3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind powered Composter - The Green Twist , Exactly
This is my Epilog Laser Cutter entry so please Vote if you think the idea is unique and worth supporting.
Composting is the easiest thing one can do to help your community. With a wealth of good soil you, your neighbors, and everyone else is stuck with the predictament of what to grow. Imagine such a world.
The problem is that the standard composter doesn't turn itself, and the average human is too everwhelmed with life's callings to take the time to turn the composter once a week.
Hence the self turning composter, wind powered so no additional power is needed.
I just added a laundry basket to the inside to help churn the soil. It was turning a 3/4 full load with no problems at all. I had to empty it out to paint it black, but once the winds pick up I will post a video of it turning soil.
The gear drive supplies more torque than it would ever require, I used vise grips and tried to stop it turning but could not. I estimate that I applied about 150 lbs with a moment arm of 8 inches and still it didn't stop! The gear ratio is 1255:1.
You will need:
A drum, or other round item that will server such a purpose. Note that I did not have a drum but I did have a large bucket I bought for 3 bucks at walmart.
Plywood-depending on how big you want to go will determine how much scrap you need. I used about a half a sheet of 1/2 inch ply for the turbine but I think twice as many layers would be better.
2x4's or 2x6's-The frame and upright uses about 2-8ft lengths of one or the other.
Screws-get a box of 3in deck screws, they last forever and are very strong.
A junk gear motor with a high gear ratio is also needed.
Tools-I used a drill press, angle grinder, hammer, screw driver and jig saw. My advice, you can never have too many tools.
Time: It took about a day to make this. I actually did it over the weekend but actual time was about 12 hours.
Step 1First cut out the layers for the turbine
The Vertical Axis Wind Turbine (VAWT) is made up of many identical layers of plywood. First, I cut out a template from foam and used it to mark scrap plywood for cutting.
54 comments
1-40 of 54next »
Jan 22, 2012. 9:30 PMHamish121212 says:
Awesome! Ok - like others I am looking for a gearmotor to build one of these. Are windscreen wiper motors from cars geared down enough to work? Has anyone used a windscreen wiper motor sucessfully - or can anyone answer this question for me before I go out and buy one.
Oct 25, 2011. 7:47 AMdiy_bloke says:
great idea and done very well. Just two remarks (no criticism) The bin is kinda small for most gardens compostable material yield and i found the easiest way to compost is still to just leave it on a heap, no turning whatsoever. It will compost the way nature has always done it without the help of men.
That said: a great project
Apr 25, 2011. 9:00 PMjj.inc says:
I know its been a while, but I was wondering if you may have some ideas. I have a bunch of grass clippings left after we mow the lawn and it would be nice to compost at least some of them. The problem with that is that I would need to contain like 3 to 6 months of clippings. Do you have any ideas for big versions, and also how do you compost just grass. I was wondering if it was necessary to contain or of you can build some kind of box with a stirring device. Obviously this would require a much larger turbine, but that is fine.
Oct 14, 2010. 9:35 PMHasersys says:
Ahh, I like this a lot. Very nice build. It looks nice spinning in the wind like a lawn ornament. HEh Nice to see some one els in the area on instructables. I am in Sebastian.
Jun 19, 2010. 7:48 PMMr. Kimberly says:
Just saw this video on Catapult Design's vertical wind turbines. One metal & canvas design was specifically cited at costing $100, and the blue one is a looker... http://www.good.is/post/mini-wind-turbines/
Mar 17, 2010. 9:29 PMjj.inc says:
 That would work great, and it looks very mobile.
Aug 31, 2009. 7:37 PMmpledger says:
This is really great. Good luck with the next model.
Jun 2, 2009. 12:13 PMFTJ says:
Can anyone provide more information on step 6 - Find a good gear motor? I tried to find something online but I couldn't find anything with such a high ratio (1250:1) What was attached to this gear motor? Essentially, I'm just trying to find out what to ask for at a local surplus store or search for online. Any suggestions, model numbers, keywords? Thanks!
May 21, 2009. 11:34 AMbrianfss says:
Great Job! Fits right in with the Green Theme. Only one little nit picking thing--Get the rust off your drill press table. Your tools will work better and projects will stay cleaner. Take a random orbital sander with a 150 grit disc--spray the table top with WD-40--Sand for a few minutes--Spray again--change to 220 grit paper and sand again--wipe off with a clean cloth and paint thinner--wipe again with a dry cloth. Use a good paste wax on the table and re-wax it every 6 months or so. Again--no complaints on your project--WAY TO GO!
