3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind turbine with bicycle wheels
Step 5Fix the bucket to the wheels and the wheels to the top and bottom frames.
Attach the wheels to the bucket. I used two 50mm self tapping screws into each of the four pieces of timber screwed to the wheels in step 2. Take care here to centre the base plates on the axles. This is where the marked lines on the base board help in alignment.
If you intend to use the rear wheel cogs to drive generator or pump etc make sure the bucket rotation is correct. If it isn't correct turn the bucket upside down and it should be turning in the correct direction.
Bolt the end frames on to the wheel axles.
6 comments
Mar 29, 2009. 1:28 PMbbion says:
dear engineers please design a portable windmill so i can take a wheel...of my bicycle ...duriiing nite ...to recharge... battery....at nite---10 lbs extra? with a bike wheel windmill
May 1, 2012. 5:11 PMalaskanbychoice says:
How about a genertor attached to the wheel while you ride so that it is charging on your way to your destination ?
Mar 19, 2010. 12:07 PMmahesh.ganpate says:
how much energy produce this wind mills
Feb 20, 2008. 2:35 PMDanLoney says:
This is a really cool idea, does that get spinning very fast in the wind? i was thinking of using that design for mine, i was just going to use 1 bike wheel for a horizontal design, instead of a VAWT. i wanted to just screw in a hub on top of the piece of wood across the wheel and put blades on it but i wasnt sure all that weight would make it spin very fast. Great works that looks very cool ~DanLoney
Feb 25, 2008. 3:23 PMbhunter736 says:
True. Also, when the time comes, you can probably just use a treadmill motor as the generator. The torque should be pretty good, even with only one tier it should self start too. : )
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:frednerk
