Sadly my gardening options are limited by apartment life, but there are still loads of container options available. When I saw an awesome planter made from a repurposed wine bottle, I knew it was something I had to give a shot. With a few simple tools, you can turn the remains of a wild weekend into some gorgeous greenery.
Step 1: You'll Need. . .
  • An empty wine bottle (or two - it doesn't hurt to have a couple extra in case anything goes awry and to allow a few practice runs)
  • Glass cutter
  • A box or scrap wood to position your glass cutter on to help provide a straight score line
  • Fine-grit sandpaper (you could also use a Dremel or sander if you wanted to)
  • Tea kettle or pot of boiling water and source of cool/cold running water
  • Wool felt or similar fabric (undyed is suggested)
  • Small stones, marbles, or similar
  • Small plant (a hydroponic or air plant is suggested - succulents also work well (a jade plant is shown here))
  • Safety glasses
Calelovezit says: Aug 11, 2011. 7:42 AM
where did I see this?
shesparticular (author) in reply to CalelovezitAug 11, 2011. 7:44 AM
I'm not sure what you mean? I included a link to where I saw it, but I believe they're available from a number of retailers.
tacamaral in reply to shesparticularJan 22, 2013. 4:55 AM
Any idea where I can buy one of these? : )
shesparticular (author) in reply to tacamaralJan 22, 2013. 4:58 AM
The retailer where I saw them is linked above, but if you try a search for "Grow Bottle" you'll likely find others as well :)
circuitfish says: Sep 7, 2011. 4:39 PM
My only addition would be a note that if you're going to be using a dremel or other high-speed grinder on glass you really need to be wearing a respirator of some kind. Ground glass in your lungs is not a pleasant way to go.
shesparticular (author) in reply to circuitfishSep 7, 2011. 5:06 PM
Awesome point and for sure worth mentioning. Thanks!
Calelovezit says: Aug 12, 2011. 8:14 AM
saw it on a craft blog last month, cant remember where, Im looking! Ill let you know!
shesparticular (author) in reply to CalelovezitAug 12, 2011. 8:16 AM
Oh, I haven't seen this idea on any blogs, but it's a great reuse project, so that's great that others are doing it as well!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
