3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wiimote Whiteboard Set up
The reason for this is to show how to use a wiimote, a bluetooth usb adapter, computer and software to create a low cost tablet screen out of your current monitor with the components just listed.
i made this after seeing johnny lee's video and thought id show my try at it
im a mechanical engineering student and just found this cool
heres johnny lee's instructable for it
Step 1The Ir pen.
The Ir pen.
the first step is building the infrared pen. the wiimote is used as an infrared sensor connected to the computer via bluetooth.
I used an ir led, small momentary switch, and a AAA battery. this all fits nicely inside an empty marker.
on the end i placed a piece of foil to reflect the light at all angles.
44 comments
1-40 of 44next »
Oct 27, 2011. 2:53 PMgnoseon says:
Do you need a wiimote Plus controller ($40.00), or a regular wiimote ($20.00)?
- Gnoseon
May 6, 2012. 4:24 PMRonnieJi says:
There are some connection issues with the new wiimote plus, you'd better stay with the regular wiimote.
Ronnie Ji
http://www.iwiiboard.com
May 5, 2011. 6:25 AManshmalhotra90 says:
i have an external bluetooth device but it not detect the wiimote..
what i do know??
Sep 15, 2010. 6:22 AMboonjin says:
In addition, you can use Smoothboard's Calibration Window to help with the positioning and adjusting the Wiimote's orientation.
This will help you to increase the tracking utilization by placing the Wiimote as close as possible to the screen while ensuring that the whole screen area is captured.
Regards,
Boon Jin
http://www.smoothboard.net
Aug 1, 2010. 8:04 AMRonnieJi says:
I agree with shakespeare1212. Windows 7 does has some problems with the "Bluetooth stack", that's why we need the software like iWiiBoard (http://www.iwiiboard.com) which can help you automatically search and add your wiimote. It's very convenient. If you have to do it step by step yourself, it will cost you time and trouble.We always like free stuff,but the inconvenience or the trouble is the cost.
Jul 12, 2010. 1:22 PMshakespeare1212 says:
Your best rule of thumb is to place your Wii remote at a distance 2 times that of the high of your display. For example, if your display is 4 feet high then place the Wii remote 8 feet out from the screen. Video projectors work much better then just your computer or laptop screen. I know that they are expensive. But they are awesome to watch movies on too. Check out the awesome uses that I put them to at: http://whaleboneir.com/numsets1.html
Jul 12, 2010. 1:17 PMshakespeare1212 says:
Windows Vista, and Windows 7 now have a built-in "Bluetooth stack". They work well. They are free, but they do sometimes take longer to connect because they are always trying to go out to the internet and update themselves, as soon as you turn them on.
Apr 1, 2010. 7:16 AMRonnieJi says:
We can expect the wiimote whiteboard on the cellular phone with an embedded mini projector  very soon.(Just a thought...)
Ronnie Ji
Jan 15, 2010. 6:22 PMtoogers says:
am easier way to make the pen write more smoothly is to put the led facing out of the back of the pen, then just do the same thing. you would still hold the pen in the same way, but the led will face outwards.
Jan 28, 2010. 4:39 AMboonjin says:
A potential issue with this method will be the tracking may not be accurate. As the IR point is away from the screen, the mouse cursor may end up away from the actual clicking position based on the tilt and orientation of the IR pen.
Boon Jin
Dec 23, 2009. 12:46 AMRonnieJi says:
http://www.penciil.com/
has a very nice ir pen too
Oct 5, 2008. 6:46 AMirpensonline says:
If anyone is interested I am making IR Pens to support this project.
http://www.irpensonline.com
Thanks,
Tino
Dec 30, 2008. 11:06 AMlolcat360 says:
They cost a whole lot!
Apr 17, 2009. 6:09 PMthen says:
they're only $20, not that much, although there's always shipping...
Dec 7, 2009. 8:17 AMtheXmaker says:
20$ ^ not too much??!! :O man it doesn't cost more that 1$ to make one by urself!, althought it's very easy to make!
Dec 30, 2008. 11:01 AMlolcat360 says:
Whoa, is that your website?
Sep 19, 2009. 8:25 PMmideivalmenace says:
I think this project is awesome. I've started to make my own... is an IR LED a regular LED? what does an IR look like
Nov 18, 2009. 5:16 PMdokworm says:
 An IR LED is an INFRA-RED LED, like the one in the end of a TV remote control. The one from VISHAY mentioned is by far the best one to get, using other ones tends to end up with not a very good result.
Oct 15, 2009. 4:48 AMboonjin says:
You can take a look at boonjin.com/smoothboard/index.php for instructions on how to make your own IR pen.
The IR LED looks like an ordinary LED but the light emitted is notvisible to the human eye. You are recommended to get the VishayTSAL 6400 IR LED for optimum results with the Wiimote.
You can check whether the IR pen works by using your mobile phone'scamera as the camera usually will be able to capture the wavelengthemitted by the IR LED.
Regards,
Boon Jin
Nov 18, 2009. 5:15 PMdokworm says:
 Why not just mount the LED on the rear of the pen, facing the wiimote?
Oct 11, 2008. 7:37 PMJellyWoo says:
how do you connect the pen together?? can you have a picture of the internal guts and tell me what's connected to what? thanks. greatly appreciated.
Oct 13, 2008. 1:30 PMJellyWoo says:
um... yeah.... what you call "simple" is hard for me. i don't know how you connect everything together.
Oct 13, 2008. 1:31 PMJellyWoo says:
like how do the wire's and crap connect and the positive and negative.
Oct 13, 2008. 2:47 PMJellyWoo says:
oh, and do you have to use a resistor?
Aug 17, 2008. 3:38 AMdegroot says:
Hi, I have made everything working. Still it is not working smooth. I can't draw a nice smooth line. Only interrupted and with sharp-edged lines. 1) The WII is half a meter from my screen and my USB 2.0 Bluetooth adapter. 2) My PC: Operating System: Windows XP Version: 5.1 Service Pack 2 Physical processor count: 2 Processor speed: 2992 MHz Built-in memory: 2000 MB Free memory: 1775 MB USB bluetooth 2.0 3 Mbps 3) I have changed all battery's. What can it be?
Oct 12, 2008. 1:59 PMdroob says:
You say you used a piece of foil to make the light visible from all angels can you explain further. ie where did you put the foil? On the tip of the led ? Was it just a small piece of foil?
May 22, 2008. 4:11 PMJellyWoo says:
nice instructable. where can you get a ir led and small momentary switch?
May 5, 2008. 6:04 AMmunchman says:
You should probalbly credit Jhonny Lee for this. Besides that, Great instrucable. I'm gonna try this - as soon as I get a wiimote. Lol
Dec 21, 2007. 11:49 AMnickdisney says:
sorry guy, somebody beat you to this already. now if only someone would port the program to work on Mac...
Mar 29, 2008. 9:36 AMBeanBot says:
theres this for the mac i have it
Dec 21, 2007. 5:15 PMHawaii00000 says:
Mac Mac Mac Mac Mac PLEASE
May 13, 2008. 4:25 PMjli1 says:
Just emu XP on your mac. (via bootcamp or parallels desktop)
May 13, 2008. 5:31 PMHawaii00000 says:
Actually it came out a bit after I posted this comment.
May 26, 2008. 7:45 PMdata23 says:
Where have you been? Parallels has been out for a while!
May 20, 2008. 5:55 PMjli1 says:
not parallels
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:volcomsnowboard
