Tips Before You Begin
To solder very small items follow the following procedure:
1. Spread some soldering flux on the components you wish to solder.
2. Gather a bit of solder on the tip of your iron.
3. Touch the components together.
4. Give the components a kiss with the soldering iron. The solder on the tip should transfer to the components.
Take care not to put to much solder on the tip of the iron, doing so may result in the bridging of two or more components you don't want soldered together.
4 comments
Aug 5, 2010. 11:38 PMRonnieJi says:
oh man, that is huge!
Jan 5, 2010. 2:10 PMpcmonkey says:
as an arm amputee this is GREAT!!!!    would you mind contacting me so i can get more details??
Dec 28, 2009. 6:23 PMluckycherms says:
Dude your awesome
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:oalbrecht(REAR laboratory)
The Rehab Engineering and Applied Research (REAR) Lab undertakes applied research and development targeting the increased health and function of persons with disabilities. Specific areas of interest i...
more »
