Step 2Installing the Conversion Package
1. Download and extract XP_Vista_Conversion_Package.rar
(Disclaimer) I am not the author of all the included files, but collected them freely from across the web. As far as I am aware, I am not violating any copyrights by distributing them and will cease immediately if requested by the author. The original version of this guide is also included within. I suggest using Winrar to extract the files.
2. Drag the fonts from XP_Vista_Conversion_Package\Fonts\SegoeUI to C:\WINDOWS\Fonts
3. Drag the contents of XP_Vista_Conversion_Package\Theme to C:\WINDOWS\Resources\Themes
4. Drag the contents of XP_Vista_Conversion_Package\Wallpaper to C:\WINDOWS\Web\Wallpaper
5. The Vista screensavers are located in XP_Vista_Conversion_Package\Screensavers\Vista Screensavers; some sweet extra screen savers are in XP_Vista_Conversion_Package\Screensavers\RSS. Drag the contents of either or both into C:\WINDOWS\SYSTEM32
6. Make sure you can see hidden folders (My Computer-> Tools-> Folder Options-> View tab-> select Show Hidden Files and Folders-> OK), then drag the contents of XP_Vista_Conversion_Package\User Images into C:\Documents and Settings\All Users\Application Data\Microsoft\User Account Pictures\Default Pictures. You can undo that setting immediately afterward if you wish them hidden again.
7. IN XP_Vista_Conversion_Package\Enhancements, run setup.exe to install Cleartype. Allow it to run after installing, checkmark the box to turn it on, then click OK.
8. In XP_Vista_Conversion_Package\Enhancements\Aero Cursors, right-click the Install.inf and choose Install.
9. Drag Vista.Emulation.dll from XP_Vista_Conversion_Package\Games to C:\WINDOWS\SYSTEM32
10. Run any of the setups in XP_Vista_Conversion_Package\Games to automatically install them on your PC. Shortcuts will be located in the Start menu under 'Vista Games.'
11. If you have SP2, run UXTheme Multi-Patcher 5.5 in XP_Vista_Conversion_Package\Programs. Make sure you read the dialog boxes carefully, and do as they say! If Windows file protection pops up, you have to cancel, not allow it, and reboot when asked. If you get an error saying an i386 folder was found, just move or rename that folder while running the UXTheme patcher. You can change it back immediately after.
11a. If you have SP3, the included UXTheme Multi-Patcher will not work. Instead, grab the latest UXTheme patcher from here. This will work on either SP2 or SP3 versions of XP. It wasn't included in the package as SP3 wasn't released when this was written. If I get enough requests, I'll do a refresh of the downloads that include new files.
12. After rebooting, click Start-> Control Panel-> User Accounts-> click on your account, and choose Change my picture. Yes, we now have the Vista user icons to choose from. Select one if you wish, click Choose picture, then close the User Accounts window. If your picture didn't show as changed there, don't worry, it is. You can verify in the Start menu.
13. Open Display Properties (right-click desktop, choose Properties). On the Desktop tab, click Customize Desktop, checkmark the icons you want on your desktop, then click OK. Now on the Theme tab, choose Vista from the dropdown and hit OK. Our hard work pays off, huh?
Troubleshooting:
- If the screensavers won't run and show an error, there's two possibilities. First, make sure you aren't using the default Microsoft driver for your video card. Download the latest nVidia, ATI, etc driver that supports OpenGL and D3D. Secondly, if your card is very old, it may not be capable. I've run into a few of those, but 95% of the machines I rebuild work fine with them, if a little slow on the 8MB cards ;)
- If you have a beta version of XP Service Pack 3 installed, UXTheme will likely show an error and not work. In that case, you can use the 11a instructions, or try grabbing the latest UXTheme patcher for your build number here. If your build number isn't listed, you should be able to download the prepatched dll itself, then either reboot into Safe Mode to replace your current dll, or use Replacer. It's a little more of a manual method, but should get your themes up and running.
- If you went through all this but your Vista theme has the classic "Windows 98" look to it, go back to step 11. Something didn't go right when you ran UXTheme. Sometimes, if XP setup files are on your hard drive, it will undo the patch. As the pop-ups dictate, choose to keep the new versions if asked. Usually problems are just caused by hitting 'OK' all the way through without paying attention to the instructional pop-ups. In this step, remember, we actually have to hit 'Cancel' once! Take this as your first lesson in not going glassy-eyed and speed-clicking through installations ;)
- The games, especially Purble Place, will also need a decent videocard and CPU to run. If you're patient, the card games function on even a 500MHz with an old ATI Rage Mobility. The games are located under "C:\Program Files\Microsoft Games\" when installed. To uninstall, just delete the corresponding folder from that directory, as well as the Start menu shortcut.
- If your XP installation is on a drive other than C: (E:, for example) then the Vista theme will not work properly when selected. To resolve this, simply follow these steps:
2. Right-click Vista.theme, and choose Open With-> Choose Program
3. Select Notepad, then click OK
4. Now within notepad, click Edit-> Replace
5. Under Find what, put C:\
6. Under Replace with, put E:\ (or whatever your drive letter XP is installed on)
7. Choose Replace All, then close the Replace dialog box
8. Close notepad. When it asks if you want to save, choose Yes.
You should now be able to select and apply the Vista theme without errors.
What exactly is the "it" that I should not allow?
Use Winrar or 7zip to extract.
