3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wiimote Rubens Tube: Control Fire With Sound! (And a Nintendo Wiimote!)
A Ruben's tube is essentially a demonstration of standing waves in air.
Numerous very small holes are drilled at lengths through the top of the tube and propane or a similar gas is fed through it. By forcing sound waves into the tube through a speaker at one end, varying areas of pressure are created. The higher flames occur at points of higher pressure (nodes) and smaller flames at lower pressure (antinodes).
I'll even show you how to control the sound with a Nintendo Wiimote so you can play god and control fire with gestures.
This is an easy physics experiment that might take a little time to assemble the parts, but the construction of which is straightforward with a fantastic reward!
REMEMBER!! Anytime you are dealing with fire, take the necessary safety precautions such as :
--Clearing the area of all flammable substances
--Using care when adjusting the propane valve
--Use ONLY in a well ventilated area
--If underage, operate ONLY under the supervision of a responsible adult
To help you remember, here's a safety haiku:
Danger! Hot Fire!
Keep Space Clear of Kids and Pets
Poor Burning Puppies
Step 1What the heck is this?
A bit of history from Wikipedia:
"August Kundt, in 1866, demonstrated an acoustical standing wave by placing seeds of lycopodium or cork dust in a tube. When a sound was made in the tube, the material inside lined up in nodes and antinodes in line with the oscillation of the wave, creating a standing wave. Later that century, Behn showed that small flames could be used as sensitive indicators of pressure. Finally, in 1905, using these two important discoveries, Heinrich Rubens, whom this experiment is named after, took a 4-metre-long tube and drilled 200 small holes into it at 2 centimeter intervals, and filled it with a flammable gas. After lighting the gas (whose flames all rose to near-equal heights), he noted that a sound produced at one end of the tube would create a standing wave, equivalent to the wavelength of the sound being made."
In many basic physics classes the Ruben's tube is used as a proof of the equation frequency = speed of sound/wavelength. Students can measure the wavelength of the standing wave (very carefully as not to burn themselves from flame maxima to maxima). Then, because the speed of sound at sea level in propane is 235 m/s, the students can attempt to guess the frequency being played into the Ruben's tube. The speed of sound in air is normally 344m/s, but because propane is almost twice as dense as air, the speed is lower in propane. (Well, not quite because it's twice as dense, but we'll leave it at that oversimplification for now.)
As the sine waves are played through the propane, they compress the propane in certain sections thereby increasing its density. This in turn increases the pressure, and because the area is at a high pressure (and air likes to flow from high to low pressure... thank you Le Chatelier) more air molecules are forced out these holes in an effort to reach equilibrium causing the flames rise higher. In areas where the propane is not as compressed, the area specific pressure is lower resulting in lower flame heights. Essentially when you are visualizing the wave with fire you are seeing a standing wave. These areas of high pressure are known as pressure nodes, and contain the highest flames (most of the time but we'll get to that in a minute) whereas the areas of relatively lower pressure are thus antinodes and yield smaller flames.
Since we know that frequency (f) equals speed (v) divided by wavelength (lamba) we are able to quantitatively determine the frequencies running through the Rubens tube. (f=v/lambda) Now, when doing this, remember that "v" is not the velocity of sound in air, (roughly 344 m/s) but rather the velocity of sound in your gas ( in this case propane, so 235 m/s). Also keep in mind that elevation and temperature affect this, but 235 is a good estimate. So, measure your wavelength from peak to peak (flame maxima) or trough to trough (flame minima), plug into the equation, and you get your frequency.
Reader Challenge: Now, you might notice an interesting effect once the gas is turned off. Yes, the flames persist if the sound is still on, no big deal. But take careful notice where the flame maixmas and minimas are. If you'll notice where the flame used to be at a high with the gas on, it is now at a low. The tubes nodes/antinodes have now switched places! Explain how this happened and you get an extra cookie!
After much digging at the college library, I was able to unearth the original journal publication by von Heinrich Rubens:
It was published on December, 8th 1904 in the Verhandlungen der Deutschen Physikalischen Gesellschaft- a German physics journal. Although I don't speak German, in my research, I was able to find out a few things. The original tube used was brass. It was four meters long, 8 centimeters wide, and had about 100 holes which were each about 2 mm wide. He used Coal Gas which was inserted on one end through a brass cap, and then covered the other end with a rubber diaphragm. Interestingly his sources of sound were bells, an organ pipe, or tuning forks.
