Step 6Construct mounting frame.
Each wall was 350mm wide. I made 8 35x35x1300mm posts by ripping 70x35mm framing pine in half.
Cut 4 320x1200mm pieces of 9mm B grade exterior board to brace the posts.
I then ran the router down the edge of each post to remove a 9mm section for the braces to sit in.
Take two posts glue and nail or screw the brace into the section cut out by the router.
Bolt the frame sections one on each side of the metal frames. I used 50mm self tapping roofing screws for metal roofs but predrilled the pipe the take up easier.
Make sure it is on the metal frames such that the wind is not blocked. ie that when the bucket is across the frames will be covering the back of a bucket. I saw this frame design on another project but I didn't keep the reference to acknowledge it. I am sure if you are looking you will find where it came from. Alternatives might be to use steel posts and fencing pipe clamp connections . Either way this turbine can be dismantled and reassembled fairly easily.
Amazingly for my first try it does work!!
How much power I get when I hook the chain drive to my generator is yet to be seen.
Check out the video set up on my veranda.
comments
Add Comment
Add Comment
