3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind powered Composter - The Green Twist , Exactly
Step 12Assemble the beast
Assemble the beast
Use lag screw or deck screws, or whatever you have around and scrap a test rig. Test for alignment of the shaft with the turbine and see if bearing are needed. I ended up using some old bearings from my inline skates and would suggest there use in furture projects. They are cheap and weather resistance.
Once the frame is prototyped, secure tacks with lags and give it a try. My final design sorta took a weird path of development but that is like my life. Depending on resources, your project may or may not look like mine, and that is a good thing. I would rather have it not look like mine since I truely value innovation over replication. But either way take a look at my result and try to do better!!\
I should note, the gear motor was attached to the barrel via a plate with a keyed hole in it. I failed to note that earlier.
Also, I made a video of the system in operation but I had the camera on it's side. I will post a less neck paining clip tomorrow as well to show it operation.
5 comments
Aug 31, 2009. 7:37 PMmpledger says:
This is really great. Good luck with the next model.
May 21, 2009. 6:29 AMdebpix says:
Bravo on a very clever idea. I don't know how your final exams turned out, but you deserve an A+ on this. You are right about turning a composter being the biggest chore. I'm looking at my huge composter outside my home office window. The beast sits there empty because I'm too lazy to go turn the handle (or fill it, keep it moist, etc.). You didn't win the Instructable prize (though you shoulda), but maybe you can make your first bazillion $ by patenting and marketing it.
Apr 29, 2009. 4:02 PMrednhez says:
how do you fill it?it seems like as soon as you open it the compost would fall out.
Apr 23, 2009. 7:18 AMworkhorse149 says:
Would this also work using a 55 gallon barrel. I want to make a rotating barrel Composter and I like this idea. Your idea is very creative. I was thinking to myself how can I spin the barrel without having to spin it manually all the time. The other problem is my yard is surrounded by houses in a city residential area. Tthe wind does blow mostly from the front to the back. I'm thinking I would have to get the wind catcher up pretty high to catch any wind in the backyard.
Apr 21, 2009. 10:56 AMGetDeBranded says:
Dude, It is brilliant. So many people are brain dead lazy and don't compost. This does it for them and for free. Unbelievable. Really, you should be very proud. Sincerely, GetDeBranded
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:kdunner
I'm a senior at Florida Tech studying Ocean Engineering (making wave and wind generators at sea). I'm into electronics, chemistry, all the sciences, alternative energy, welded steel art and lots more...
more »
