When you're finished with this project, you will have a low-cost accent light made with commonly available materials. The project is simple and produces great-looking results. If you want to do this with a bottle that has sentimental value to you, I recommend that you practice first because glass is a hard, brittle material and you need to get a feel for the process to increase the likelihood of success.
This instructable is easily adapted to assembly-line processes... Once you have all the jjgs built and materials together, you can whip out bottle after bottle. Total time per bottle is about 10 minutes.
Step 1: Equipment and Materials List
Here's the materials and equipment list:
Equipment
- Craftsman drill press or equivalent (you can do this project with a hand-held drill, but you'll have less control)
- Safety glasses
- Gloves
- Bottle and stopper jigs (See below for materials; instructions included)
- 1/2-inch diamond hole saw
- 5/16-inch drill bit
- 7/16-inch Forstner bit or standard drill bit the same size (the Forstner bit will work best, because it drills a flat-bottomed hole)
- A condiment bottle or other type of squeeze bottle
- A box knife or other sharp cutting tool
- Pliers
Materials
- Wine or liquor bottle, with cork or cap
- 12-inch section of wire coat hanger
- A 12-inch piece of 2x8 for the jig base
- 2 12-inch pieces of parting stop or similar material
- 6 1 1/2" wood screws
- 20-bulb string of white or multicolored Christmas lights
- #00 rubber stopper
- Modeling clay
- Goo-Gone brand adhesive removal product
Step 2: Choose Your Wine
This is the most fun part of the project. Find a distinctive wine bottle, and drink responsibly. I chose a 2004 Jailhouse Red Merlot with a picture of The King.
Try to choose a bottle with a clean, undamaged label. Colorful labels will give a quasi stained-glass look. Rinse out the bottle and either allow it to dry or dry it out with paper towels. Make sure the exterior of the bottle is clean and free of price stickers or other extraneous labels. Use Goo-Gone or other adhesive removal products to clean up the outside of the bottle.
Step 3: Build the Jig
While the bottle is drying, build your jigs. Although this step may seem unnecessary, it makes a big difference. The idea is to build a base onto which you can place the bottle and hold it steady and prevent rolling while drilling. You can use any material for the base, but the thicker material allows you to drill a hole to hold the stoppers securely while drilling.
Lay the 2x8 on a flat surface. Place a 12-inch piece of parting stop on the 2x8, roughly one quarter of the way from the edge. Screw the parting stop to the 2x8 using three of the wood screws. Place a bottle on the 2x8 against the first piece of parting stop, and place the other piece of parting stop on the opposite side of the bottle. Hold it in place, remove the bottle, then move the loose piece of parting stop slightly closer to the piece of parting stop already attached to the jig base. The goal is to hold the bottle slightly above the jig base, and prevent the bottle from rolling during the drilling process. Fasten the second piece of parting stop to the jig base with the remaining wood screws.
Somewhere in the center of the jig base, between the pieces of parting stop, drill a hole about 1.25 inches deep using the Forstner bit. Test the depth by inserting the #00 stopper; you want the hole to be deep enough to ensure the stopper is firmly seated, but still easily removed.
Step 4: Make the Fish Wire
Take the 12-inch piece of wire coat hanger, and bend a 90-degree ell about a quarter-inch long on the end. You'll use this to fish the light string out of the bottle and adjust the placement of the light string.
Step 5: Drilling the Stopper
Insert a stopper into the hole in the jig. Do not attempt this without the jig; holding the stopper with your hand will result in injuries!
Chuck the 5/16" drill bit into the drill press. Center the bit on the stopper, turn on the drill press, and drill through the stopper. You want a hole completely through the stopper. Most likely, you'll have to unscrew the stopper off of the drill bit.
Remove the stopper from the jig, and using the box knife or razor blade slice from the top to the bottom of the stopper with the point of the knife just inside the hole in the stopper. Later, you'll fit the stopper over the cord of the light string to act as a grommet.
A great tips from users 79spitfire and prof_jellis: Putting the rubber stopper in the freezer overnight will make it easier to drill; drill slowly so the bit doesn't get clogged with melted rubber. www.instructables.com/id/a-little-brown-egg-in-Maine%3a-terra-cotta-smoker/step4/Top-it-off/
Step 6: Make a Lubricant Reservoir
Take a piece of modeling clay, and work it into a rope approximately 4 inches long. Take the rope of modeling clay, and form it into a ring. This ring of modeling clay will serve as a reservoir for water to lubricate the diamond hole saw during the drilling process.
