Step 1Gathering Parts
1.) 25mm Venetian blind louvre (8 cm) 8 pieces required - for turbine blades
2.) 6mm wooden dowel (8 cm) 8 pieces required - for blade arms
3.) 10mm Polyethylene (Cutting board or similar) [40mm diameter] 1 piece required - for turbine hub
4.) 25mm PVC electrical conduit (210mm) 1 piece required - for swinging arm
5.) Hobby Motor - Low torque (Nominal 3 Volts) 1 piece required - for generator
6.) 25mm wooden dowel (260 mm) 1 piece required - for support tower
7.) 20mm MDF (140mm sq) 1 piece required - for base
8.) Banana Socket (To suit multimeter leads) 2 pieces required
9.) 3mm Plastic sheet or stiff card (100mm x 30mm) 1 piece required - for tail fin
10.) Hookup wire (500 mm long) 2 pieces required
11.) Digital Multimeter
12.) Retaining screw to secure motor (3mm x 10mm long with lock nut)
Tools Required :
1.) screw driver
2.) solder iron
3.) drilling machine
comments
Add Comment
rhackenb
says:
Add Comment
