Step 3Building the rectifier circuit
The output of the rectifiers will be stabilized with a 1000uF capacity and a 5v voltage regulator (LM7805 in my case).
Attach some connectors to allow charging different gadgets. I added a female USB connector since my phone and mp3 use USB to charge.
Note 1: this motor can generate easily more than 5V, but i only need 5V by the way.
Note 2: there is an issue with the USB female connector. You need to follow the USB specifications in order to make it work. USB2 charging needs two 15KOhm resistances on the data buses to work properly. Check comments on this instructable for more info: USB charger
Note 3: I used this free software for circuit simulation: QUCS
It lacks of some components right now, but it's great after all.
UPDATE
Still can't get usb charging on my phone. My mp3 charge ok, i think it's USB1.
comments
Add Comment
Add Comment