Step 7: Decide Where to Drill
Examine your wine bottle. Look for a place on the back of the bottle, near the bottom, free of labels. You want to drill the hole through the glass, but some bottles are made in such a way that you'll have to go through the label as well. Place the ring over the spot where you've decided to drill, and seal it to the bottle.
Step 8: Prepare to Drill
Chuck the hole saw into the drill press.
Place the jig on the drill press table, and place the bottle on the jig. Move the bottle until the diamond hole saw is centered over the ring of modeling clay, where you plan to drill your hole.
Step 9: Final Preparations
Fill the squeeze bottle with tap water. Fill the lubricant reservoir with water from the squeeze bottle. Check for leaks at the edges of the clay reservoir, and seal any you find.
Don your gloves and safety glasses. Glass is a hard, brittle solid and whenever you drill it you run the risk of shattering the bottle and injuring yourself. From this step on, you could injure yourself or those around you so work slowly and with care, and always wear proper personal protective gear.
Read the previous paragraph again :-)
Step 10: Drill the Hole
Start the drill press and lower the hole saw until it's just in contact with the bottle surface. This is very important: Don't force the hole saw through the glass; allow the saw to do its work. As you lower the hole saw into the work piece, the lubricant will cloud up with the glass dust from the drilling process. Continue to apply scant downward pressure on the press.
At some point (in my experience, about 20 to 30 seconds is all it takes), the lubricant will cascade into the bottle, which will indicate that you have drilled through the bottle. Continue applying downward pressure until the hole saw is completely through the bottle wall. Slowly reverse the hole saw out of the bottle, and turn off the press.
Step 11: Check Your Work
Check for cracks in the bottle. If you see cracks, discard the bottle. Remove the modeling clay ring and empty the bottle into the trash; you should see a small disc of glass (if it's not in the bottle, it's most likely stuck in the cavity of the hole saw). If the disc is trapped in the hole saw cavity, worry it out with a paper clip; when the edge is accessible pull the disc out of the cavity with needlenose pliers.
Rinse the bottle with water and allow the bottle to dry again.
Step 12: Add the Lights
Remove the 20-bulb light string from the box, and straighten it out. Plug the light string in to ensure it works, then take the #00 stopper and place it around the cord of the light string, with the wide end of the stopper toward the light string plug. You'll want the narrow end of the stopper to be a couple of inches away from the last light on the string.
Insert the first bulb on the string into the hole in the base of your bottle. Continue to feed the lights and cord through the hole, one at a time. On the second and subsequent lights fold the bulb against the cord and gently push through the hole. Take care not to nick the cord.
Once you've gotten four or five bulbs in the bottle, use the 12-inch piece of coat hanger to fish the first bulb on the string out of the bottle. Then, continue feeding bulbs into the base, pulling the light string out of the top of the bottle. This makes it easier to feed the string into the bottle.
Step 14: Reinsert the Light String and Arrange
Plug the light string in. Start feeding the light string back into the bottle, using the 12-inch piece of coat hanger to arrange the light string in the bottle. Continue until all of the lights are in the bottle. Avoid placing lights in the neck of the bottle.
1-40 of 50Next »
sunshiine says: Feb 27, 2013. 8:15 PM
I love this! Faved! Thanks for sharing and do have a splendorous day!
sunshiine
henri_cervantes says: Jan 8, 2012. 9:16 AM
i found christmas lights to be much too hot, the glass bottle becomes too hot to handle. LED is a better solution. ikea used to sell a great string of lights, they didn't market them as christmas lights, but that's what they look like.
hock3ydud3 says: Dec 7, 2011. 10:11 AM
If it is throwing off glass dust at all, you need to wear a respirator rated appropriately. It is horrible for your lungs. Good instructable, I'm going to attempt to make a few of these as christmas presents!
KEUrban (author) in reply to hock3ydud3Dec 9, 2011. 5:26 AM
Very good point. Inhaling glass dust can lead to silicosis, which is very bad as you say.
