Step 4Fix metal sheets to bases to form bucket.
My buckets are 900mm high and 450mm around the template. The circumference of the templates is 470mm but I had a sheet of 900x900 so used what I had cut in half.
To fix the tin to the templates I predrilled the templates then marked the holes on elictrical tape which I ran around the template. I then applied the tape to to the end of the sheet metal and drilled the holes in the sheet metal.
I fixed the sheets to the templates using 25mm self tapping screws with the outside edge "flush" to the outside edge of the template and the inside edge short.
Add Comment
