3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Windbelt from hard drive voice coil and magnets
This is a Proof of Concept version of Shawn Frayne's Windbelt built from hard drive parts. I knocked it out in a couple of minutes because I got tired of waiting for someone else to do it ;-)
This is a quick and dirty instructable.
Step 1You will need ..
A hard drive
ribbon
wood
nail
magnet wire
led
55 comments
1-40 of 55next »
Feb 28, 2010. 12:35 PMjohn2010 says:
where on the voice coil do i solder the magnet wire ?
Sep 30, 2009. 1:34 AMbloodyjoe says:
hey are all these parts from a hard drive ?
Oct 29, 2008. 9:17 AMvigtigper says:
I just found this cool instruction video on how to construct the windbelt
http://www.youtube.com/watch?v=GlKRipoL1rI
Aug 12, 2008. 9:44 AMelectronic boy says:
you could add a 5 volt capacitor at 1 f to store the power then you will have longer bursts of light
Jun 3, 2008. 6:48 AMstonehenge360 says:
In the video it looks like the ribbon is not at its most efficient length. From what I remember from Physics, there should be an optimum length for any given wind speed that creates a standing wave harmonic in the ribbon which would be the most efficient power generator. Also, theoretically there is an optimum tension the ribbon should be at.
May 5, 2008. 8:19 PMmedievalbiscuits says:
What are the other two wires coming out going toward the left? (The ones that are not connected to the LED)
Feb 5, 2008. 3:06 PMdentsinger says:
This is cool. I can imagine wind flag farms might be even more efficient than turbines (without having looked it up yet.)
Jan 27, 2008. 1:26 PMnil0lab says:
Kudos! This is exactly what an instructable should be! What voltages did you get? Peak-to-peak or RMS? Anyone else replicate this? Can you tell us what your voltmeter said? And what hard drive you used? (make and model?) And what ribbon or string materials worked best for you?
Jan 27, 2008. 11:53 PMnil0lab says:
Exactly what I meant. Before the internet, people like us invented something and then wandered off bored and it was forgotten till someone else reinvented and published! Now we can do our little bit and spin it off for others to build on. You did say you got a voltmeter, though. Did you never measure?
Nov 10, 2007. 2:24 PMjongscx says:
What if you made added a full-wave bridge rectifier before the LED, since I'm assuming the coil creates an AC current since it oscillates.
Jan 27, 2008. 1:21 PMnil0lab says:
You'd obviously lose some of the voltage since you get .6V loss per std diode (.2V for germanium). http://en.wikipedia.org/wiki/Diode#Voltage-Current_characteristics. You'd maybe best step-up the AC voltage with an old transformer.
At low powers like this, every loss counts
Nov 11, 2007. 5:28 AMcarpespasm says:
then it would probably stay lit pretty continuously I would imagine. I've got a box of old dead hard drives that are waiting to have their magnets pulled, now I have a use for the coils if i can convince them to leave the casing without the need of a pair of pliers. I'd like to set up several of these in series to see what kind of output would be practical with something like this.
Nov 11, 2007. 8:07 AMguyfrom7up says:
it's a bit more complex than that, a proper power condition unit is more than just any old bridge rectfier.
Feb 10, 2008. 11:42 PMstatic says:
But not that complex either. Micro power generation generally has low expectations, like charging the batteries that power the devices. Not directly power devices that would be upset by the ripple of rectified AC of a varying frequency. A battery is an effective power conditioner it's own right, nothing simpler than a battery. Perhaps a MOV to clamp down spikes.
Nov 12, 2007. 6:34 PMDoctor What says:
does it produce AC or DC power, and could i shock people with it??
Nov 12, 2007. 7:08 PMDoctor What says:
dang
Jan 27, 2008. 1:13 PMnil0lab says:
Well, actually, the LED is a Light Emitting *Diode*. Diodes only let current through one way. I.e. what's actually going though the diode is DC, but pulsed.
