Make a Wire Dispenser From a Recycled Bottle
 by fjordcarver
Here is a quick and simple shop idea for storing jumbles of wire using a recycled bottle.
Step 1: Stuff to Find
All you need for this project is a plastic bottle that has enough capacity for the jumble of wire you would like to organize, and a utility knife.
Step 2: Make the Dispenser
Begin by cutting the bottom off of your bottle.
Next drill a hole large enough for the wire to pass through freely in the cap. You can use your knife as a drill by twisting the point of the blade back and forth slowly while applying a slight pressure.
Pierce a small hole somewhere near the top of the dispenser so you can hang it up on a nail in your workshop later. It should hook on the nail as you may want to reload it one day.
Now you can load up your wire for convenient dispensing. You do this by passing one end down through the hole in the cap and then winding it around the inside of the bottle. Once you are all wound up, you can hang it up and use it. Just tug out some wire and snip. No more mess or tangles.
If you are making one for small wire, as I was, hot glue a milk bag cutter on the bottom and have a built in cutter! Awesome.
Share and enjoy.
pfred2 says: Nov 30, 2011. 8:05 PM
You obviously haven't seen any of my jumbles of wire. I only have 3 acres so I don't think I've enough room to do this!
fjordcarver (author) in reply to pfred2Nov 30, 2011. 9:06 PM
Use a paint can for a big jumble
pfred2 in reply to fjordcarverNov 30, 2011. 10:16 PM
It'd take a few cans and they'd all have to be 55 gallon drums at that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