If you ensure that the clay reservoir is filled with water, glass dust is captured in the liquid. If you were doing dozens and dozens of these, I'd wear a respirator for sure.
desnotes says: Jan 15, 2010. 9:26 AM
Great instructable...I have always wanted to drill holes in glass for different projects. From reading your instructable I know that getting the proper drill bit is important. What about drill speed? I have a drill press for my dremel and would build a jig but what speed did you use to drill through the bottle?
Thanks,
desnotes@gmail.com
KEUrban (author) in reply to desnotesJan 16, 2010. 7:43 AM
I set my drill press at 1,100 RPM when drilling bottles. I put scant pressure on the bit, allowing it to cut at its own pace. Keep the bit lubricated with water.
In my experience (and contrary to some other 'ibles that say it takes minutes or hours to drill through glass) it takes about 30 seconds to drill through a wine bottle, and a bit longer to go through thicker-walled bottles like liquor bottles.
Good luck!
Kenneth
seekertat in reply to KEUrbanFeb 6, 2011. 5:38 AM
The drill press does work wonders and fast; however, if you do put pressure on it, the glass where you're drilling will break. Also, odd shaped bottles (pear shaped) are difficult to work with but they can be done with the drill press too.
KEUrban (author) in reply to seekertatAug 31, 2011. 8:48 PM
For odd-shaped bottles I fill a plastic bag with sand and put the bag in a small box. Then, nestle the bottle in until it's in the proper orientation for drilling.
desnotes in reply to KEUrbanJan 17, 2010. 11:21 AM
 Thank you for the response. Drilling glass has been something I've always wanted to do and now I have all the instructions. Thanks again.
Mike
desNotes
leannehr says: Aug 26, 2011. 10:45 AM
I love this project, I made a couple and want to put a cute bottle stopper on it but then I really think it will get to hot and if I try to sell them I don't want to risk fires for someone else. I have 20 light strand and I want LED lights but they are all to long with to many lights. Does any body know where to get LED's around 6 feet in length that are not battery operated? IM DESPERATE! I've looked every where! Thanks!
KEUrban (author) in reply to leannehrAug 31, 2011. 8:46 PM
I'm glad you like this project.
I've looked for short LED strands but all I can find are battery powered strings. Even with stoppers, none of mine get very hot. Please post if you find a source, though.
cattco says: Aug 29, 2011. 7:44 AM
hi, can the labels be left on the bottle then the bottle lamp sold for profit? just wondering if this is legal because i also make these for family but a friend wants to put them in her shop. thanku :)
KEUrban (author) in reply to cattcoAug 31, 2011. 8:44 PM
That's a good question. Since I'm not a lawyer and I don't play one on TV, I'm not sure I'm qualified to answer. Fellow instructabrarians? Any direction for Cattco?
CLIFTON23708 says: Jan 7, 2011. 6:15 AM
I'M GIVING AWAY MY TRADE SECRET. USE AUTOMOTIVE ANTI FREEZE!!! IT'S SLIPPERY, AND DOESN'T BOIL OVER.
ncohen2004 says: Dec 4, 2010. 2:05 PM
I just love these bottles....i bought one and love it but am a little fearful of the heat....i'm afraid the heat will shatter the bottle....am i being over cautious? The craftman used christmas lights.....
KEUrban (author) in reply to ncohen2004Dec 4, 2010. 4:08 PM
The light strings I use have just 20 bulbs, so the ones I've built never get hot, just warm. If someone crammed a 50- or 100-light string in I imagine it would get much warmer. Hot enough to shatter the glass? Most likely, not (in fact, I can't imagine that). But hot enough to melt the insulation? With 100 lights it might.
I'm glad you like them... They are pretty cool.
Kenneth
ncohen2004 in reply to KEUrbanDec 4, 2010. 5:22 PM
thanks for your response....i do believe there are only 20ish lghts....it gets warm...not hot...and so now i feel much better using it...thanks again and happy holidays!
Sowee says: Sep 5, 2010. 1:23 PM
I did this, but without drilling a hole. Its amazing, but gets VERY hot.
KEUrban (author) in reply to SoweeSep 5, 2010. 3:47 PM
That's interesting; the ones I've made get warm but never hot. What type of lights did you use? Is it possible you nicked the cord?