Not that it matters much- to get DC from AC, all you need to do is add a bridge rectifier (four diodes). Or if you only want have the wave, use a half-wave rectifier (two diodes). See http://en.wikipedia.org/rectifier
Alternatively, if you want DC at a particular voltage (e.g. to charge a device), you can run the AC through a transformer to get a higher AC voltage. See http://en.wikipedia.org/Flyback_transformer. The idea would be to let the capacitor charge up till it exceeds the charging voltage and then release it to the device to be charged (I'd use a Power FET for that since they are very efficient). Something like an arduino or freeduino would control the flyback and the charge pulses quite well, I think.
Nov 20, 2007. 4:19 PMbofthem says:
Would you consider submitting this to the Mashup contest?
{instructables.com/id/How-to-Enter-the-Instructables-and-ReadyMade-Mash-/?ALLSTEPS}
Nov 17, 2007. 1:03 AMeight says:
They wrote a song about this didn't they...? "Tie a Yellow ribbon round the old oak tree..." Nice POC. Thanks for the post!
Nov 15, 2007. 7:20 AMHYRYSC says:
I love this because it takes materials that would normally end up in a landfill somewhere and is used to produce energy. There are probably things that you learned from this and could improve on, but you did it and I applaud you for that!
Nov 14, 2007. 10:50 AMshooby says:
Good job, this is cool. Any plans on using many of these to, for example, charge a cell phone?
After DC conversion of course.
Nov 11, 2007. 10:23 AMdglp says:
I don't have any spare voice coils, nor do I have the tools and workspace to make one of these, so I'm proposing it and hoping that someone will do it and send me the video. In addition, I never heard of a windbelt til now, so maybe everyone else has already thought of this. Since the principle is based on a vibrating ribbon, it should work almost as well with a string. more specifically, a string several metres long. Several strings of differing thickness (gauge) strung between poles should make a nice self-powered electric air guitar or harp. The guitar would need a fretboard and frets, the harp could just play itself in the breeze, like an electronic windchime. The problem of frets could be solved with a slider on each string and a series of peg holes in a 'fret' board - like a cribbage board; or by putting posts in the ground at tuned intervals, exactly like frets. This would be a good one for installation on the High Plains. Miles of fence wire tuned and ready to be played by the wind and passers-by.
Nov 11, 2007. 1:03 PMbofthem says:
http://botsmaker.blogspot.com/2007/09/wind-harp-on-shoutcast.html
http://youtube.com/watch?v=Pad1mgEAYbo
http://en.wikipedia.org/wiki/Aeolian_harp
Some wind harps, or aeolian harps aren't too hard to make. You could probably make one using tools you can borrow from anyone with a garage shop.
Nov 11, 2007. 2:17 PMdglp says:
Agreed - but the point of the windbelt is to generate electricity, so I'm thinking of ways to use that electricity. LED's are a nice idea, but using the electricity to power an electric guitar pickup (as one way of feeding the electrical output back into the device) seems like a cool thing to do. A self-powered, self-playing instrument could be entertaining.
Nov 10, 2007. 2:36 PM!Andrew_Modder! says:
:-\ so it just flaps?..
Nov 11, 2007. 3:38 AMwhatsisface says:
It generates electricity from the vibration of the tape in the wind.
Nov 11, 2007. 11:42 AM!Andrew_Modder! says:
oh ok :-)
Nov 10, 2007. 4:37 PMegreen767 says:
i think it makes electricity or something
Nov 10, 2007. 11:57 PMRoddy6667 says:
(removed by author or community request)
Nov 11, 2007. 9:27 AMKiteman says:
Removed? Why?
Nov 11, 2007. 2:10 AMKiteman says:
It generates electricity from the vibrations of a tape in the wind - in this case, the vibrating tape is twanging a coil between a pair of magnets, powering the LED to the lower-right of the video frame.
Nov 11, 2007. 8:40 AMfrickelkram says:
Ok ... you where faster than I .. :-) I was too busy with the Helloween contest. I have an instructable at work but I am not finished yet. My design is nearly the same than yours. I also use old hard disc drive parts. I use two of them to get more power out of the construction. The main difference is that I try to build a device that can be used. I don't want to build just the proof of concept. I know that it works. But I try to find out how effective the design is and if it is really usable. At the moment I still experiment with belts and I am working on the design of the power electronics. Powering a led is nice but I try to get a clean voltage out of the system and maybe stack some of the generators to get even more power ... I think it will still take some time until I get a working device.
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
