3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wiimote Modification for Persons with Disabilities
Step 9Assemble the Wiimote
Finally the Wiimote is ready for assembly. To begin place the buttons in their original slots in the top case of the Wiimote. Then lower the circuit board in place while using miniature flat-head screwdriver to maneuver the wires. Depending on the diameter of your wires you will probably have to make a few modifications to the top of the case to make enough room for the wires. Once the circuit board is flush with the top case bring in the bottom case. Making all of the everything fit within the small space available on the Wiimote will require a lot of patience and finesse. But don't be discouraged, it is possible to fit everything within the Wiimote.
Once everything fits in place, tighten the triangular-head screws back on the case. Finally put in the batteries and try out your Wiimote. If your Wiimote doesn't work make sure to try it out with brand new batteries before disassembling it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:oalbrecht(REAR laboratory)
The Rehab Engineering and Applied Research (REAR) Lab undertakes applied research and development targeting the increased health and function of persons with disabilities. Specific areas of interest i...
more »
