3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind Generator from old scanner [updated]
I'll show you how to recycle an old scanner into an amazing wind generator.
You need it, clean energy!
Step 1What you need?
What you need:
- Old scanner
- Rectifier diodes (I used 8 1N4007)
- 1000uF Capacity
- LM7805 (voltage regulator for 5 volts)
- PVC pipe (for blades)
- Plastic square (for tail)
- Aluminum pieces (i used alumynum, but you can use what you want)
100 comments
1-40 of 100next »
Nov 15, 2010. 6:10 PMtomtortoise says:
yo which pulley should i get and are there metal ones??? and do i need to remove the pinion gear and how.
Jun 8, 2008. 11:09 AMjavotech says:
Sep 12, 2010. 12:08 PMrikkiesix says:
Hi there.
Can you tell me what part it is u used for making your turbine pivot.
There are some bearings in it i see.
Greetings from Belgium
Erik
Feb 13, 2009. 8:05 PMDeanC993 says:
sorry i keep commenting but is your stepping motor MITSUMI M42SP-4NK LOT NO.T G 6117 if so i af the exact same motor as you is it from lexmark?
Jul 13, 2010. 1:00 AMstormthirst says:
The make and model of motor shouldn't make a difference, provided that it's a stepper motor, which is rated to have approximately the same output. What it comes out of is irrelevant.
Apr 5, 2010. 6:01 PMazngiant1212 says:
 I have made one with a PM55L-048 Stepper Motor took from an old HP Deskjet printer. But I need a rectifier circuit for my stepper because it is a unipolar I think with 5 wires coming out from it. Please Help! Thanks.
Jan 18, 2010. 6:28 PMrandommate says:
 hey neat instructable.  i have been trying to think of something of this size as well.. any chance you could update with more info on the range of output your turbine can supply? cheers.
Aug 1, 2009. 9:28 AMmrjtwill says:
how did you build the hub so you could attach the blades?
Aug 25, 2009. 3:35 AMelectronic boy says:
The hub/meccano pulley has holes for meccano screws already in it
Aug 25, 2009. 3:24 AMelectronic boy says:
how in gods name did you get that fiddly gear off of the end of the stepper motor
Aug 25, 2009. 3:19 AMelectronic boy says:
if you want to light a bulb then your best bet is to put a charging circuit and a battery so your light dose not flicker if there is no wind
Oct 23, 2008. 11:44 PMJr Hacking kid says:
it he meccano gear this one? =D
Apr 11, 2009. 1:46 AMJr Hacking kid says:
its metal look it up in ebay its a 19b part i think google and macth the pics ok
Mar 12, 2009. 3:11 PMhappybiscuit23 says:
Is the gear metal.?
Feb 20, 2009. 1:39 PMhappybiscuit23 says:
Is this metal or plastic? I found the plastic one to break very easily, it would only take a light wind. This one is made of the same plastic all the new meccano kits come with, it chipped away and is cheap enough that I would not reccomend its use.
Jul 27, 2009. 9:32 PMJr Hacking kid says:
metal its called a "meccano 19b"
Feb 19, 2009. 4:52 PMemdarcher says:
where did you get the old scanner?
Feb 18, 2009. 7:03 PMslinger14 says:
could you use a zeiner diode to by-pass the 7805 when the voltage is under 5 volts?
Feb 17, 2009. 2:31 PMDeanC993 says:
hi could you just hook up a light to the generator i have the same generator as you and i only want to light a bulb of it o you know how i could do it?
Feb 13, 2009. 5:22 AMDeanC993 says:
(removed by author or community request)
Feb 13, 2009. 5:48 AMclark says:
thats what he is using, so i'd say yes
Dec 6, 2008. 9:23 PMciaagent says:
Hey everyone, I'm still working on mine, got some big gusts and broke 2 of the blades... topped out at .005V... I must have fried a diode during soldering. So I fixed the blades and never put it back up (bad move) and I dropped the blades and broke one of the previous broken ones again, so here I am fixing it... anyways, if you REALLY want to follow me, head on over too http://ciaagentswindmillblog.wordpress.com/ where I will post about it.
