3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind turbine with bicycle wheels
This instructable uses bicycle wheels to create a wind turbine. Some construction ideas come from A Home Power Plant - Wind Power Generator Revised
by bhunter736
Making a simple Savonius wind turbine
http://www.macarthurmusic.com/johnkwilson/MakingasimpleSavoniuswindturbine.htm
The timber frame idea comes from wind turbine by faroun
Faroun Savonius Wind Turbine
plus other net published constructions I can't remember plus some original bits.
WT.MOV2 MB
Step 1Make base and top frames.
Create two 700mm square frames
These frames to hold the axle bolt and make the whole construction simpler. I used 25mm pipe. Add an angle iron section across the the centre with a hole drilled at the centre able to take the wheel axle.
Fortunately I have a mate with a welder and is much better at it than me. Thanks Chris
24 comments
Mar 29, 2009. 1:28 PMbbion says:
dear engineers please design a portable windmill so i can take a wheel...of my bicycle ...duriiing nite ...to recharge... battery....at nite---10 lbs extra? with a bike wheel windmill
May 1, 2012. 5:11 PMalaskanbychoice says:
How about a genertor attached to the wheel while you ride so that it is charging on your way to your destination ?
Mar 19, 2010. 12:07 PMmahesh.ganpate says:
how much energy produce this wind mills
Apr 27, 2009. 12:25 AMtimmi says:
Hi Does anybody know what would sort of motor would be best for my wind turbine (perhaps that I could get from an appliance around the house etc)? Thanks Tim
Jun 24, 2008. 8:01 AMdsandds2003 says:
Looks GREAT and is a great idea. I could see this with a dc motor and maybe an Car alternator but to make alternator work you would need it to generate about 1600 rpm to get anything out of the alternator. Thinking a dc motor would work best. However this is a GREAT IDEA and leaves allot to experiment with as well. Now if I could just get the video to work.....
Oct 26, 2008. 4:54 AMfbuzzell says:
Check out TMA's VAWT for air foils in combination with vertical turbines. They report efficiencies at 40+% with the airfoil design
Jul 26, 2008. 7:41 PMSplineGod says:
Also if you left the tire on you might be able to use that to drive a small generator or DC motor by direct contact with the tire using friction.
Sep 20, 2008. 5:56 PMfreakinbill says:
Instead of fabricating the buckets from flat sheet metal why not use air-conditioning ducting or stove pipe?
Feb 25, 2008. 3:21 PMbhunter736 says:
Looks fantastic. I love the view of the veranda. The turbine seems so at home there. I love the fact that the baffles seem to help in a real world test too. I have not been able to answer that question with any certainty. I cant wait to see what kind of output you end up with. They are mesmerizing to watch arent they? : )
Feb 26, 2008. 9:41 AMfaroun says:
i do belive that i am the first to frame it and Direct the wind to the blades now, how about this idea, take a v belt and place it inside the rim with the pointy edge to the outside and then use a pm alternator or treadmill dc generator and place a pully on it and spring load it to the v belt. if you go to my project you will see that i did the same using a timing belt and it works. easy and you have the rim already. regards Faroun
Feb 20, 2008. 2:35 PMDanLoney says:
This is a really cool idea, does that get spinning very fast in the wind? i was thinking of using that design for mine, i was just going to use 1 bike wheel for a horizontal design, instead of a VAWT. i wanted to just screw in a hub on top of the piece of wood across the wheel and put blades on it but i wasnt sure all that weight would make it spin very fast. Great works that looks very cool ~DanLoney
Feb 25, 2008. 3:23 PMbhunter736 says:
True. Also, when the time comes, you can probably just use a treadmill motor as the generator. The torque should be pretty good, even with only one tier it should self start too. : )
Feb 23, 2008. 6:59 AMfaroun says:
nice work, i like the simple i dea of using bicycel parts and such. in my project i have created the wind direction idea to achive more tork and Yes it does work, cause at the same time where the back of the blade there is a vacume. in my project i am aiming for 400 watt but i am still at 180 at 20mph wind so i am working on another custom alternator, what are you aiming for? regards
Feb 18, 2008. 10:55 AMGorillazMiko says:
Cool idea. IF I were to try this, I would probably do something terribly wrong, but you are just amazing. Great job.
Feb 19, 2008. 5:35 AMLinuxH4x0r says:
Wow, why didn't I think of this?
Feb 18, 2008. 6:30 AMchuckr44 says:
Great idea since the bike wheels already have ball bearings. And you can hook the rear wheel sprockets to your generator.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:frednerk
