Wind power is a favorite for makers and amateurs interested in renewable energy, chiefly because the technology involved is simple and accessible. While solar, hydroelectric, tidal and biogas are difficult to achieve on a small scale and small budget, wind power has simple requirements that put it within reach of many hobbyists.
The only real requirement is an electric generator and some way to make it turn. These Instructables cover a range of wind power designs, from the traditional turbine-on-a-mast to more unusual vertically rotating generators, that are mostly constructed using simple and easily available tools and materials.
Power distribution (city power) uses AC because it can easily be transformed up or down in voltage - up to high voltage for transmitting over long distances (because, for a given load, higher voltage means lower current - and hence less voltage drop, and much less power loss) and then down again to 120v or 240v to supply your house (because several thousand volts in the house is somewhat dangerous!)
I believe that the use of alternators in cars came about because it's easier to get an AC alternator to give a suitable voltage (around 14v to charge the battery) at idle speeds as well as at full revs than it is for a DC dynamo.
How I built an electricity producing wind turbine has some information about battery management systems in it- perhaps you could get in touch with mdavis19 to see how he tackled the problem?