Dec 3, 2008. 12:19 PMgilles99 says:
your third picture have a mistaque with your graetz
Oct 22, 2008. 2:33 AMgaryuou says:
Hi, everybody! New energy industry is developing at high speed, and it does have a bright future. Do you guys realize this? If you interested in wind turbineor need any information, you can contact me.
Oct 9, 2008. 8:05 PMciaagent says:
Update on mine, Bad news. We got a windstorm and I seen it going too fast, so I thought I'd take it down. I go out there and lift the pole out of the ground and the blade slowly moved forward an inch, then tilted down. I then though that I didn't feel like being decapitated, so I dropped the pole and ran. As I watched it fall, I realized what a bad mistake that was. It hit the garden and broke two blades off. Luckily, they were on opposite sides so it still works. Good news: I finally got something for a bearing, and came up with a design for the thing to transfer electricity down the pole without wires. I will flatten copper pipe and use some kind of brush to rub them. So this is my update, and its a long one. Stay tuned for more.
Sep 24, 2008. 5:41 PMciaagent says:
Hey everyone, update on mine: I finally have it up temporarily, (its in an underground sprinkler hole with broks around it and no electronics hooked up) anyways, here are some images: I know it leans, but its only temp.
Sep 26, 2008. 7:49 PMciaagent says:
I hooked up the electronics, I only get .004V. If i spin it really fast by hand I can barely get 1V. Looks like I need to fix something. When I was soldering last night, I got a drop of solder on one of the rectifier diodes so I'm thinking that killed it.
Sep 25, 2008. 3:27 PMciaagent says:
Of course there would be a wind storm after I put it up... I guess I should move the cementing the pipe in the ground to a priority, luckily, the hole it was in kept it from falling down completely. I am getting good RPM's out of it, I do not know the voltage yet as I don't have the rectifier circuit hooked up.
Sep 24, 2008. 5:43 PMciaagent says:
*sorry, I meant bricks, not brocks.
Jun 26, 2008. 11:33 AMdanlab says:
I have a stepper motor which has 5 wires, black being a common lead, does anyone know how to rectify it, if it is possible? down below is a picture of the wiring diagram that came from the manufacturer p.s. Great Instructable, just wish I had an old scanner I didn't need
IMG_1958[1](2272x1704) 1 MB
Jul 20, 2008. 2:11 PMdark sponge says:
Try this
Jul 20, 2008. 12:03 PMgadget_brain says:
Get a hold of an old HP inkjet printer they have some nice motors. 500, 600, 700 series (and probably most any of their inkjets). I've gotten some nice 5 wire stepper motors out of them. There's also a nice DC motor which would work well.
Jun 29, 2008. 12:37 PMdark sponge says:
I just took apart a printer, and one of the stepper motors is almost exactly like that one (for some reason there were two motors, and it was just a plain printer without a scanner). I will use the diagram and try to figure out how to rectify it. If I do, ill post it
Jul 20, 2008. 11:59 AMgadget_brain says:
Most printers that I have taken apart have 2 motors. One for moving the paper through and another for moving the print head. HP 500, 600, 700 etc series printers have a really nice stepper motor for moving the paper and a really nice DC motor for moving the print head.
Apr 22, 2008. 4:23 PMmikemmcmeans says:
my motor came out of a HP scanner it has 6 leads 2 for separate coils should i make a 6-way rectifier or is there a better way
May 22, 2008. 4:31 PMmikemmcmeans says:
thanks that was a great explanation but any idea how i would know which wires are the right ones on the coils?
Jun 8, 2008. 11:16 AMjavotech says:
look at the scanner circuit board, maybe some wire wasn't connected to any component. or use a multimeter (on ac). good luck!
Jun 3, 2008. 6:55 PMTheNerdGroup says:
Nice work
Im going to use this with my newman engine, : v)
Bill - N.e.R.d. Group
Apr 17, 2008. 8:15 AMbtop says:
Ok, mine is done :) Heres the flickr photo stream. PHOTOS
1-40 of 100next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Tigrezno
