3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind powered Composter - The Green Twist , Exactly
Step 3Drill the shaft hole
After you cut them out, stack them up and use a drill to make the shaft hole. You can do this individually or all at once if you have a drill press and a really long drill bit. You don't need to be super accurate at all really since the turbine turns slowly and you will be grinding away a lot of material later on.
I used a 1/4 inch drill bit since I used 1/4 inch thread stock for the shaft. However, in retrospect I could have used a larger drill bit (1/2 inch or so) for the same shaft since the layers are compressed together with the end nuts. This would allow for easier re-alignment of the shaft had I poorly drilled my hole to begin with.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:kdunner
I'm a senior at Florida Tech studying Ocean Engineering (making wave and wind generators at sea). I'm into electronics, chemistry, all the sciences, alternative energy, welded steel art and lots more...
more »