After all this work experimenting with different tube designs blindly, and without knowing much about the tube's origins, I admittedly had a rather geeky adrenaline rush holding the actual journal in my hands and learning the origins of this project. I included 4 pictures of page scans from the journal if anyone speaks German or is further interested!
55 comments
1-40 of 55next »
Sep 15, 2011. 12:01 PMThe Scientartist says:
Yay for Blue Man Group!
Apr 26, 2011. 1:54 AMnamit says:
We made this over last weekend for event coming up have few improvements to make but very nice.
Its 9 feet hight with 150 hold 2mm wide drilled ever 1.5mm in staleness steel.
For more videos and to see other revisions, http://www.tog.ie/
Apr 22, 2011. 4:51 AMJanitorial16 says:
It looks like the bellagio fountains at night :-)
Mar 3, 2011. 11:05 PMsn0manX says:
instead of pvc could i just use metal end caps, brass fittings, and whatnot?
Mar 26, 2011. 3:35 PMKaoticmodz says:
(removed by author or community request)
Mar 27, 2011. 12:27 AMsn0manX says:
why not? it seems more logical
Dec 19, 2010. 9:17 AMbudsiskos says:
about what is the life of one of the propane cans when used for this?
Aug 5, 2010. 11:35 PMRonnieJi says:
What exactually is this for?
Jun 17, 2010. 12:00 PMHandy_Andy says:
I don't know if it's been mentioned already, but I think you got the nodes and anti-nodes backwards in the intro (as far as i can remember from physics class last month). Nodes are low pressure points and anti-nodes are the points in between the nodes. Otherwise, nice Instructable. http://hyperphysics.phy-astr.gsu.edu/hbase/waves/funhar.html#c3
Jun 10, 2010. 8:58 PMwocket says:
so friggin cool!
Jun 3, 2010. 4:00 PMyoyology says:
Amazing Instructable.  Cool build, clear explanation, and well-researched background info.  Extra points for digging up Rubens' original work AND the haiku!
5 stars, my man.
Aug 30, 2007. 6:38 PMjazzu says:
Could you make a video with the music patched in directly to the tape? The echoy nature of the space you performed in kind of interfered with interpreting the effect of the music on the flames. Not that I'm complaining, it would just be very neat to see the effects with a proper soundtrack (kinda like the "Wizard of Winter" video with the christmas lights).
Feb 16, 2010. 7:27 AMstukass says:
now imagine that was ur neigbor, going to bed with that every night,  itll be cool for tghe firs five seconds
Oct 8, 2007. 7:05 AMBuffaloNickel says:
holy shamoley
Jan 14, 2010. 11:26 AMM4industries says:
 I love the safety haiku!
Oct 1, 2009. 11:04 AMmaranathabeery says:
We really want to build this, but the pages that are linked for the wii are down. Any reccomendations?
Nov 2, 2008. 6:21 PMAndrew10 says:
whats better # Galvinized # Steel # PVC # Aluminium irrigation pipe to use for tubing
May 9, 2009. 7:42 PMschetleft says:
do not use pvc it will melt. galvanized will create a stinky chemical reaction do not use. aluminum is cheap but idk if it will work. steel works.
Aug 5, 2009. 3:58 PMtheghillieman says:
But aluminum does have the lowest melting temp (around 1200 degrees) and steels is in the 2,000's
Nov 25, 2008. 6:49 PMReCreate says:
hmm,no video showing at least the flame...Add a video and also dont add it from youtube just an .avi file
Nov 2, 2008. 6:19 PMAndrew10 says:
Good experiment_ What is the dimensions you used for the tube...... And the material, from what I've seen and heard galvinized pipe should explode in this experiment. Can you please tell me what material you used???
Jan 4, 2008. 12:58 PMlunasol321 says:
that was a lot of fun to build. thanks for the great instructable.
Aug 30, 2007. 4:20 PMBlackross says:
Instead of a straight pipe, would a curved tubing work? or square (might not with that one) but i was thinking about covering a good frequency range and coiling it and placing it into my fire place.
