Step 9Drill the marked shaft
If you do happen to miss align the center point mark, you can move your mark a little bit closer to center by angling the centerpunch in the direction you want to move the mark and hammering again. Once the mark is reset, give it a couple of taps of the hammer vertically to clean up the dents.
Now, to drill. I wanted to drill and tap the shaft in place but I didn't have the right tap. So, I drilled the hole to the size of the turbines shaft (1/4 inch) and used a wrap of friction tape to make the connection lock together. The hole I drilled was only about half of a inch deep, but you can pick whatever depth you need per your supplies.
Add Comment