Holcan says: Jul 16, 2010. 11:46 AM
What does accent mean? Sorry for the ignorance D:
KEUrban (author) in reply to HolcanJul 16, 2010. 7:45 PM
No such thing as an ignorant question! An accent lamp or light is a lamp that is used to make a design statement in a room. It is used in addition to the primary light (like a ceiling light) in a room. See: http://interiordesign.lovetoknow.com/Small_Accent_Lamps
Holcan in reply to KEUrbanJul 16, 2010. 9:24 PM
O I get it Thank you very much man
spa31rky says: Jul 12, 2010. 3:37 PM
Great work! I seen this at a local flee market......the people were selling them for $35 dollars and up.......and they sold too!
TabbyDeAnne says: Jun 22, 2010. 1:36 PM
This is fantastic! I also have wondered how to drill through glass and have lots of unused wine bottles so this is high on my list of "to do's"! Thank you so much for taking the time to teach us how!
KEUrban (author) in reply to TabbyDeAnneJun 22, 2010. 2:15 PM
You're very welcome. I'm glad you found it useful. I'd love to see you post your finished bottles!
ragdolldude says: Jun 6, 2010. 7:23 PM
I've made several of these bottle lights, using the led's. I"ve put up to 60 led bulbs in bottles. I cut off the plug and feed the cut wires first into the bottle. I solder a lamp cord/switch to wire ends that are pulled through thedrilled bottle . Glass bits can be found on Ebay easily. I then feed the bulbs in through the neck of the bottle. I use a mechanics claw tool to grab the bulbs and wires to help spread them around the bottle for a more even look. I've also used an etching compound to "frost" the bottles exterior. I've left some of the led bottles lit for several days, with no noticeable heat.
KEUrban (author) in reply to ragdolldudeJun 7, 2010. 3:47 PM
That sounds very nice. I'd like to see a picture!
ragdolldude in reply to KEUrbanJun 8, 2010. 1:33 PM
I can't seem to upload photos. All photos are jpeg format, but can't seem to get them into the reply box. Suggestions?
KEUrban (author) in reply to ragdolldudeJun 13, 2010. 5:37 AM
Down below the reply box, lower-left, is an "add images" button. Once you browse to the file and add it, click the "Upload" button.
wdwdash says: Dec 28, 2009. 7:37 AM
 I did this project yesterday - pretty cool results!
KEUrban (author) in reply to wdwdashDec 28, 2009. 9:59 AM
Glad you like it!
luvit says: Dec 17, 2009. 5:24 PM
i;ll finish my wine tonight and do this. i have a string of lights in my shopping cart. they don't work, but that;s ok. i don;t have electricity.
and-reas says: Dec 9, 2009. 11:54 AM
I wanted to do a instructable about this exact same thing! Oh well, gonna make it anyway. Thanks for the tip of the reservoir =D
porcupinemamma says: Aug 8, 2009. 4:04 AM
very pretty
j0nny says: Apr 13, 2009. 5:00 AM
I am planning on making some for a gift. However, i plan to use some glass frosting spray on the inside of the bottle to hide the lights a bit and make a cool lighting effect. It might look dreadful but i'll post how it goes. Oh, and thanks for the great instructable!
wiccanman82 says: Mar 2, 2009. 3:46 PM
thats a great idea, im moving from maine to boston to go to le cordon blue college and this will be a great addition to my new apartment... I love it thanks for the great idea
KEUrban (author) in reply to wiccanman82Mar 2, 2009. 5:59 PM
Thanks for the comment! Good luck at Le Cordon Bleu!
kitze says: Jan 14, 2009. 12:52 PM
Hey! Great idea, even though there already is a very similar project on this site where the result looks even better imho - and it uses LEDs! Every project is great that has LEDs in it! :)
http://www.instructables.com/id/Bawls-Blue-Crystal-LED-Light/
KEUrban (author) in reply to kitzeJan 29, 2009. 2:46 PM
See my reply earlier about the suitability of this project for LEDs... I used regular bulbs because that was what I had on hand. LEDs are awesome, I agree. I like the instructable you linked to, but I find it a bit scary to fill the bottle with shards of broken glass!
jianqiang says: Jan 25, 2009. 6:56 PM
good idea with the water to soak up the glass dust, I couldnt figure a way around that in my head.
1-40 of 50Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
