Introduction: Wire Christmas Tree Earrings
wire wrapped fun festive colorful earrings
Step 1: Materials
gather different colors of thin wire, I used the Christmas wire from michaels.
jewelry round plyers
hot glue gun just for tip or any glue bottle tip works
earring backs
any small star type bead or charm (optional)
jewelry jump rings
Step 2: Step One Cut and Twist Wire
Cut a few inches of length of all the wires you are using I suggest 3-5 different colors. then lightly twist them together, just enough that they don't come apart.
Step 3: Make Top Loop
use the round nose pliers and twist until you have a loop that will be used to attach it will later
Step 4: Wrap Wire to Form Tree
Hold the loop on the top of the bottle, it is ok if it bends, then begin to wrap the wire around the top of the glue bottle or glue gun tip (make sure it is cool)
Step 5: Cut Wire and Reform If Needed
When it is the length you want it, cut the wires and tuck then up to the last circle and if the first loop bent down use the pliers to bend it back up
Step 6: Attach Jump Ring and Charm (optional)
open jump ring enough to put it through the original loop them put the charm on the ring as well, make sure it's on the side you want it on.
Step 7: Attach to Earring
then put the jump ring through the earring and close it up with pliers (again before closing the jump ring make sure our will hang the way you want it to).
First Time Authors Contest 2016
Epilog Contest 8
Homemade Gifts Contest 2016
