http://www.instructables.com/id/How-to-use-a-wet-tile-saw-to-cut-glass-bottles/
http://www.instructables.com/id/Hanging-Liquor-Bottle-Candle-Lamp/
I've found that a regular tile sawblade in the wetsaw doesn't make a very clean cut but it does work. I tried several ideas for the wire and candle support before deciding on the one shown. Recycled used giant sparkler wire from New Years was ok but kind of overkill, the bottom of an aluminum can as a candle support worked but was to much work for the final result. But enough of what DIDN'T work.
Step 1: Materials and tools
recycled wine bottles, you can also use liqueur, beer or water(glass) bottles
found electrical wire
left over votive and tea-lite candles from Halloween
Tools:
I borrowed a wetsaw from a friend
SAFETY GOGGLES ! <<<< Cutting glass is dangerous to your eyes regardless of how you cut it
Pliers
Wire cutters
Needlenose pliers
Razorknife
Step 2: The bottles
Step 3: Forming the wire
Starting at one end of a single wire, form a coil approximately 1 1/2 inces across and then make a 90degree bend.
Measure up about 4inches from the coil and make another 90 degree bend towards the center of the coil.
Make another 90 degree bend pointing upwards from approximately the middle of the coil.
Eyeball where the shoulder of the bottle begins and make a couple of loops in your wire (this keeps the wire from pulling up to far.) I put another bend in the wire loop because I made it a little to wide.
Make any extra/decorative bends you may need to put the coil about 1/2 inch from the bottom of the bottle
Step 4: Wire part 2
The more observent may notice I started with a clear bottle and now Im using a green bottle, that's because I only had clear bottles left uncut !
Step 5: Hang and light
Slide the bottle up the wire and place either a votive sized candle or tea-lite candle on the coil and light it , then slide the bottle back down.
WARNING : Votive size candles make the bottle HOT to the touch, tea-lites only make the glass warm (experience typing here)
Visit Our Store »
Go Pro Today »
It seems like it works pretty well but I haven't had a chance to try it yet. Also, the bottle necks don't crack when the candles are lit? I've had problems with narrow-necked candle votives that crack or shatter internally when they get too hot.
I haven't had any instances of the bottle breaking due to heat from the tealight candles or votive size candles with this design, although if the candle was too high in the bottle I could see it being possible
http://youtu.be/_vILNflmwFw
sunshiine
sunshiine
When you beg,borrow,barter the saw cut 2-3x what you think you'll need because friends have a tendency to appropriate one or 2 for their trees... or in one case, windows.
Maybe if I frost/etch the clear bottles...hhhmmmm
Thank you for commenting
