I've seen many of the wine bottle puzzle kits that are available for purchase but they seemed a little expensive for what they are. Since joining my local hackerspace (Northackton) I've not actually made anything, so I thought I'd see if I could make one over a weekend.
Based on pictures of existing designs, I started with some sketch drawings to see if it was feasible. I might have a go at drawing up a CAD version, as I'd like to try cutting one out with CNC or even a laser cutter in the future. It would be really interesting to try it with acrylic.
This is my fist Instructable, so constructive criticism and comments are gratefully received. I'd be really interested to see if anyone else has a go at building one.
Step 1: Cut out parts
I was quite surprised by how little material I needed to make this puzzle. There's not that many parts but some of them are a little small and fiddly.
I used entirely materials I had lying around: some 5mm ply, some 8mm ply and some thin rope; thick shoelaces would probably suffice. As a protoype ply was fine, but I think it would look nicer in plain wood. Wood glue holds it all together, though its annoying to wait for it to set. You'll need minimal tools. I used a jigsaw to cut the wood, but a scroll saw would be better. A drill and bit of similar size to your rope is also necessary.
After a little research online, I started with some scrawly paper sketches to see if the concept would work and work out some sensible dimensions. With a puzzle of this type, accurate dimensions are quite critical. I did make one mistake, but I was able to recover it.
Skip these if you don't follow, it should all become clear in the next couple of steps.
Semper Fi says: Jan 24, 2011. 6:48 AM
Thanks for the instructable, love it. My wife wanted one, the pic is my second one and i've got 2 more to make. Really enjoyed it
164116_10150372743340123_884190122_16547944_1899532_n.jpg168168_10150372743255123_884190122_16547942_7882561_n.jpg
MatB (author) in reply to Semper FiJan 24, 2011. 10:18 AM
Wow. That's really really nice. I'm still waiting for my father to solve my puzzle so I can have it back to help make another one.
mattbomb says: Dec 17, 2010. 11:38 AM
hey dose this work for alcoholics?
ddemayo in reply to mattbombMar 21, 2012. 11:24 AM
replace the rope with a chain of the same size and it could
Dr.Earl Insanity in reply to mattbombAug 1, 2011. 5:31 AM
don't quite think so.....a knife would solve this quickly and sadly...
slithien says: Feb 15, 2011. 10:48 AM
i might make this for my GCSE resistent materials product. at the moment im making a burr puzzle. hmm
Semper Fi says: Jan 25, 2011. 4:15 AM
Thanks MatB, just made one thats better,i think. Can't post it yet, its another birthday gift. Good Luck with father,lol.
ndzoch says: Dec 23, 2010. 2:37 PM
Is there a solution to this? I built it and can't figure out how it is even posible to open.
MatB (author) in reply to ndzochDec 30, 2010. 8:47 AM
Personally speaking, I built it unlocked and then locked it, but each to their own. If you've built it just as in the picture it should be unlockable, but it did take my brother a couple of days over Christmas to figure it out.
JJYork says: Dec 21, 2010. 6:30 PM
I am having trouble reading your diagrams. What are the dimensions of the hasps and do they need to be able to fit through the hole in the cleat? And I am assuming that the slots in the hasps are 35 by 5 mm. Is that correct?
MatB (author) in reply to JJYorkDec 23, 2010. 8:06 AM
Sorry for the delay in replying. I tried to get round to doing a CAD drawing for you, but I haven't managed to yet.
The hasps should be small enough to just fit through the hole in the cleat (my hole was 22mm, but then I had to elongate it a little to allow both hasps to fit on the cleat yet still let the small ball through. I planned them at 20mm x 40mm but in the end made them a little longer - length is not critical.
A slot of 35mm x 5mm seems about right. Since letting my brother loose on my puzzle I've found that you want the one that's part of the bottle cover to be a tight fit widthways so it can't be slid off over the rope. The one that is part of the locking mechanism needs a bit more play as sliding over the ropes is part of the solution; perhaps make this slot about 8mm to 10mm wide if you're using 5mm ply.
Verga says: Dec 17, 2010. 2:24 PM
Great Ibble, I am going to do several of these in solid hardwood and give them away next Christmas, and adding this to my faves.
Lorax98 says: Dec 16, 2010. 6:35 AM
Thanks for the Instructable. I have been wanting to "reverse engineer" one of these two part puzzles for some time. I currently make a cage style puzzle for wine and spirits that I give away during the holidays. They are easy to make, deceptively difficult to open, and look great behind a bar or on a liquor shelf. Your puzzle will add to the available styles that I can manufacture. I would like to alter the design slightly in order to use a cork screw as part of the mechanism. This would make a complete "Wine Kit" out of the puzzle.
Verga in reply to Lorax98Dec 17, 2010. 2:18 PM
Love to see and instructable about a cage style puzzle.
MatB (author) in reply to Lorax98Dec 16, 2010. 10:24 AM
A cage-style puzzle sounds cool. I'd like to see pictures or even better and Instructable on it. Neat idea to include a corkscrew in the puzzle.
jpurtell says: Dec 16, 2010. 2:50 PM
MatB-that is really well done. You are way smarter than I am.
RoaringSilence says: Dec 16, 2010. 2:11 PM
This is fantastic! I'm making this for my parents for Christmas, they'll get a kick out of it.
slackpat says: Dec 16, 2010. 12:56 PM
I had thoughts of doing the same puzzle nice job
vaberon says: Dec 13, 2010. 4:57 PM
to solve the puzzle, i would just cut the string. :P
GothPoet in reply to vaberonDec 16, 2010. 10:54 AM
Gordium called, they have a knot they want you to look at.
lukeyj15 says: Dec 16, 2010. 2:36 AM
Use high tensile wire in place of the string for a harder challenge.
martzsam says: Dec 15, 2010. 2:42 PM
That's diabolical!
Greasetattoo says: Dec 13, 2010. 8:27 AM
I bet a scissors could open the lock!! lol
GREAT instructable!
Good job!
MatB (author) in reply to GreasetattooDec 13, 2010. 11:04 AM
That's cheating!
Kryptonite says: Dec 13, 2010. 1:46 AM
Awesome job! I love making little puzzles out of wood / metal as gifts, they're so much rewarding that just a pretty ornament! I'll have to try this one, but it may be a while in the coming due to lack of tools at the moment.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