May 21, 2009. 6:29 AMdebpix says:
Bravo on a very clever idea. I don't know how your final exams turned out, but you deserve an A+ on this. You are right about turning a composter being the biggest chore. I'm looking at my huge composter outside my home office window. The beast sits there empty because I'm too lazy to go turn the handle (or fill it, keep it moist, etc.). You didn't win the Instructable prize (though you shoulda), but maybe you can make your first bazillion $ by patenting and marketing it.
May 11, 2009. 6:51 PMload_nikon says:
Upload failed.... try again.
May 19, 2009. 1:15 PMReCreate says:
Google sketchup!
May 16, 2009. 7:48 AMstephenniall says:
I might be getting a small allotment with ma dad and I have a idea for a thing like this but Smaller Thanks this has helped me alot
May 17, 2009. 8:50 AMstephenniall says:
tht isnt a bad idea i have a very strong gear motor out of a old box of car bits i have Bought them all Loads of motors for 2£ (4$) Even a starter motor in the box was well chuffed with myself Anyway That could be a good idea or i could do a verticle Wind turbine to power it Hmm will look into it more Hoping to have it in a small allotment we may be getting
May 16, 2009. 7:45 PMbkt says:
Fabulous! I just started a little garden and really want to start a compost. But with a small yard and busy family the thought of having to turn a tumbler does sort of intimidate me. Anyway, I thought a wind-powered tumbler would be the perfect solution and went about searching for one. I think I'll try to hike up the hole thing so I don't get little curious fingers pinched in the tires. That should also help with getting the turbine higher. And potentially for emptying the barrel... I know very little about composting, but are there supposed to be air holes in the bucket? I think I better do a bit more research before I take the plunge. Thanks for the great and inspiring instructions! I've never been here before but signed up so you could have my vote. Excellent work.
May 11, 2009. 6:48 PMload_nikon says:
Glad to see an old idea of mine was brought to fruition. I've always wondered how big a turbine I needed to turn a good heap of compost with what kind of gear reduction. Here's a pic of mine with a few components not yet drawn in... Kinda large and not too pleasing to look at it. I like your idea's compactness and it's design makes a bold statement to the neighborhood.
Apr 30, 2009. 8:38 AMmacrumpton says:
Great idea! I think the frame and the turbine could be simpler but it is really great. To take it to the next level, if there was some way to make it so that you could drop more stuff in without removing the bucket, and if there was some way to have the composted stuff drop out automatically that would make it even more awesome. My idea for getting the stuff in would be to add a hatch (or maybe attach a cut off rubbermaid container and lid) to the center of the lid of the bucket. maybe the way to get the compost out would be a small hole in the bucket covered with a coarse mesh. The small hole would have a cover to keep the moisture in and only open when the hole is facing down. The big question is the best place for the hole. does the composted material tend to sink or float on the uncomposted stuff? Congrats again on a great project. It is on my favorites list.
Apr 30, 2009. 5:20 PMMaster Roda says:
Great idea. This is worthy of a win.
Apr 29, 2009. 4:02 PMrednhez says:
how do you fill it?it seems like as soon as you open it the compost would fall out.
Apr 27, 2009. 5:09 AMn3rrd says:
I think this idea is incredible. My one question is: why the plywood instead of something like a plastic bucket cut in half (such as Build-your-own-Savonius-VAWT) ? Just out of preference?
Apr 29, 2009. 3:45 PMn3rrd says:
That's cool. Was just curious, and wasn't intending to offend. :) Thanks for the response.
Apr 25, 2009. 10:02 PMimagewizard says:
Saw you at the Dark Sky Festival, My Dad and I were pretty blown away (ahem), by your idea. I suspect my Dad'll be buliding something like this soon! You got my Vote!
Apr 23, 2009. 7:18 AMworkhorse149 says:
Would this also work using a 55 gallon barrel. I want to make a rotating barrel Composter and I like this idea. Your idea is very creative. I was thinking to myself how can I spin the barrel without having to spin it manually all the time. The other problem is my yard is surrounded by houses in a city residential area. Tthe wind does blow mostly from the front to the back. I'm thinking I would have to get the wind catcher up pretty high to catch any wind in the backyard.
Apr 23, 2009. 4:05 PMdrincon says:
I was looking for a composter but didn't want to dig a hole in my yard or get a big one. This is both artistic and esthetically pleaseing to the eye. I vote for you! Holly's friend-Delia
Apr 23, 2009. 4:33 AMsuperlite says:
Clearly you are a gifted inventor kdunner, your compost device is just the thing i am looking for and will build as soon as i have the time A#1.
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:kdunner
I'm a senior at Florida Tech studying Ocean Engineering (making wave and wind generators at sea). I'm into electronics, chemistry, all the sciences, alternative energy, welded steel art and lots more...
more »