Aug 30, 2007. 5:52 PMburzvingion says:
I may be interpretting you wrong, but it sounds like you're thinking that a longer tube will give you a greater frequency range, right? Actually, the frequency response is affected by the length of the tube, but not the frequency range per se, because it isn't a spectrograph, it's just showing the areas of constructive and destructive interference. So there is some fundamental frequency which is a function of the speed of sound in the devices environment and the length/shape of the tube. Then any harmonics of that frequency will also create pretty patterns on the tube. So a longer tube will show you more (higher frequency) harmonics. Perhaps that's what you mean by frequency range. If so, then disregard this comment, but just checking.
Dec 27, 2007. 11:33 PMstevens1988 says:
I wonder if the effect would be more grand if you were to use a 6" pipe 10' long with 1/8 " or maybe 3/16 " holes and a 6" 2-way speaker a propane tank from a grill with a larger supply line , and a electric igniter to remotely light the gas , with a electric soleniod valve to turn the gas on and off . any thoughts ?
Aug 30, 2007. 6:06 PMBlackross says:
Chart from other Indstructable
the chart above from another instructable that was posted shows length versus frequency.... sorry just off from 10hr work day an not thinking right mind, but yeah what you said was what i was asking.
Jun 10, 2010. 9:02 PMwocket says:
that sort of research sounds fascinating. don't suppose you could do a link dump here, or pass on some recommended reading? I've recently decided to get into all of this wonderful Victorian era science.
Aug 30, 2007. 5:45 PMBlackross says:
cool, have you tried different size speakers, like a small simple headphone speaker? since all i've seen are ones that use larger speakers and vent tubing... although yours uses smaller tubing which is cool, but desktop speakers.
Oct 23, 2007. 6:55 PMJ_SCAP says:
screw controlling fire i think you just invented the new electric instrument that requires body movement try hacking the wiimote and making it look diffrent and sell the thing and you will become rich
Oct 9, 2007. 5:47 AMphenoptix says:
Fantastic. I need a wii and a Ruben's tube for that matter!!
Sep 10, 2007. 7:41 PMBrandon121233 says:
Try Golden Slumbers by the Beatles, Baba O Riley by the Who, or Sow by Red Hot Chile Peppers they all work really well with a Rubens Tube.
Sep 1, 2007. 9:33 PMBrandon121233 says:
So I just got a prototype working with 1/2" copper pipe and a funnel design, I'm ganna expand on it a little more, but it works:
Aug 31, 2007. 2:52 PMAnimattersInc says:
Just out of curiosity, is this something that you could indeed run for a long period of time without worries or are you limited to 5-10 minute durations?
Sep 1, 2007. 1:24 AMAnimattersInc says:
Well, what fun that was. Here's what I did (and perhaps you can help me troubleshoot). My local hardware store only had a 1 7/8" galvanized pipe (and end pipe for chain link fencing) so that's what I was working with. The pipe is 6' 6" long and I left it at that length. Per instructions I started 6" from one end and went up to the 48" mark for a total of 81 holes. This left about 2 feet to the other end. I found a PVC sleeve that slipped over the ends of the pipe and on one side affixed a loose speaker the same diameter (just a touch larger actually) and the other end had the req'd reducers to the fuel line with a drilled out nozzle on the regulator. Inlet on 24" end / speaker on 6" end resulted in decent effect but nowhere near as pronounced. Inlet on 6" end / speaker on 24" end resulted in little to no effect. I suspect two things: One - the speaker not only may be too weak (especially when not enclosed in it's factory casing) but I believe the multimedia setup with subwoofer incorporates a crossover to limit the frequencies passed to the satellite speaker I used; and Two - perhaps my pipe diameter is too small or the excess on the end is too great. Any pointers? I'm close but still far somehow. My apologies if this is not the forum for this.... Thanks for a fun night in the workshop BTW.
Aug 29, 2007. 12:26 AM5Volt says:
.....Playing with fire AND a Wiimote at the same time....a dream come true ! A +++ Almost forgot: tried with some psychedelic like Pink Floyd ? They have long standing notes which should add a lot to the effect. Best wishes
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:ScaryBunnyMan
