3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wine Bottle Accent Light
When you're finished with this project, you will have a low-cost accent light made with commonly available materials. The project is simple and produces great-looking results. If you want to do this with a bottle that has sentimental value to you, I recommend that you practice first because glass is a hard, brittle material and you need to get a feel for the process to increase the likelihood of success.
This instructable is easily adapted to assembly-line processes... Once you have all the jjgs built and materials together, you can whip out bottle after bottle. Total time per bottle is about 10 minutes.
Step 1Equipment and Materials List
Here's the materials and equipment list:
Equipment
- Craftsman drill press or equivalent (you can do this project with a hand-held drill, but you'll have less control)
- Safety glasses
- Gloves
- Bottle and stopper jigs (See below for materials; instructions included)
- 1/2-inch diamond hole saw
- 5/16-inch drill bit
- 7/16-inch Forstner bit or standard drill bit the same size (the Forstner bit will work best, because it drills a flat-bottomed hole)
- A condiment bottle or other type of squeeze bottle
- A box knife or other sharp cutting tool
- Pliers
Materials
- Wine or liquor bottle, with cork or cap
- 12-inch section of wire coat hanger
- A 12-inch piece of 2x8 for the jig base
- 2 12-inch pieces of parting stop or similar material
- 6 1 1/2" wood screws
- 20-bulb string of white or multicolored Christmas lights
- #00 rubber stopper
- Modeling clay
- Goo-Gone brand adhesive removal product
49 comments
1-40 of 49next »
Jan 8, 2012. 9:16 AMhenri_cervantes says:
i found christmas lights to be much too hot, the glass bottle becomes too hot to handle. LED is a better solution. ikea used to sell a great string of lights, they didn't market them as christmas lights, but that's what they look like.
Dec 7, 2011. 10:11 AMhock3ydud3 says:
If it is throwing off glass dust at all, you need to wear a respirator rated appropriately. It is horrible for your lungs. Good instructable, I'm going to attempt to make a few of these as christmas presents!
Jan 15, 2010. 9:26 AMdesnotes says:
Great instructable...I have always wanted to drill holes in glass for different projects. From reading your instructable I know that getting the proper drill bit is important. What about drill speed? I have a drill press for my dremel and would build a jig but what speed did you use to drill through the bottle?
Thanks,
desnotes@gmail.com
Feb 6, 2011. 5:38 AMseekertat says:
The drill press does work wonders and fast; however, if you do put pressure on it, the glass where you're drilling will break. Also, odd shaped bottles (pear shaped) are difficult to work with but they can be done with the drill press too.
Jan 17, 2010. 11:21 AMdesnotes says:
 Thank you for the response. Drilling glass has been something I've always wanted to do and now I have all the instructions. Thanks again.
Mike
desNotes
Aug 26, 2011. 10:45 AMleannehr says:
I love this project, I made a couple and want to put a cute bottle stopper on it but then I really think it will get to hot and if I try to sell them I don't want to risk fires for someone else. I have 20 light strand and I want LED lights but they are all to long with to many lights. Does any body know where to get LED's around 6 feet in length that are not battery operated? IM DESPERATE! I've looked every where! Thanks!
Aug 29, 2011. 7:44 AMcattco says:
hi, can the labels be left on the bottle then the bottle lamp sold for profit? just wondering if this is legal because i also make these for family but a friend wants to put them in her shop. thanku :)
Jan 7, 2011. 6:15 AMCLIFTON23708 says:
I'M GIVING AWAY MY TRADE SECRET. USE AUTOMOTIVE ANTI FREEZE!!! IT'S SLIPPERY, AND DOESN'T BOIL OVER.
Dec 4, 2010. 2:05 PMncohen2004 says:
I just love these bottles....i bought one and love it but am a little fearful of the heat....i'm afraid the heat will shatter the bottle....am i being over cautious? The craftman used christmas lights.....
Dec 4, 2010. 5:22 PMncohen2004 says:
thanks for your response....i do believe there are only 20ish lghts....it gets warm...not hot...and so now i feel much better using it...thanks again and happy holidays!
Sep 5, 2010. 1:23 PMSowee says:
I did this, but without drilling a hole. Its amazing, but gets VERY hot.
Jul 16, 2010. 11:46 AMHolcan says:
What does accent mean? Sorry for the ignorance D:
Jul 16, 2010. 9:24 PMHolcan says:
O I get it Thank you very much man
Jul 12, 2010. 3:37 PMspa31rky says:
Great work! I seen this at a local flee market......the people were selling them for $35 dollars and up.......and they sold too!
Jun 22, 2010. 1:36 PMTabbyDeAnne says:
This is fantastic! I also have wondered how to drill through glass and have lots of unused wine bottles so this is high on my list of "to do's"! Thank you so much for taking the time to teach us how!
Jun 6, 2010. 7:23 PMragdolldude says:
I've made several of these bottle lights, using the led's. I"ve put up to 60 led bulbs in bottles. I cut off the plug and feed the cut wires first into the bottle. I solder a lamp cord/switch to wire ends that are pulled through thedrilled bottle . Glass bits can be found on Ebay easily. I then feed the bulbs in through the neck of the bottle. I use a mechanics claw tool to grab the bulbs and wires to help spread them around the bottle for a more even look. I've also used an etching compound to "frost" the bottles exterior. I've left some of the led bottles lit for several days, with no noticeable heat.
Jun 8, 2010. 1:33 PMragdolldude says:
I can't seem to upload photos. All photos are jpeg format, but can't seem to get them into the reply box. Suggestions?
Dec 28, 2009. 7:37 AMwdwdash says:
 I did this project yesterday - pretty cool results!
Dec 17, 2009. 5:24 PMluvit says:
i;ll finish my wine tonight and do this. i have a string of lights in my shopping cart. they don't work, but that;s ok. i don;t have electricity.
Dec 9, 2009. 11:54 AMand-reas says:
I wanted to do a instructable about this exact same thing! Oh well, gonna make it anyway. Thanks for the tip of the reservoir =D
Aug 8, 2009. 4:04 AMporcupinemamma says:
very pretty
Apr 13, 2009. 5:00 AMj0nny says:
I am planning on making some for a gift. However, i plan to use some glass frosting spray on the inside of the bottle to hide the lights a bit and make a cool lighting effect. It might look dreadful but i'll post how it goes. Oh, and thanks for the great instructable!
Mar 2, 2009. 3:46 PMwiccanman82 says:
thats a great idea, im moving from maine to boston to go to le cordon blue college and this will be a great addition to my new apartment... I love it thanks for the great idea
Jan 14, 2009. 12:52 PMkitze says:
Hey! Great idea, even though there already is a very similar project on this site where the result looks even better imho - and it uses LEDs! Every project is great that has LEDs in it! :)
http://www.instructables.com/id/Bawls-Blue-Crystal-LED-Light/
Jan 25, 2009. 6:56 PMjianqiang says:
good idea with the water to soak up the glass dust, I couldnt figure a way around that in my head.
Jan 6, 2009. 11:17 AMelgoetsch says:
Just what I need!
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:KEUrban
I am an administrator at a college, responsible for academic and student affairs. In a previous life, I was a human factors engineer and human performance researcher. I have post-graduate degrees in ...
more »
