Winter Scene Bauble Ornament
2,444
115
8
Posted
Introduction: Winter Scene Bauble Ornament
This is a great, fun way to make a boring old bauble more exciting, and a great way to upcycle unwanted baubles.
What you'll need:
  • Plastic bauble
  • Small plastic animal
  • Paper clay
  • Paint
  • Trims
  • Skewer
  • Candle
Step 1: Burn Your Bauble
Light a candle and hold the bauble slightly over the flame. A dent should start to form; stick the skewer in to pierce the plastic. Continue burning until your desired size and shape of hole is dented in. Use all-purpose scissors to cut out this area while it is still soft and pliable. Heat the edges of the hole on the flame and bend them in, but be careful not to burn your fingers.
Step 2: Paint the Bauble
Paint the outside of your bauble white, and the inside whatever colour you like. I painted mine a light blue. I found it easiest to paint the bauble when it wasn't on a flat surface, so I taped a chopstick to my lamp, and taped the bauble to the chopstick.
Step 3: Add the Air-dry Clay
Press some air dry clay (I used paper clay) into the base of the ornament, creating a flat surface. Ensure that your figure can stand and is at your desired height, and press it into the clay slightly to create footprints, keeping your desired positioning for when you glue it in. Allow to dry.
Step 4: Add Your Braid and Your Creature
Add some braid around the edge of the hole to cover the raw edge. Finally, glue your plastic animal into the footprints you made, and you're done!
  • made it! :D thanks a...-Ameedroid
    Ameedroid made it!
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
7 Comments
Thank you very much for this instructable! I've been wanting to know how to do it for such a long time :D thanks to you I am now in the process of doing so! :D
I did realise that using a heated knife and sliding it down the bauble works well too.. :)
Thanks again! :D
Really nice, I'm going to make some . It would be nicefor gifts.
It would make a great gift! Post a picture if you make your own! :)
Thank you!
Thank you! :)
