Introduction: Window Plant Cage
This is a "Plant Cage" to keep pets out of your window plants.
Step 1: Measuring
Measure the space to find out how much PVC pipe you will need.
Step 2: Materials
Gather the materials necessary for the project.
1. PVC pipe
2. PVC pipe cutter
3. Window screen
4. Zip-ties
5. PVC joints
6. Spray paint, if desired
Step 3: Assembly
Once you have measured and cut your pipe to size, fit it together how you would like it.
Step 4: Covering
Measure the material you want to use to cover it. Spread it over the frame and attach it.
Step 5: Attaching
For this I used zip-ties. I fount it easier to insert the knife. and with the knife still in the material, slide the zip-tie into place on top of it.
Step 6: Corners
Don't forget to fasten the corners, as it helps to keep the frame and covering in place.
Step 7: Finished
I hope that you enjoyed this instructable.
Zip Tie Challenge
